Re: [Mpi-forum] Question about MPI_Info set on communicators
Forget the use-shared-memory hint; it was just an example. Substitute in any "foo" info key hint name(assuming the implementation understands the "foo" key hint name); the original question remains: what should the value be if the implementation cannot provide the requested hint? - "yes" because the user asked for it (i.e., that's the hint, regardless of what the implementation dos with it) - "no" because the implementation could not provide it - no "foo" key at all because the implementation did not use the hint Sent from my phone. No type good. On Feb 16, 2016, at 2:16 PM, Jeff Hammond <[email protected]<mailto:[email protected]>> wrote: On Tue, Feb 16, 2016 at 6:50 AM, Jeff Squyres (jsquyres) <[email protected]<mailto:[email protected]>> wrote: Jim -- Based on your answer, I'm now a bit confused. I now need to back up from my original question and clarify what MPI_COMM_INFO_GET is supposed to return in this scenario: ----- MPI_Info_set(myinfo, "use_shared_memory", "yes"); MPI_Comm_set_info(comm, my info); // MPI implementation recognizes the "use_shared_memory" hint, but is // unable to use shared memory with this communicator MPI_Comm_get_info(comm, myinfo_returned); ----- What value is in myinfo_returned for use_shared_memory? MPI 3.1 6.4.4 p250 says: "MPI_COMM_GET_INFO returns a new info object containing the hints of the communicator associated with comm. The current setting of all hints actually used by the system related to this communicator is returned in info_used." "...all hints actually used by the system..." is actually a bit ambiguous. In this case, "use_shared_memory" is *recognized* by the MPI implementation. But it wasn't able to be *used* (e.g., because no shared memory was available). So is the value in info_used supposed to be: How does it know how much shared memory is required? I don't see any reason for MPI_Comm_set_info to fail on account of lack of shared memory. If zero bytes of shared memory are available, how does MPI_Comm_set_info know that this is not enough when the user actually needs? 1. The user's requested hint (i.e., "yes"), or I'm changing my answer to this one, in this case. For MPI_Alloc_mem and MPI_Win_allocate(_shared), my answer will be different. The only reasonable behavior is for MPI_Comm_set_info to succeed and set "use_shared_memory"="yes". Subsequent operations may behave differently depending on how much shared memory is available. I would expect the user to probe that using MPI_T. Jeff 2. What MPI is actually using (i.e., "no"), or 3. Since this hint wasn't "used" by the system, then the "use_shared_memory" key shouldn't be returned in info_used ? Indeed, one could make the argument that MPI_COMM_GET_INFO is supposed to return exactly the value(s) that the user requested (if it is *recognized* by the implementation), and MPI_T pvars and/or cvars should be queried to obtain the values indicating what the implementation chose to do with those hints. Thoughts? On February 15, 2016 at 8:25:44 PM, Jim Dinan ([email protected]<mailto:[email protected]>) wrote:
"Same" should mean that these call sequences produce the same newcomm, right?
MPI_Comm_get_info(comm, myinfo_returned); MPI_Comm_dup_with_info(comm, &newcomm, myinfo_returned);
and
MPI_Comm_dup(comm, &newcomm);
I think this is an argument for "no".
I'm not sure if the question is asking whether the MPI implementation can change communicator info values dynamically. I'm not sure the spec actually addresses that possibility. If this is allowed, newcomm would still only get "yes" if the implementation had also toggled the info key on the parent communicator.
~Jim.
On Mon, Feb 15, 2016 at 5:34 PM, Jeff Squyres (jsquyres) > > wrote:
This question has come up in the Open MPI community:
----- MPI_Info_set(myinfo, "use_shared_memory", "yes"); MPI_Comm_set_info(comm, myinfo); MPI_Comm_get_info(comm, myinfo_returned); // Assume here that there was not enough shared memory available to use shared-memory for // communication on this comm, so MPI_Info_get() tells us that use_shared_memory is "no".
// ...time passes, and now assume there is more shared-memory available MPI_Comm_dup_with_info(comm, &newcom); MPI_comm_get_info(newcom, myinfo_returned); -----
Should newcom have "use_shared_memory" set to "yes" or "no"?
Arguments for "yes": - the user originally asked for "yes" - now there is shared memory available
Arguments for "no": - the current value for "used_shared_memory" on the parent communicator is "no"
Which should it be?
MPI-3.1 6.4.2 p238 says:
"...Returns in newcomer a new communicator with the same group or groups, same topology, same info hints, any copied cached information, but a new context (see Section 6.7.1)."
