Re: [Mpi-22] Higher-level languages proposal
Dear Jeff, Unfortunately, I won't be in Chicago, so we should rather discuss this here. I talked to Torsten last time about this extension. As far as I can remember, the main purpose of this extension is to make sure that the thread that called the MPI_Probe also calls the MPI_Recv and gets the message matched by the aforementioned MPI_Probe. If so, the main problem here is not the matching. The main problem is that one cannot address threads in MPI. If we fix that, the proposed extension with the message handle and such will become superfluous. See what I mean? Best regards. Alexander -----Original Message----- From: mpi-22-bounces_at_[hidden] [mailto:mpi-22-bounces_at_[hidden]] On Behalf Of Jeff Squyres Sent: Monday, October 13, 2008 11:48 PM To: MPI 2.2 Subject: Re: [Mpi-22] Higher-level languages proposal On Oct 13, 2008, at 10:46 AM, Supalov, Alexander wrote:
Thanks. The 2.1.1, which was presented last time, in my opinion does not seem to solve the right problem. Instead of defining a way for unambiguous addressing of the threads in MPI, which would eliminate the MPI_Probe/Recv ambiguity and many other issues, it attempts to add yet another concept (this time, a message id) in the current situation where any thread can do what they please.
I'm not quite sure I understand your proposal. <... after typing out a lengthy/rambling discourse that made very little sense and was fraught with questions and ambiguities :-) ...> Let's discuss this in Chicago; Rich has allocated 5-7pm on Monday for discussion of this proposal. These are exactly the kinds of larger issues that we want to raise via this proposal. -- Jeff Squyres Cisco Systems _______________________________________________ mpi-22 mailing list mpi-22_at_[hidden] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-22 --------------------------------------------------------------------- Intel GmbH Dornacher Strasse 1 85622 Feldkirchen/Muenchen Germany Sitz der Gesellschaft: Feldkirchen bei Muenchen Geschaeftsfuehrer: Douglas Lusk, Peter Gleissner, Hannes Schwaderer Registergericht: Muenchen HRB 47456 Ust.-IdNr. VAT Registration No.: DE129385895 Citibank Frankfurt (BLZ 502 109 00) 600119052 This e-mail and any attachments may contain confidential material for the sole use of the intended recipient(s). Any review or distribution by others is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
participants (1)
unknown@example.com
