Re: [Mpi-22] New proposal: Support for large message counts
Alexander, We do have use-cases of customers requireing a mix of 32-bit and 64-bit executables (as strange as it sounds). These are not typical MPI applications, though... Thanx! Kannan -----Original Message----- From: mpi-22-bounces_at_[hidden] [mailto:mpi-22-bounces_at_[hidden]] On Behalf Of Supalov, Alexander Sent: Thursday, September 04, 2008 3:58 AM To: MPI 2.2 Subject: Re: [Mpi-22] New proposal: Support for large message counts Hi, Yes, I was looking into maintaining one library source code with the ability to build several versions out of it. Since 1) and 2) will be essentially ABI compatible, one can ship one version of the 32-bit dynamic library to cover both cases. The 64-bit library will be different, and this is I think what customers want anyway - they don't seem to want mixing 32- and 64-bit calls in one application. Best regards. Alexander -----Original Message----- From: mpi-22-bounces_at_[hidden] [mailto:mpi-22-bounces_at_[hidden]] On Behalf Of Narasimhan, Kannan Sent: Wednesday, September 03, 2008 7:32 PM To: MPI 2.2 Subject: Re: [Mpi-22] New proposal: Support for large message counts Alexander, Thanx for the suggestion. 1. Maybe I'm missing something here, but without name change, we break backward compatibility with "old" binaries coded to the existing APIs with 32-bit counts, and the new MPI 2.2 compatible MPI shared library that supports 64-bit counts --- without a re-build/relink step. Or are you proposing that implementations have multiple libraries, one that supports 32 bit counts, one that supports 64 bit counts, etc.? With a single library, (1) and (2) addresses backward compatibility, but maintains status-quo on support for large message counts, and (3) and (4) requires rebuild. However, having different names will take care of this. 2. If needed, we can explore normalization to a single API that supports MPI_Count in the MPI 3.0 time frame, since MPI 3.0 is open changes that can break backward compatibility. 3. I cannot think of any use cases for a "signed" count, but I'll let others chime in here. 4. I agree that new applications will have no issues with your approach. Thanx! Kannan -----Original Message----- From: mpi-22-bounces_at_[hidden] [mailto:mpi-22-bounces_at_[hidden]] On Behalf Of Supalov, Alexander Sent: Wednesday, September 03, 2008 11:39 AM To: MPI 2.2 Subject: Re: [Mpi-22] New proposal: Support for large message counts Thanks. We may even do without changing the MPI routine names I think. Let's consider this: 1) #define MPI_Count int will yield the current MPI interface. 2) typedef int MPI_Count will yield the new 32-bit interface, still backward binary compatible with 1). 3) typedef long MPI_Count will yield new 64-bit interface. 4) typedef long long MPI_Count will safely bring us into XXII century (or earlier). Old applications may be rebuilt using 1) without any changes, dynamically linked against MPI library built using 2), and will have to be rebuilt to use MPI library built using 3) or 4). New applications will use library with the MPI_Count definitions, and, properly rebuilt, will work in either 32-, 64-, or 128-bit mode, using MPI libraries built using MPI bindings 2), 3), or 4), respectively. By the way, should MPI_Count really be signed? -----Original Message----- From: mpi-22-bounces_at_[hidden] [mailto:mpi-22-bounces_at_[hidden]] On Behalf Of Narasimhan, Kannan Sent: Wednesday, September 03, 2008 5:55 PM To: MPI 2.2 Subject: Re: [Mpi-22] New proposal: Support for large message counts We can certainly consider this option, since it abstracts along the same lines as MPI_Offset. Thanx! Kannan -----Original Message----- From: mpi-22-bounces_at_[hidden] [mailto:mpi-22-bounces_at_[hidden]] On Behalf Of Supalov, Alexander Sent: Wednesday, September 03, 2008 10:19 AM To: MPI 2.2 Subject: Re: [Mpi-22] New proposal: Support for large message counts Dear Kannan, Thanks. Why don't we define MPI_Count datatype instead, and make that grow if necessary? Best regards. Alexander -----Original Message----- From: mpi-22-bounces_at_[hidden] [mailto:mpi-22-bounces_at_[hidden]] On Behalf Of Narasimhan, Kannan Sent: Friday, August 29, 2008 6:15 PM To: mpi-22_at_[hidden] Subject: [Mpi-22] New proposal: Support for large message counts I have submitted a new 2.2 proposal to addresses the need for large message counts (i.e. counts greater than the size of 32-bit integer) for MPI calls that communicate messages. Please refer to https://svn.mpi-forum.org/trac/mpi-forum-web/wiki/mpi22/LargeMsgCounts for details. Comments and suggestions are welcome. Thanx! Kannan _______________________________________________ mpi-22 mailing list mpi-22_at_[hidden] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-22 --------------------------------------------------------------------- Intel GmbH Dornacher Strasse 1 85622 Feldkirchen/Muenchen Germany Sitz der Gesellschaft: Feldkirchen bei Muenchen Geschaeftsfuehrer: Douglas Lusk, Peter Gleissner, Hannes Schwaderer Registergericht: Muenchen HRB 47456 Ust.-IdNr. VAT Registration No.: DE129385895 Citibank Frankfurt (BLZ 502 109 00) 600119052 This e-mail and any attachments may contain confidential material for the sole use of the intended recipient(s). Any review or distribution by others is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies. _______________________________________________ mpi-22 mailing list mpi-22_at_[hidden] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-22 _______________________________________________ mpi-22 mailing list mpi-22_at_[hidden] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-22 --------------------------------------------------------------------- Intel GmbH Dornacher Strasse 1 85622 Feldkirchen/Muenchen Germany Sitz der Gesellschaft: Feldkirchen bei Muenchen Geschaeftsfuehrer: Douglas Lusk, Peter Gleissner, Hannes Schwaderer Registergericht: Muenchen HRB 47456 Ust.-IdNr. VAT Registration No.: DE129385895 Citibank Frankfurt (BLZ 502 109 00) 600119052 This e-mail and any attachments may contain confidential material for the sole use of the intended recipient(s). Any review or distribution by others is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies. _______________________________________________ mpi-22 mailing list mpi-22_at_[hidden] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-22 _______________________________________________ mpi-22 mailing list mpi-22_at_[hidden] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-22 --------------------------------------------------------------------- Intel GmbH Dornacher Strasse 1 85622 Feldkirchen/Muenchen Germany Sitz der Gesellschaft: Feldkirchen bei Muenchen Geschaeftsfuehrer: Douglas Lusk, Peter Gleissner, Hannes Schwaderer Registergericht: Muenchen HRB 47456 Ust.-IdNr. VAT Registration No.: DE129385895 Citibank Frankfurt (BLZ 502 109 00) 600119052 This e-mail and any attachments may contain confidential material for the sole use of the intended recipient(s). Any review or distribution by others is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies. _______________________________________________ mpi-22 mailing list mpi-22_at_[hidden] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-22
participants (1)
unknown@example.com