So the specific question here is: what exactly does "Same info hints" mean? The user-specific hint, or the current value of the hint?
-- Jeff Squyres [email protected]<mailto:[email protected]> For corporate legal information go to: http://www.cisco.com/web/about/doing_business/legal/cri/ _______________________________________________ mpi-forum mailing list [email protected]<mailto:[email protected]> http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum
-- Jeff Squyres [email protected]<mailto:[email protected]> For corporate legal information go to: http://www.cisco.com/web/about/doing_business/legal/cri/ _______________________________________________ mpi-forum mailing list [email protected]<mailto:[email protected]> http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum -- Jeff Hammond [email protected]<mailto:[email protected]> http://jeffhammond.github.io/ Received: from xch-rtp-019.cisco.com<http://xch-rtp-019.cisco.com> (64.101.220.159) by xch-rcd-019.cisco.com<http://xch-rcd-019.cisco.com> (173.37.102.29) with Microsoft SMTP Server (TLS) id 15.0.1104.5 via Mailbox Transport; Tue, 16 Feb 2016 13:16:12 -0600 Received: from xch-rtp-004.cisco.com<http://xch-rtp-004.cisco.com> (64.101.220.144) by XCH-RTP-019.cisco.com<http://xch-rtp-019.cisco.com> (64.101.220.159) with Microsoft SMTP Server (TLS) id 15.0.1104.5; Tue, 16 Feb 2016 14:16:11 -0500 Received: from rcdn-iport-1.cisco.com<http://rcdn-iport-1.cisco.com> (173.37.86.72) by mail.cisco.com<http://mail.cisco.com> (64.101.220.144) with Microsoft SMTP Server (TLS) id 15.0.1104.5 via Frontend Transport; Tue, 16 Feb 2016 14:16:11 -0500 Received: from rcdn-core-5.cisco.com<http://rcdn-core-5.cisco.com> ([173.37.93.156]) by rcdn-iport-1.cisco.com<http://rcdn-iport-1.cisco.com> with ESMTP/TLS/DHE-RSA-AES256-GCM-SHA384; 16 Feb 2016 19:16:09 +0000 Received: from alln-inbound-e.cisco.com<http://alln-inbound-e.cisco.com> (alln-inbound-e.cisco.com<http://alln-inbound-e.cisco.com> [173.37.147.235]) by rcdn-core-5.cisco.com<http://rcdn-core-5.cisco.com> (8.14.5/8.14.5) with ESMTP id u1GJG9s3016172; Tue, 16 Feb 2016 19:16:10 GMT Received-SPF: None (alln-inbound-e.cisco.com<http://alln-inbound-e.cisco.com>: no sender authenticity information available from domain of [email protected]<mailto:[email protected]>) identity=mailfrom; client-ip=129.79.39.208; receiver=alln-inbound-e.cisco.com<http://alln-inbound-e.cisco.com>; envelope-from="[email protected]<mailto:[email protected]>"; x-sender="[email protected]<mailto:[email protected]>"; x-conformance=spf_only Received-SPF: None (alln-inbound-e.cisco.com<http://alln-inbound-e.cisco.com>: no sender authenticity information available from domain of [email protected]<mailto:[email protected]>) identity=helo; client-ip=129.79.39.208; receiver=alln-inbound-e.cisco.com<http://alln-inbound-e.cisco.com>; envelope-from="[email protected]<mailto:[email protected]>"; x-sender="[email protected]<mailto:[email protected]>"; x-conformance=spf_only Authentication-Results: alln-inbound-e.cisco.com<http://alln-inbound-e.cisco.com>; spf=None [email protected]<mailto:[email protected]>; spf=None [email protected]<mailto:[email protected]>; dkim=hardfail (body hash did not verify [final]) [email protected]<mailto:[email protected]>; dkim=hardfail (body hash did not verify [final]) [email protected]<mailto:[email protected]>; dmarc=fail (p=none dis=none) d=gmail.com<http://gmail.com> X-from-outside-Cisco: 129.79.39.208 IronPort-PHdr: =?us-ascii?q?9a23=3A3koMHBVMN/yf5qkGiy0ZpEKb+w/V8LGtZVwlr6E/?