Re: [Mpi-forum] Many MPI-tickets: Actions needed before July meeting
Dear Jeff, (and others below) please can you correct the title of
https://svn.mpi-forum.org/trac/mpi-forum-web/report/14 from "MPI-2.2 errata / MPI-3: Tickets that need to be discarded (moved or withdrawn)" to "MPI-2.2 errata / MPI-3: single-vote-corrections should be "Scheduled, July 2012 Chicago", all other moved to MPI-next or withdrawn"
Dear Bill, Jesper, George, Hubert, Pavan, Jeff H., Jed, Rich, Tony, Alexander, Fab, Douglas, Marc, Marc-Andre, Mohamad, Current status of needed actions of all the tickets that are in this report https://svn.mpi-forum.org/trac/mpi-forum-web/report/14 - Errata tickets that have to go into MPI-3.0 Tickets 166 (solution TO-DO) gropp, 170 gropp, 172 rabenseifner, 179 traff, 181 bosilca, 186 hubertritzdorf, 191 gropp + 201 rabenseifner (those parts that are not touched by 259), 202 (as MPI-2.2 errata!) rabenseifner, 222 balaji, 316 jhammond, 318 jedbrown, 329-335 gropp Action: These tickets should be checked by the ticket authors: - the solutions completed, and - please mark then with -- Milestone "July 2012 Chicago" -- Priority "Scheduled" - and then voted with such a reading-and-single-and-only-vote (especially the tickets that span several chapters) at the following meeting (can be also done in a block of votes as in May), - or some tickets are already done, because the content is already included into the ticket 0 part by the related chapter author(s). - Other tickets that should be switched to MPI-next (or withdrawn): Tickets 32 traff, 47 graham, 59 hubertritzdorf, 165 tony, 176 asupalov, 194 gropp +195 balaji, 198 ftilier, 217 dougmill, 310 snir, 311 snir, 319 jedbrown Action: please update the ticket's "Version" into "MPI-next" and also "Priority" to new/correct state (or resolve with "Withdrawn") - Probably to be withdrawn: Tickets 102 bosilca (solved by 278), 177 asupalov + 190 gropp (solved through 279), 178 asupalov (probably not needed), 261 mahermanns (see comments within the ticket), 315 jhammond (see comments within the ticket) Action: please update the ticket's resolution - To be discussed due to Japan-voting-rule: - Ticket 273 chaarawi - FT tickets 323 bosilca , 326 bosilca, 327 bosilca i.e. should also have a slot in the agenda (Not within report/14:) - Already withdrawn because the chapter authors promised to convert the ticket content into a ticket-0-change which will be presented in the July 2012 meeting: Tickets 216 , 267, 268 Action: Chapter authors may mention these tickets when reading their ticket-0-changes - Tickets that should stay in "MPI-2.2 errata": - #171 change MPI_C_BOOL external32 size to 1 byte (passed) And following tickets, because they correct the C++ interface which will be removed in MPI-3.0 - #166, Item 1, (needs single-and-only-1-vote in July 2012) - #192 (needs 2nd vote in July 2012) - #202 (needs single-and-only-1-vote in July 2012) - The other MPI-2.2-errata tickets need not to go on the errata page. It is okay to use them only for MPI-3.0. Action: - to be checked, whether the MUST go to the MPI-2.2 errata page by a reasonable reason, - otherwise "Version" should be modified from "MPI-2.2-errata" into "MPI-3.0" . Best regards Rolf ----- Original Message -----
From: "Jeff Squyres" <[email protected]> To: "Main MPI Forum mailing list" <[email protected]> Sent: Wednesday, June 20, 2012 5:34:23 PM Subject: Re: [Mpi-forum] Many MPI-tickets: Actions needed before July meeting Thanks Rolf (and I could have sworn I had updated mine -- doh!).
Since begging hasn't worked :-), I advanced all tickets that were voted on in Japan (both passed and failed tickets).
Reflecting much of what Rolf listed below, I created the following reports to help both chapter and ticket authors (also available under the "View tickets" tab in the top right of Trac):
- MPI-3 tickets that need text committed https://svn.mpi-forum.org/trac/mpi-forum-web/report/11
- MPI-3 tickets that need PDF reviews https://svn.mpi-forum.org/trac/mpi-forum-web/report/12
- MPI-3 tickets that are fully complete (i.e., committed and reviewed) https://svn.mpi-forum.org/trac/mpi-forum-web/report/13
- MPI-3 tickets that need to be discarded (i.e., moved to MPI <next> or withdrawn) https://svn.mpi-forum.org/trac/mpi-forum-web/report/14
-- Dr. Rolf Rabenseifner . . . . . . . . . .. email [email protected] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . (Office: Allmandring 30)
participants (1)
Rolf Rabenseifner
