Re: [Mpi-22] Memory footprint concern
I think Alexander hit on the answer to this: how is the user to know what is going to offer an implementation some advantage? What may look like it could offer a lot of benefit from a users perspective (ready send) could be considered low priority by the implementer. Especially in the constrained environments example, every implementer for a constrained environment could have a different perception of what they can make fast and small. So, an application that runs fine on a Cell SPE could blow up the code memory footprint on a Clearspeed. This is ultimately bad for the user. That is to say nothing of the dynamic memory footprint, which I am sure an implementer could trim with appropriate guarantees. I'm not sure official subsetting is the right answer or what the right approach for getting that functionality would be, but I am pretty sure that MPI on a Cell SPE is going to be a subset - whether it is official or not :-) Keith ________________________________ From: mpi-22-bounces_at_[hidden] [mailto:mpi-22-bounces_at_[hidden]] On Behalf Of Richard Treumann Sent: Friday, May 09, 2008 3:48 PM To: MPI 2.2 Subject: Re: [Mpi-22] Memory footprint concern Hi Keith Say the MPI implementor for the Cell SPE version of MPI did a good job of organizing his functionality (perhaps by making subsetting decisions that work for the structure of his implementation). Say there is an MPI application that only makes calls to the 6 essential MPI routines plus MPI_Allreduce and MPI_Bcast. When that application is statically bound to the MPI implementation by a smart linker that follows dependancy chains and only brings in needed subroutines don't you get the desired result? What more do you get in this case from having the MPI standard dictate the subsets and asking the user to declare what subsets he will need? If you leave it to the implementor to devise the subsets and change them as some ways of slicing and dicing libmpi prove more useful than others it may be better than having the standard lock down the dividing lines based on today's best guess. It does occur to me that the linker cannot tell if the MPI_Bcast call will need the code that supports MPI_Bcast on intercommunicators even though that is rarely used. That means if the application has an MPI_Bcast call, both (probably needed) intracomm- and (probably not needed) intercomm support enter the footprint. Dick Dick Treumann - MPI Team/TCEM IBM Systems & Technology Group Dept 0lva / MS P963 -- 2455 South Road -- Poughkeepsie, NY 12601 Tele (845) 433-7846 Fax (845) 433-8363 mpi-22-bounces_at_[hidden] wrote on 05/09/2008 02:34:33 PM:
Imagine, for example, MPI running on a Cell SPE. Yes, it sounds crazy, but people are working on it. If you look at the state in MPI-2 today, and assume it will grow proportionally with complexity, MPI-3 could be really nasty in that context. So, while I agree that an arbitrarily large number of permutations is a terrible idea for everyone involved (implementers wouldn't leverage all of the options, ISVs wouldn't test them, people who write third party libraries would have a huge headache dealing with the arbitrary combination of features chosen by the application), it seems like it would be prudent to try to figure out how to provide some mechanisms in this direction. I don't know if this overlaps with your idea about assertions or not, but they do seem to be related.
Keith
participants (1)
unknown@example.com