= =?us-ascii?q?grcLSJyIuqrYYRSBt8tkgFKBZ4jH8fUM07OQ6PC/HzBbqs/Y4TgrS99laVwssY?= =?us-ascii?q?0uhQsuAcqIWwXQDcXBSGgEJvlET0Jv5HqhMEJYS47UblzWpWCuv3ZJQk2sfTR8?= =?us-ascii?q?Kum9IIPOlcP/j7n0oM2MJVkTz2PkMPtbF1afk0b4joEum4xsK6I8mFPig0BjXK?= =?us-ascii?q?Bo/15uPk+ZhB3m5829r9ZJ+iVUvO89pYYbCf2pN4xxd7FTDSwnPmYp/4Wr8ECb?= =?us-ascii?q?FUrcrkYaSXgcxxpUHxCXq1b+X4ztqW3/rus41i6AIMiwSqo7HjGr7qNuQRmvjz?= =?us-ascii?q?8bNjk/6yfchc03ibpa5RymvQF6kLPSe5yfYf93f6fBeoEfXWsEUMFLSikEGI6l?= =?us-ascii?q?coYUE8IFPP1EtM/4v1pLoxykGAzqA/ngnSRVjH371rFvzuI6DAvd1xYhFd9djH?= =?us-ascii?q?OBidz0Mu83acH94q7S0DCLavpX3Tb758DMcws96aWJRbM1f83L1EwHEwLekk7W?= =?us-ascii?q?rJTkej2SzPkI9W+B4Lwzb++3j38brFRUqzmpjuIUq8HngZgIzxjB/CR9wYA6bd?= =?us-ascii?q?m5U1IzNdu8Ed5esDuHMqNyQ9g+WCdtoCd/xLocpJv9ezIFnscJ3RnaPt6KfYbA?= =?us-ascii?q?whvmUeGXLX8shn9rdvSkjBe/90Ot4uL5X8iwll1Nq3wWwZH3qnkR2kmLuYC8Qf?= =?us-ascii?q?xn8xLkgG7X2g=3D=3D?= X-IronPort-Anti-Spam-Filtered: true X-IronPort-Anti-Spam-Result: =?us-ascii?q?A0GWAACSdMNWmdAnT4FeBhMBAQEBDwEBA?= =?us-ascii?q?QEGAQEBAYNSRyYGhDWkGIFJI4UhilQBDYEmGyIbAQmHJD8UAQEBAQEBAQECDgE?= =?us-ascii?q?BAQEBCAsJCSEugi0JATgGBAEBBAEBAQEBAQEBASMBAQEBAQEBAQEBAQEBAQEBA?= =?us-ascii?q?QEBAQEBAQEBAQEBAQEBAQEBAQYCDR4PFgEaAQEBAQIBAQEBDxEdAQUKDBIMAgE?= =?us-ascii?q?BAQECBgEBBQULDRUNBAQCAgMBGgMBAQUECAEFARwGEwUPDodiAQMKCA6eJIExP?= =?us-ascii?q?jGLNIFpgleBYINOChknDVGECAEBAQEBAQEDAQEBAQEVAQUKBIUQhSiCN4I6gkG?= =?us-ascii?q?BOgWOHIhCIYENhEaFH3SBc4ImjE1EhjuGBREePwNaDwEBgkEcgWlJAYhbAQEB?= X-IPAS-Result: =?us-ascii?q?A0GWAACSdMNWmdAnT4FeBhMBAQEBDwEBAQEGAQEBAYNSRyY?= =?us-ascii?q?GhDWkGIFJI4UhilQBDYEmGyIbAQmHJD8UAQEBAQEBAQECDgEBAQEBCAsJCSEug?= =?us-ascii?q?i0JATgGBAEBBAEBAQEBAQEBASMBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQE?= =?us-ascii?q?BAQEBAQEBAQYCDR4PFgEaAQEBAQIBAQEBDxEdAQUKDBIMAgEBAQECBgEBBQULD?= =?us-ascii?q?RUNBAQCAgMBGgMBAQUECAEFARwGEwUPDodiAQMKCA6eJIExPjGLNIFpgleBYIN?= =?us-ascii?q?OChknDVGECAEBAQEBAQEDAQEBAQEVAQUKBIUQhSiCN4I6gkGBOgWOHIhCIYENh?= =?us-ascii?q?EaFH3SBc4ImjE1EhjuGBREePwNaDwEBgkEcgWlJAYhbAQEB?= X-IronPort-AV: E=Sophos;i="5.22,456,1449532800"; d="scan'208,217";a="194686767" X-Amp-Result: Clean X-Amp-File-Uploaded: False X-IronPort-Outbreak-Status: No, level 0, Unknown - Unknown Received: from crest.iu.edu<http://crest.iu.edu> (HELO lion.crest.iu.edu<http://lion.crest.iu.edu>) ([129.79.39.208]) by alln-inbound-e.cisco.com<http://alln-inbound-e.cisco.com> with ESMTP; 16 Feb 2016 19:16:08 +0000 Received: by lion.crest.iu.edu<http://lion.crest.iu.edu> (Postfix, from userid 493) id 8E3BD260779; Tue, 16 Feb 2016 14:16:08 -0500 (EST) X-Spam-Checker-Version: SpamAssassin 3.3.1 (2010-03-16) on lion.crest.iu.edu<http://lion.crest.iu.edu> X-Spam-Level: X-Spam-Status: No, score=-2.5 required=5.0 tests=BAYES_00,DKIM_ADSP_CUSTOM_MED, DKIM_SIGNED,FREEMAIL_FROM,HTML_MESSAGE,RCVD_IN_DNSWL_LOW,T_DKIM_INVALID autolearn=unavailable version=3.3.1 Received: from crest.iu.edu<http://crest.iu.edu> (localhost [127.0.0.1]) by lion.crest.iu.edu<http://lion.crest.iu.edu> (Postfix) with ESMTP id 220D12608A4; Tue, 16 Feb 2016 14:16:06 -0500 (EST) X-Original-To: [email protected]<mailto:[email protected]> Delivered-To: [email protected]<mailto:[email protected]> Received: by lion.crest.iu.edu<http://lion.crest.iu.edu> (Postfix, from userid 493) id C3B4326079D; Tue, 16 Feb 2016 14:16:04 -0500 (EST) Received: from mail-ob0-f177.google.com<http://mail-ob0-f177.google.com> (mail-ob0-f177.google.com<http://mail-ob0-f177.google.com> [209.85.214.177]) by lion.crest.iu.edu<http://lion.crest.iu.edu> (Postfix) with ESMTP id 0CF2D260779 for <[email