MPI-3.0 public draft, small request for clarification
Hello, I have a small, very technical comment on the formulation of MPI_WIN_FREE and MPI_WIN_TEST which might be of interest. I already came across this rather subtle point in the MPI standard v2.2 and it seems to me that the issue has not been clarified in the new MPI 3.0 draft. The problem is as follows: For a small test program I encountered a crash on some platforms (NEC-SX9) while everything runs smoothly elsewhere (Linux-gfortran). PROGRAM main USE MPI IMPLICIT NONE INTEGER, PARAMETER :: nfieldsize = 10 REAL :: send_buf(nfieldsize), recv_buf(nfieldsize) INTEGER :: win01, ierr, rank, sizeofreal, msg_size INTEGER :: group, togroup, fromgroup INTEGER(KIND=MPI_ADDRESS_KIND) :: bytesize INTEGER :: ranks(0:1) LOGICAL :: l_complete CALL MPI_INIT(ierr) CALL MPI_COMM_RANK(MPI_COMM_WORLD, rank, ierr) ! get own rank CALL MPI_TYPE_SIZE(MPI_REAL, sizeofreal, ierr) WRITE (*,*) "proc ", rank, ": creating window" bytesize = nfieldsize*sizeofreal CALL MPI_WIN_CREATE(recv_buf, bytesize, sizeofreal, MPI_INFO_NULL, MPI_COMM_WORLD, win01, ierr) send_buf = 1 recv_buf = 99 WRITE (*,*) "proc ", rank, ": Before: ", recv_buf ! build two new groups: one contains only the sender, the other ! group is the receiver CALL MPI_COMM_GROUP(MPI_COMM_WORLD, group, ierr) ranks = (/ 0, 1 /) CALL MPI_GROUP_INCL(group, 1, ranks(1:1), togroup, ierr) CALL MPI_GROUP_INCL(group, 1, ranks(0:0), fromgroup, ierr) IF (rank == 0) THEN CALL MPI_WIN_START(togroup, 0, win01, ierr) ELSE CALL MPI_WIN_POST(fromgroup, 0, win01, ierr) END IF IF (rank == 0) THEN WRITE (*,*) "proc ", rank, ": one-sided put" msg_size = 1 CALL MPI_PUT(send_buf, msg_size, MPI_REAL, 1, 0_MPI_ADDRESS_KIND, & & msg_size, MPI_REAL, win01, ierr) END IF WRITE (*,*) "proc ", rank, ": closing fence" IF (rank == 0) THEN CALL MPI_WIN_COMPLETE(win01, ierr) ELSE DO WRITE (*,*) "test..." ! check if RMA access completed: CALL MPI_WIN_TEST(win01, l_complete, ierr) IF (l_complete) EXIT END DO ! CALL MPI_WIN_WAIT(win01, ierr) ! <<< needed on some machines !!! END IF WRITE (*,*) "proc ", rank, ": After: ", recv_buf CALL MPI_WIN_FREE(win01, ierr) CALL MPI_BARRIER(MPI_COMM_WORLD, ierr) CALL MPI_FINALIZE(ierr) END PROGRAM main Our system vendor insisted that the MPI implementation is standard conforming and that the program crash was caused by the use of MPI_WIN_FREE. True enough, the standard says (11.2.5 Window Destruction): "MPI_WIN_FREE(win) can be invoked by a process only after it has completed its involvement in RMA communications on window win: e.g., the process has called MPI_WIN_FENCE, or called MPI_WIN_WAIT to match a previous call to MPI_WIN_POST or called MPI_WIN_COMPLETE to match a previous call to MPI_WIN_START or called MPI_WIN_UNLOCK to match a previous call to MPI_WIN_LOCK. [...]" I knew about this definition, however, the standard also contains the following passage (11.5.2, p.445): "The effect of return of MPI_WIN_TEST with flag = true is the same as the effect of a return of MPI_WIN_WAIT." Doesn't this mean that the above test program is correct? Perhaps one of these two passages in the standard needs clarification? Regards Florian
participants (1)
Florian Prill
