Re: [Mpi-comments] Non blocking receive of unknown size
Alain, Regardless of what the standard says or how it is interpreted, your example can simply deadlock if rank 1 returns from MPI_Iprobe() before rank 0 calls MPI_Ssend(). Cheers, Gilles ----- Original Message ----- Hi, (text location provided w.r.t MPI 3.1 https://www.mpi-forum.org/docs/mpi-3.1/mpi31-report.pdf) a) In 3.2.4, page 29, there is a discussion regarding the size of the buffer and size of the actual message with an "advice to users" section stating that : "The MPI_PROBE function described in Section 3.8 can be used to receive messages of unknown length." b) There is no such discussion in 3.7.2 so one could assume (maybe too optimistically) that the same advice applies w.r.t. MPI_Iprobe. c) In 3.8.1. page 66 line 9 "The MPI implementation of MPI_PROBE and MPI_IPROBE needs to guarantee progress: [calling those functions, msg should arrive eventually if send and not intercepted]. d) The "Progress" note in 3.7.4, illustrated by example 3.14, seems to indicate that a synchronous send can not be blocked if a recv has been posted regardless of the completion of that receive. But I could not find anything explicitly stating that MPI_Iprobe would initiate a receive the way MPI_Irecv does. That is, a slightly modified 3.14 example: CALL MPI_COMM_RANK(comm, rank, ierr) IF (RANK.EQ.0) THEN CALL MPI_SSEND(a, n, MPI_REAL, 1, 0, comm, ierr) CALL MPI_SEND(b, 1, MPI_REAL, 1, 1, comm, ierr) ELSE IF (rank.EQ.1) THEN CALL MPI_IPROBE(0, 0, comm, flag, status1, ierr) CALL MPI_RECV(b, 1, MPI_REAL, 0, 1, comm, status2, ierr) ... extract size info from status1 once available .... CALL MPI_IRECV(a, n, MPI_REAL, 0, 0, comm, r, ierr) CALL MPI_WAIT(r, status, ierr) END IF could deadlock in a correct MPI implementation. If I am correct in assuming that the MPI standard ask for the MPI_Iprobe to progress, it is not required to initiate. If true, it means the the point a) above does not extend to the non blocking communications and that the MPI does not provide a way to receive messages of unknown size whithout adding more opportunities for deadlocks. Am I correct ? and if yes, does that indicate that the discussion and advice of point a could be adapted and explicitly added for the non blocking case (point b). Thanks Alain
participants (1)
gilles@rist.or.jp