protected]<mailto:[email protected]>>; Tue, 16 Feb 2016 14:16:04 -0500 (EST) Received: by mail-ob0-f177.google.com<http://mail-ob0-f177.google.com> with SMTP id gc3so172260092obb.3 for <[email protected]<mailto:[email protected]>>; Tue, 16 Feb 2016 11:16:04 -0800 (PST) DKIM-Signature: v=1; a=rsa-sha256; c=relaxed/relaxed; d=gmail.com<http://gmail.com>; s=20120113; h=mime-version:in-reply-to:references:from:date:message-id:subject:to :cc:content-type; bh=KEQt98rYsl7/LCgT0QeppyTHXsG6OQ4HlXJPO5cSx6g=; b=ZjDP3X63meN3mEnca6KBi6EBk9pci2/5zBnyPW9jXQQoUqv8q6f6xnTqfe6kAJIANL BrdVhlIVnOzqmSuQluiCJ+wif1RFZsh9I1q2Rc3JmktVNu9mlkj8GABpnIV76JsN3+Nh TE4bBFG6d/yEpONEhBmHYb0M9CPNfGwjyHcU/iwIIdp/NJ2aCFQd2DT3iTjubsfcQ9YC NtZrfSHLBJ7W7uXA4xh502P+h5n3Zw4cK5T3jvnX2dS8Ya7q2RgvaB9hZ0O573Z8KPGX NckpbsAI93Z+2WOYKjYD+RahNtTisu/3pg/YUYPp32fT3ClY6+y/lCvz+v3MAbEr5QwM i3hw== X-Google-DKIM-Signature: v=1; a=rsa-sha256; c=relaxed/relaxed; d=1e100.net<http://1e100.net>; s=20130820; h=x-gm-message-state:mime-version:in-reply-to:references:from:date :message-id:subject:to:cc:content-type; bh=KEQt98rYsl7/LCgT0QeppyTHXsG6OQ4HlXJPO5cSx6g=; b=f0LWIMla+RNtd30P6me/Due6bIOkINSUFd72cgxq4quY2u5vwQ2vGAidpQmR6GxaVX Va0CxATjTEdQthxE645JcglMkoa3Qr3/NyZSn3NdxXcGBNSt4O21JWy2JMhyrRq/ZOdU ZUUWR3E/0sndIX6N2CVn8TmcDe+V6oK5seuP1/s0DBArBabm7UvX8i4WpZ87Rbro8ZZz bGaz6H5r2BNGfvqTs/dJpFgngDtZmQhfs9bBQqTAZnZF2BT0Hr5mYXslbpVpeeFP10ZB js+ZIBksZ3r0nNfSp2PBSI80LJmHIYwzv1Uo4Dv+qMXMS/r5JI3ZDgdYBaajWn3Ed4Hg Wurw== X-Gm-Message-State: AG10YORIYeBZwr2gNbdXFNnEMipCzyF4XmxjsJ5xCcL1SPpPAt3FYho5f7woQq6eyHH8eU3A5UOCDzVNozyUTg== X-Received: by 10.182.81.227 with SMTP id d3mr8859463oby.78.1455650163481; Tue, 16 Feb 2016 11:16:03 -0800 (PST) Received: by 10.76.160.99 with HTTP; Tue, 16 Feb 2016 11:15:43 -0800 (PST) In-Reply-To: <etPan.56c3373a.c1948d0.7e1e@JSQUYRES-M-H05C> References: <etPan.56c25272.501e2675.7e1e@JSQUYRES-M-H05C> <CAOoEU4Hp-m7RVfAD42ueQLcryUyAP4zY_D-prbHHyPwBdi=6Hg@mail.gmail.com<mailto:CAOoEU4Hp-m7RVfAD42ueQLcryUyAP4zY_D-prbHHyPwBdi=6Hg@mail.gmail.com>> <etPan.56c3373a.c1948d0.7e1e@JSQUYRES-M-H05C> From: Jeff Hammond <[email protected]<mailto:[email protected]>> Date: Tue, 16 Feb 2016 11:15:43 -0800 Message-ID: <CAGKz=u+pZtXqgiNV+tgCiv+tttMBUREc6CMYG=BVcC7eqYXcpw@mail.gmail.com<mailto:CAGKz=u+pZtXqgiNV+tgCiv+tttMBUREc6CMYG=BVcC7eqYXcpw@mail.gmail.com>> To: Main MPI Forum mailing list <[email protected]<mailto:[email protected]>> Subject: Re: [Mpi-forum] Question about MPI_Info set on communicators X-BeenThere: [email protected]<mailto:[email protected]> X-Mailman-Version: 2.1.15 Precedence: list Reply-To: Main MPI Forum mailing list <[email protected]<mailto:[email protected]>> List-Id: Main MPI Forum mailing list <mpi-forum.lists.mpi-forum.org<http://mpi-forum.lists.mpi-forum.org>> List-Unsubscribe: <http://lists.mpi-forum.org/mailman/options.cgi/mpi-forum>, <mailto:[email protected]?subject=unsubscribe> List-Archive: <http://lists.mpi-forum.org/MailArchives/mpi-forum/> List-Post: <mailto:[email protected]> List-Help: <mailto:[email protected]?subject=help> List-Subscribe: <http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum>, <mailto:[email protected]?subject=subscribe> Content-Type: multipart/mixed; boundary="===============5365574427901088839==" Errors-To: [email protected]<mailto:[email protected]> Sender: mpi-forum <[email protected]<mailto:[email protected]>> Return-Path: [email protected]<mailto:[email protected]> X-MS-Exchange-Organization-AuthSource: XCH-RTP-004.cisco.com<http://xch-rtp-004.cisco.com> X-MS-Exchange-Organization-AuthAs: