Votes at MPI-Forum meeting Feb 1+8, 2023 (related to Terms and Topologies)
Dear MPI forum members, dear Wesley, I would like to have the following issues (and their PRs) voted. They all had reading (or remembering reading) at the Dec. 2022 meeting. ================ Updating Side Document Function Table (SDFT) ============== 1st vote SDFT-17 SDFT - RMA section in Annex A.2 to be added Rolf 1st vote SDFT-5 SDFT - MPI_Comm_set_info is missing from function table Rolf 1st vote SDFT-7 SDFT - Why are MPI_COMM_CREATE, MPI_COMM_DUP etc not freeing? Rolf 1st vote SDFT-8 SDFT - Superfluous remark 4 on process topology functions Rolf 1st vote SDFT-10 SDFT - Handle special case of MPI_WAIT on a cancelled request Rolf 1st vote SDFT-11 SDFT - The column Procedure should be "Procedure Call" Rolf ================== 1st votes related to MPI 4.1 ============== 1st vote 641 Including Annex A.2 back into the standard Rolf 1st vote 493 Issue N - Progress-Section in terms-2.tex Rolf 1st vote 471 Fix Incorrect Usage of Rank/Task/etc. in Terms Chapter Rolf 1st vote 565 Refer to Fortran 2018 instead of 2008+TS Rolf+Jeff H. 1st vote 644 Update 'Process Topology' chapter title to use 'MPI process' Christoph ================== 2nd votes related to MPI 4.1 ============== 2nd vote 468 Issue K - MPI_REQUEST_GET_STATUS with same progress as MPI_TEST Rolf @Wesley, I already updated the milestone to Feb 2023. After this email, I'll update the flag from "Scheduled reading" to "scheduled vote". ================== 1st votes related to MPI 4.1 ================= == only if it will not be handled as a chapter committee change == == current status: chapter committee voting is done and on the way to the merge == 1st vote 649 Topology - use of MPI process where necessary Christoph 1st vote 650 Topology improvement around the term virtual topology Christoph 1st vote 651 Topology typos and smaller text improvements Christoph ================== Voted but still to be merged =============== == If there is another vote needed, then this is hereby also announced: == errata-voted 589 Issues with Partitioned Communication Example-4.4 (reread with No No) Christoph Best regards Rolf -- Dr. Rolf Rabenseifner . . . . . . . . . .. . . [email protected] . High Performance Computing Center (HLRS) . . . ++49(0)711/685-65530 . University of Stuttgart . . . . . . www.hlrs.de/people/rabenseifner . Nobelstr. 19, 70569 Stuttgart, Germany
participants (1)
Rolf Rabenseifner
