Re: [Mpi-22] mpi-22 Digest, Vol 2, Issue 7
Woops... Read "dynamic processes" rather than "one-sided". Partial update, sorry. -----Original Message----- From: mpi-22-bounces_at_[hidden] [mailto:mpi-22-bounces_at_[hidden]] On Behalf Of Supalov, Alexander Sent: Monday, May 05, 2008 7:54 PM To: MPI 2.2 Subject: Re: [Mpi-22] mpi-22 Digest, Vol 2, Issue 7 Hi, We may want to see whether communicator-bound restriction will help down there. For example, even one communicator with dynamic processes enabled may "taint" the progress engine enough to make any saving from the absence of one-sided elsewhere disappear. On the other hand, attaching attributes to the MPI_COMM_WORLD, although not fully clean and properly timed, might be a way to spread the assertions across the job, and let libraries cut their proper part out. Same with windows and files, by the way. How and when will this pass down to the progress engine? I don't know. Do you? Best regards. Alexander -----Original Message----- From: mpi-22-bounces_at_[hidden] [mailto:mpi-22-bounces_at_[hidden]] On Behalf Of Jeff Squyres Sent: Monday, May 05, 2008 7:31 PM To: MPI 2.2 Subject: Re: [Mpi-22] mpi-22 Digest, Vol 2, Issue 7 On May 5, 2008, at 1:28 PM, Supalov, Alexander wrote:
Thank you. We can actually introduce what you propose, possibly with a query function to make it still easier to live with, as early as in MPI 2.2, as a subset precursor. Judging by the discussion in Chicago, subsets may not need much more than that in the end, possibly with a little more flags and semantics added in MPI-3.
The reservation against 32- (or for that matter, 64-) bit limitation is the only one I have at the moment. Not being able to attach assertions to communicators, etc. may be missed by some advanced programmers, but here we need to be pragmatic: who will ever want to go that deep?
Libraries that build on top of MPI may want to. This was one of the prime motivations for communications, right? (private/safe communications) As Quincy stated in Chicago and on the mailing list (IIRC), what if a top-level app sets an assertion that a library using MPI can't live with? Being able to set them per-communicator might alleviate that issue. -- Jeff Squyres Cisco Systems _______________________________________________ mpi-22 mailing list mpi-22_at_[hidden] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-22 --------------------------------------------------------------------- Intel GmbH Dornacher Strasse 1 85622 Feldkirchen/Muenchen Germany Sitz der Gesellschaft: Feldkirchen bei Muenchen Geschaeftsfuehrer: Douglas Lusk, Peter Gleissner, Hannes Schwaderer Registergericht: Muenchen HRB 47456 Ust.-IdNr. VAT Registration No.: DE129385895 Citibank Frankfurt (BLZ 502 109 00) 600119052 This e-mail and any attachments may contain confidential material for the sole use of the intended recipient(s). Any review or distribution by others is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies. _______________________________________________ mpi-22 mailing list mpi-22_at_[hidden] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-22 --------------------------------------------------------------------- Intel GmbH Dornacher Strasse 1 85622 Feldkirchen/Muenchen Germany Sitz der Gesellschaft: Feldkirchen bei Muenchen Geschaeftsfuehrer: Douglas Lusk, Peter Gleissner, Hannes Schwaderer Registergericht: Muenchen HRB 47456 Ust.-IdNr. VAT Registration No.: DE129385895 Citibank Frankfurt (BLZ 502 109 00) 600119052 This e-mail and any attachments may contain confidential material for the sole use of the intended recipient(s). Any review or distribution by others is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
participants (1)
unknown@example.com
