Re: [Mpi-22] MPI_Aint/MPI_ADDRESS_KIND equivalence and ticket #18
Address-sized variables in MPI can be passed from C to Fortran or vice versa, and I know of no c2f or f2c conversion functions for them. So I think MPI_Aint and integer (kind=MPI_ADDRESS_KIND) are assumed to be of the same size at least implicitly. Rajeev
-----Original Message----- From: mpi-22-bounces_at_[hidden] [mailto:mpi-22-bounces_at_[hidden]] On Behalf Of Dave Goodell Sent: Friday, March 06, 2009 1:09 PM To: MPI 2.2 Subject: [Mpi-22] MPI_Aint/MPI_ADDRESS_KIND equivalence and ticket #18
At the last meeting in San Jose, Rolf brought up a good point w.r.t. ticket #18 [1]. Part of the proposal for ticket #18 is to add MPI_AINT and MPI_OFFSET types corresponding to MPI_Aint/ MPI_ADDRESS_KIND and MPI_Offset/MPI_OFFSET_KIND language types. Rolf's point was that it isn't defined in the standard whether or not MPI_Aint and INTEGER(KIND=MPI_ADDRESS_KIND) are exactly the same type. Obviously we cannot define a new predefined datatype corresponding to two different language types. I believe Rolf's view (correct me if I'm misrepresenting you, Rolf) was that the forum ought to make their equivalence explicit, irrespective of what happens with ticket #18. I'm ambivalent about this issue, but I need a resolution on it in order to get #18 into a final voteable state.
So the larger question to the Forum is: Are these types exactly the same between the two languages?
Looking at MPICH2 it seems that we try to make them the same size but there are some convoluted code paths in the build logic that might result in different sizes. I would not consider this to be a compelling argument that they are permitted to differ because the logic in question may simply be buggy or never exercised. Does anyone have an example from other MPI implementations where the types do/may differ? Do any Fortran experts out there know of instances where MPI_ADDRESS_KIND would be different from MPI_Aint?
As for the impact on ticket #18, there are several ways to deal with this:
1) If the Forum decides that the types are always equivalent, add text to that effect (probably in a separate ticket) and otherwise stick with the current proposal. 2) If the Forum decides that the type equivalence is undefined, drop the new MPI_AINT/MPI_OFFSET types from the proposal. 3) If the Forum decides that the type equivalence is undefined, create four types instead of just two: MPI_AINT, MPI_OFFSET, MPI_F_AINT, MPI_F_OFFSET (or some such names). 4) If the Forum decides that the type equivalence is undefined, make MPI_AINT/MPI_OFFSET only correspond to the C types.
I'm inclined towards either #1 or #2, depending on what the Forum decides about the type equivalence. I also can separate the MPI_AINT/ MPI_OFFSET types out into a separate ticket if this becomes too contentious of an issue, but I'd like to keep it together for now since the text changes are easier to describe correctly in just one place.
-Dave
[1] https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/18 _______________________________________________ mpi-22 mailing list mpi-22_at_[hidden] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-22
participants (1)
unknown@example.com
