Re: [Mpi-22] Ticket #46: Addconst Keyword to the C bindings- implementation
Yes, you have to cast it away for Portals and Elan (http://web1.quadrics.com/downloads/documentation/ElanProgMan_5.3.pdf) Keith
-----Original Message----- From: mpi-22-bounces_at_[hidden] [mailto:mpi-22-bounces_at_lists.mpi- forum.org] On Behalf Of Jeff Squyres Sent: Friday, March 13, 2009 7:05 AM To: MPI 2.2 Subject: Re: [Mpi-22] Ticket #46: Addconst Keyword to the C bindings- implementation
Do you end up casting away the const when invoking the Windows network interfaces?
On Linux, I think the following interfaces would require casting the const away:
- shared memory (even using Linux vmsplice()) - MX - TCP - OpenFabrics (both verbs and udapl)
These interfaces do not require casting away const:
- SCTP (I *think* -- I'm not an SCTP expert, but a quick look in sctp.h showed a "const" argument for the sctp_sendmsg() function)
I can't check these offhand:
- Portals - Elan
On Mar 12, 2009, at 6:06 PM, Erez Haba wrote:
I urge you, please read the ticket proposal again. It discusses the merit of this proposal.
As for IB; yes you'd copy small messages (which const is fine with) and some implement RDMA read or write for large messages; you might need to cast the const away if your IB interface does not expose const SGE's.
As for the compiler; no you are not violating the contact; (otherwise we wouldn't have casts); as long as you guarantee that you are not changing the buffer. It's a way for the programmer to use old, non const correct, interfaces.
.Erez
-----Original Message----- From: mpi-22-bounces_at_[hidden] [mailto:mpi-22- bounces_at_[hidden] ] On Behalf Of Underwood, Keith D Sent: Thursday, March 12, 2009 2:03 PM To: MPI 2.2 Subject: Re: [Mpi-22] Ticket #46: Add const Keyword to the C bindings- implementation
I didn't think that typical MPI implementations over IB copied the data for large messages (as opposed to the bounce buffers for small messages).
If you are going to have to cast away the const, what is the point of putting it in? In fact, if you have to cast away the const, aren't you violating your contract with the compiler? Should this change be rolled out from the bottom up? i.e. common low-level APIs first and then MPI?
Keith
-----Original Message----- From: mpi-22-bounces_at_[hidden] [mailto:mpi-22- bounces_at_lists.mpi- forum.org] On Behalf Of Erez Haba Sent: Thursday, March 12, 2009 2:10 PM To: MPI 2.2 Subject: Re: [Mpi-22] Ticket #46: Add const Keyword to the C bindings- implementation
Possibly you'll have to cast. There are few interfaces that take const for send buffer (like sockets). In other cases you copy the buffer (like with IB) which keeps the const property.
Thanks, .Erez
-----Original Message----- From: mpi-22-bounces_at_[hidden] [mailto:mpi-22- bounces_at_lists.mpi- forum.org] On Behalf Of Underwood, Keith D Sent: Thursday, March 12, 2009 12:05 PM To: MPI 2.2 Subject: Re: [Mpi-22] Ticket #46: Add const Keyword to the C bindings- implementation
It would seem like const would eventually have to be cast away for most lower level interfaces. Portals, Elan, IB Verbs, and as best I can tell MX don't have const on their send buffers...
Keith
-----Original Message----- From: mpi-22-bounces_at_[hidden] [mailto:mpi-22- bounces_at_lists.mpi- forum.org] On Behalf Of Erez Haba Sent: Thursday, March 12, 2009 12:44 PM To: MPI 2.2 Subject: Re: [Mpi-22] Ticket #46: Add const Keyword to the C bindings- implementation
No, it's not being cast away (although it is a quick way for you to implement it). In MPICH2 implementation it trickles down to the lower functions. There are very few places where the const is being cast away because ticket #46 does not to break backward compatibility. For example, when the user function is called (const was not added to the MPI_User_function) the implementation must cast away const from the send buffer before calling the user function.
Thanks, .Erez
-----Original Message----- From: mpi-22-bounces_at_[hidden] [mailto:mpi-22- bounces_at_lists.mpi- forum.org] On Behalf Of Jeff Squyres Sent: Thursday, March 12, 2009 11:34 AM To: MPI 2.2 Subject: Re: [Mpi-22] Ticket #46: Add const Keyword to the C bindings- implementation
More importantly, how is const handled? Is it just cast away inside the MPI library?
On Mar 12, 2009, at 2:34 PM, Underwood, Keith D wrote:
Since the main purpose of an implementation for something like adding const is to see how invasive the change is, would it be possible to get a diff against the trees that these were created from?
Thanks, Keith
From: mpi-22-bounces_at_[hidden] [mailto:mpi-22- bounces_at_[hidden] ] On Behalf Of Erez Haba Sent: Thursday, March 12, 2009 12:24 PM To: MPI 2.2 Subject: [Mpi-22] Ticket #46: Add const Keyword to the C bindings - implementation
Implementation for ticket #46 is now available from ANL (thanks Pavan)
tarballs
http://www.mcs.anl.gov/research/projects/mpich2/downloads/tarballs/nightl y /
const
thanks, .Erez
_______________________________________________ mpi-22 mailing list mpi-22_at_[hidden] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-22
-- Jeff Squyres Cisco Systems
participants (1)
unknown@example.com