Internal X-MS-Exchange-Organization-AuthMechanism: 10 X-MS-Exchange-Organization-Network-Message-Id: b0530982-0953-4081-be2c-08d33705a182 X-MS-Exchange-Organization-AVStamp-Enterprise: 1.0 MIME-Version: 1.0 --===============5365574427901088839== Content-Type: multipart/alternative; boundary=047d7b2e4058e96442052be7f662 --047d7b2e4058e96442052be7f662 Content-Type: text/plain; charset=UTF-8 On Tue, Feb 16, 2016 at 6:50 AM, Jeff Squyres (jsquyres) <[email protected]<mailto:[email protected]> wrote: Jim -- Based on your answer, I'm now a bit confused. I now need to back up from my original question and clarify what MPI_COMM_INFO_GET is supposed to return in this scenario: ----- MPI_Info_set(myinfo, "use_shared_memory", "yes"); MPI_Comm_set_info(comm, my info); // MPI implementation recognizes the "use_shared_memory" hint, but is // unable to use shared memory with this communicator MPI_Comm_get_info(comm, myinfo_returned); ----- What value is in myinfo_returned for use_shared_memory? MPI 3.1 6.4.4 p250 says: "MPI_COMM_GET_INFO returns a new info object containing the hints of the communicator associated with comm. The current setting of all hints actually used by the system related to this communicator is returned in info_used." "...all hints actually used by the system..." is actually a bit ambiguous. In this case, "use_shared_memory" is *recognized* by the MPI implementation. But it wasn't able to be *used* (e.g., because no shared memory was available). So is the value in info_used supposed to be: How does it know how much shared memory is required? I don't see any reason for MPI_Comm_set_info to fail on account of lack of shared memory. If zero bytes of shared memory are available, how does MPI_Comm_set_info know that this is not enough when the user actually needs? 1. The user's requested hint (i.e., "yes"), or I'm changing my answer to this one, in this case. For MPI_Alloc_mem and MPI_Win_allocate(_shared), my answer will be different. The only reasonable behavior is for MPI_Comm_set_info to succeed and set "use_shared_memory"="yes". Subsequent operations may behave differently depending on how much shared memory is available. I would expect the user to probe that using MPI_T. Jeff 2. What MPI is actually using (i.e., "no"), or 3. Since this hint wasn't "used" by the system, then the "use_shared_memory" key shouldn't be returned in info_used ? Indeed, one could make the argument that MPI_COMM_GET_INFO is supposed to return exactly the value(s) that the user requested (if it is *recognized* by the implementation), and MPI_T pvars and/or cvars should be queried to obtain the values indicating what the implementation chose to do with those hints. Thoughts? On February 15, 2016 at 8:25:44 PM, Jim Dinan ([email protected]<mailto:[email protected]>) wrote: "Same" should mean that these call sequences produce the same newcomm, right? MPI_Comm_get_info(comm, myinfo_returned); MPI_Comm_dup_with_info(comm, &newcomm, myinfo_returned); and MPI_Comm_dup(comm, &newcomm); I think this is an argument for "no". I'm not sure if the question is asking whether the MPI implementation can change communicator info values dynamically. I'm not sure the spec actually addresses that possibility. If this is allowed, newcomm would still only get "yes" if the implementation had also toggled the info key on the parent communicator. ~Jim. On Mon, Feb 15, 2016 at 5:34 PM, Jeff Squyres (jsquyres) > > wrote: This question has come up in the Open MPI community: ----- MPI_Info_set(myinfo, "use_shared_memory", "yes"); MPI_Comm_set_info(comm, myinfo); MPI_Comm_get_info(comm, myinfo_returned); // Assume here that there was not enough shared memory available to use shared-memory for // communication on this comm, so MPI_Info_get() tells us that use_shared_memory is "no". // ...time passes, and now assume there is more shared-memory available MPI_Comm_dup_with_info(comm, &newcom); MPI_comm_get_info(newcom, myinfo_returned); ----- Should newcom have "use_shared_memory" set to "yes" or "no"? Arguments for "yes": - the user originally asked for "yes" - now there is shared memory available Arguments for "no": - the current value for "used_shared_memory" on the parent communicator is "no" Which should it be? MPI-3.1 6.4.2 p238 says: "...Returns in newcomer a new communicator with the same group or groups, same topology, same info hints, any copied cached information, but a new context (see Section 6.7.1)." So the specific question here is: what exactly does "Same info hints" mean? The user-specific hint, or the current value of the hint? -- Jeff Squyres [email protected]<mailto:[email protected]> For corporate legal information go to: http://www.cisco.com/web/about/doing_business/legal/cri/ _______________________________________________ mpi-forum mailing list [email protected]<mailto:[email protected]> http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum _______________________________________________ mpi-forum mailing list [email protected]<mailto:[email protected]> http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum -- Jeff Squyres [email protected]<mailto:[email protected]> For corporate legal information go to: http://www.cisco.com/web/about/doing_business/legal/cri/ _______________________________________________ mpi-forum mailing list [email protected]<mailto:[email protected]> http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum -- Jeff Hammond [email protected]<mailto:[email protected]> http://jeffhammond.github.io/ --047d7b2e4058e96442052be7f662 Content-Type: text/html; charset=UTF-8 Content-Transfer-Encoding: quoted-printable <meta http-equiv=3D"Content-Type" content=3D"text/html; charset=3Dutf-8"><d= iv dir=3D"ltr"><br><div class=3D"gmail_extra"><br><div class=3D"gmail_quote= ">On Tue, Feb 16, 2016 at 6:50 AM, Jeff Squyres (jsquyres) <span dir=3D"ltr= "><<a href=3D"mailto:[email protected]" target=3D"_blank">jsquyres@cisc= o.com<http://o.com></a>></span> wrote:<br><blockquote class=3D"gmail_quote" style=3D"m= argin:0px 0px 0px 0.8ex;border-left-width:1px;border-left-color:rgb(204,204= ,204);border-left-style:solid;padding-left:1ex">Jim --<br> <br> Based on your answer, I'm now a bit confused. I now need to back up f= rom my original question and clarify what MPI_COMM_INFO_GET is supposed to = return in this scenario:<br> <span class=3D""><br> -----<br> MPI_Info_set(myinfo, "use_shared_memory", "yes"); = <br> MPI_Comm_set_info(comm, my info);<br> </span>// MPI implementation recognizes the "use_shared_memory" h= int, but is<br> // unable to use shared memory with this communicator<br> MPI_Comm_get_info(comm, myinfo_returned); <br> -----<br> <br> What value is in myinfo_returned for use_shared_memory?<br> <br> MPI 3.1 6.4.4 p250 says:<br> <br> "MPI_COMM_GET_INFO returns a new info object containing the hints of t= he communicator associated with comm. The current setting of all hints actu= ally used by the system related to this communicator is returned in info_us= ed."<br> <br> "...all hints actually used by the system..." is actually a bit a= mbiguous.