non-collective version of MPI_File_set_view
I would like to suggest a non-collective version of MPI_File_set_view. The current MPI_File_set_view is defines as the following. MPI_FILE_SET_VIEW(fh, disp, etype, filetype, datarep, info) The last two arguments, datarep and info, may be necessary to be set collectively, but disp, etype, and filetype are only relevant to the calling process. It is not rare to see in today's MPI-IO programs the interleaved calls to collective and independent file read/write functions. For example, an application writes to multiple variables of different sizes. Large variables are partitioned among processes while small ones are read/written by rank 0 only. Accessing partitioned variables often uses filetype, such as MPI_Type_create_subarray, to set the view. Having only the collective version of MPI_File_set_view introduces a penalty for processes not accessing small variables in this scenario. To deal with this issue, PnetCDF opens the file twice, one with MPI_COMM_WORLD and the other with MPI_COMM_SELF, so the latter can be used to do independent I/O. A non-collective version of MPI_File_set_view can look similar, but without the last two arguments, datarep and info. An alternative is to create a new set of MPI I/O functions that add the three arguments disp, etype, and filetype. For example, a new write function corresponds to MPI_FILE_WRITE(fh, buf, count, datatype, status) will be MPI_FILE_WRITE_x(fh, buf, count, datatype, disp, etype, filetype, status) Wei-keng Liao
participants (1)
Wei-Keng Liao
