Re: [Mpi-forum] another request for iaccept
JeffH, You might have been misled by the date on the ticket. This is an old (stale ticket) that was imported from TRAC when we moved to github. Thanks for pointing it out. That being said, your point remains valid, we should not force the users to use complicated solution based on threads doing blocking MPI calls just to cope with our inability to timely converge toward a reasonable non-blocking solution. George. On Fri, Feb 26, 2016 at 12:55 AM, Jeff Hammond <[email protected]> wrote:
On Thu, Feb 25, 2016 at 3:40 PM, Balaji, Pavan <[email protected]> wrote:
On Feb 25, 2016, at 2:48 PM, Jeff Squyres (jsquyres) < [email protected]> wrote:
1) Low overhead (justifies Isend/Irecv etc.) 2) Scarcity of threads (e.g., the BlueGene/L rationale)
Agreed -- neither of these are likely important for an iconnect/iaccept scenario.
I would disagree. This is *always* a problem since adding threads hurts other operations in the application. For example, if I need to use a nonblocking iconnect/iaccept in one small part of the application, it now means that every fine-grained PUT/GET/ISEND operation in the rest of the application would be more expensive.
Does making a blocking operation nonblocking via threads not require MPI_THREAD_MULTIPLE, which Open-MPI does not support ( https://github.com/open-mpi/ompi/issues/157) more than 12 years after its standardization? It seems that a significant fraction of the MPI Forum does not believe that thread-safe MPI calls are important, so how can anyone argue that threads are a solution to this problem?
Jeff
But I do think the progression overlap with application threads can be quite useful.
Right. Having a nonblocking operation is not about performance improvements, but that I can now stick in a request into an existing Waitall or Testany in my application. FWIW, at least one of our applications uses NBC I/O in exactly this way. Before MPI-3.1, they had to do an event-based model (with Testany) for everything else and a blocking call for I/O, which was inconvenient and hurts performance.
There are some interactions with multiple-competion routines and limitations in the generalized requests, but fixing generalized requests would be a more general solution.
Agreed -- fixing generalized requests has been a white whale for quite a while now.
There are technical reasons for why this was not easily fixed, unlike iconnect/iaccept where people are bandwidth limited to put together a proposal.
-- Pavan
_______________________________________________ mpi-forum mailing list [email protected] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum
-- Jeff Hammond [email protected] http://jeffhammond.github.io/
participants (1)
George Bosilca