<br> <br> In this case, "use_shared_memory" is *recognized* by the MPI impl= ementation. But it wasn't able to be *used* (e.g., because no shared = memory was available). So is the value in info_used supposed to = be:<br> <br></blockquote><div><br></div><div>How does it know how much shared memor= y is required? I don't see any reason for MPI_Comm_set_info to fail o= n account of lack of shared memory. If zero bytes of shared memory ar= e available, how does MPI_Comm_set_info know that this is not enough when t= he user actually needs?</div><div> </div><blockquote class=3D"gmail_qu= ote" style=3D"margin:0px 0px 0px 0.8ex;border-left-width:1px;border-left-co= lor:rgb(204,204,204);border-left-style:solid;padding-left:1ex"> 1. The user's requested hint (i.e., "yes"), or<br></blockquote><d= iv><br></div><div>I'm changing my answer to this one, in this case. F= or MPI_Alloc_mem and MPI_Win_allocate(_shared), my answer will be different= .</div><div><br></div><div>The only reasonable behavior is for MPI_Comm_set= _info to succeed and set "use_shared_memory"=3D"yes".&n= bsp; Subsequent operations may behave differently depending on how much sha= red memory is available. I would expect the user to probe that using = MPI_T.</div><div><br></div><div>Jeff</div><div> </div><blockquote clas= s=3D"gmail_quote" style=3D"margin:0px 0px 0px 0.8ex;border-left-width:1px;b= order-left-color:rgb(204,204,204);border-left-style:solid;padding-left:1ex"= 2. What MPI is actually using (i.e., "no"), or<br> 3. Since this hint wasn't "used" by the system, then the "us= e_shared_memory" key shouldn't be returned in info_used<br> <br> ?<br> <br> Indeed, one could make the argument that MPI_COMM_GET_INFO is supposed to r= eturn exactly the value(s) that the user requested (if it is *recognized* b= y the implementation), and MPI_T pvars and/or cvars should be queried to ob= tain the values indicating what the implementation chose to do with those h= ints.<br> <br> Thoughts?<br> <span class=3D"im"><br> <br> <br> On February 15, 2016 at 8:25:44 PM, Jim Dinan (<a href=3D"mailto:james.dina= [email protected]<mailto:[email protected]>">[email protected]<mailto:[email protected]></a>) wrote:<br> > "Same" should mean that these call sequences produce the sam= e newcomm,<br> > right?<br> ><br> > MPI_Comm_get_info(comm, myinfo_returned);<br> > MPI_Comm_dup_with_info(comm, &newcomm, myinfo_returned);<br> ><br> > and<br> ><br> > MPI_Comm_dup(comm, &newcomm);<br> ><br> > I think this is an argument for "no".<br> ><br> > I'm not sure if the question is asking whether the MPI implementation = can<br> > change communicator info values dynamically. I'm not sure the spec<br> > actually addresses that possibility. If this is allowed, newcomm would= <br> > still only get "yes" if the implementation had also toggled = the info key on<br> > the parent communicator.<br> ><br> > ~Jim.<br> ><br> </span><div class=3D""><div class=3D"h5">> On Mon, Feb 15, 2016 at 5:34 = PM, Jeff Squyres (jsquyres) > > wrote:<br> ><br> > > This question has come up in the Open MPI community:<br> > ><br> > > -----<br> > > MPI_Info_set(myinfo, "use_shared_memory", "yes&quo= t;);<br> > > MPI_Comm_set_info(comm, myinfo);<br> > > MPI_Comm_get_info(comm, myinfo_returned);<br> > > // Assume here that there was not enough shared memory available = to use<br> > > shared-memory for<br> > > // communication on this comm, so MPI_Info_get() tells us that<br= > > use_shared_memory is "no".<br> > ><br> > > // ...time passes, and now assume there is more shared-memory ava= ilable<br> > > MPI_Comm_dup_with_info(comm, &newcom);<br> > > MPI_comm_get_info(newcom, myinfo_returned);<br> > > -----<br> > ><br> > > Should newcom have "use_shared_memory" set to "yes= " or "no"?<br> > ><br> > > Arguments for "yes":<br> > > - the user originally asked for "yes"<br> > > - now there is shared memory available<br> > ><br> > > Arguments for "no":<br> > > - the current value for "used_shared_memory" on the par= ent communicator is<br> > > "no"<br> > ><br> > > Which should it be?<br> > ><br> > > MPI-3.1 6.4.2 p238 says:<br> > ><br> > > "...Returns in newcomer a new communicator with the same gro= up or groups,<br> > > same topology, same info hints, any copied cached information, bu= t a new<br> > > context (see Section 6.7.1)."<br> > ><br> > > So the specific question here is: what exactly does "Same in= fo hints"<br> > > mean? The user-specific hint, or the current value of the hint?<b= r> > ><br> > > --<br> > > Jeff Squyres<br> > > <a href=3D"mailto:[email protected]">[email protected]<mailto:[email protected]></a><br> > > For corporate legal information go to:<br> > > <a href=3D"http://www.cisco.com/web/about/doing_business/legal/cr= i/" rel=3D"noreferrer" target=3D"_blank">http://www.cisco.com/web/about/doi= ng_business/legal/cri/</a><br> > > _______________________________________________<br> > > mpi-forum mailing list<br> > > <a href=3D"mailto:[email protected]">mpi-forum@lists.= mpi-forum.org<http://mpi-forum.org></a><br> > > <a href=3D"http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-fo= rum" rel=3D"noreferrer" target=3D"_blank">http://lists.mpi-forum.org/mailma= n/listinfo.cgi/mpi-forum</a><br> > _______________________________________________<br> > mpi-forum mailing list<br> > <a href=3D"mailto:[email protected]">[email protected]<mailto:[email protected]>-f= orum.org<http://orum.org></a><br> > <a href=3D"http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum" = rel=3D"noreferrer" target=3D"_blank">http://lists.mpi-forum.org/mailman/lis= tinfo.cgi/mpi-forum</a><br> <br> --<br> Jeff Squyres<br> <a href=3D"mailto:[email protected]">[email protected]<mailto:[email protected]></a><br> For corporate legal information go to: <a href=3D"http://www.cisco.com/web/= about/doing_business/legal/cri/" rel=3D"noreferrer" target=3D"_blank">http:= //www.cisco.com/web/about/doing_business/legal/cri/<http://www.cisco.com/web/about/doing_business/legal/cri/></a><br> _______________________________________________<br> mpi-forum mailing list<br> <a href=3D"mailto:[email protected]">[email protected]<mailto:[email protected]>-forum.= org</a><br> <a href=3D"http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum" rel= =3D"noreferrer" target=3D"_blank">http://lists.mpi-forum.org/mailman/listin= fo.cgi/mpi-forum</a></div></div></blockquote></div><br><br clear=3D"all"><d= iv><br></div>-- <br><div class=3D"gmail_signature">Jeff Hammond<br><a href= =3D"mailto:[email protected]" target=3D"_blank">[email protected]<mailto:[email protected]>= </a><br><a href=3D"http://jeffhammond.github.io/" target=3D"_blank">http://= jeffhammond.github.io/<http://jeffhammond.github.io/></a></div> </div></div> --047d7b2e4058e96442052be7f662-- --===============5365574427901088839== Content-Type: text/plain; charset="us-ascii" Content-Transfer-Encoding: 7bit Content-Disposition: inline _______________________________________________ mpi-forum mailing list [email protected]<mailto:[email protected]> http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-forum --===============5365574427901088839==--
participants (1)
