Re: [Mpi-22] Ticket #71: Add routine for registering callbackwhen finalize occurs
Sorry -- I didn't see this much-more-complete discussion before I replied to the other mail. I agree with most of Dick's points (e.g., an MPI will likely implement the same mechanism for COMM_SELF as it does for all other attribute destruction functionality). But I don't feel strongly one way or the other (apply the ordering just to COMM_SELF or to all attribute destruction). To me, the COMM_SELF attribute destruction stuff is already a hack -- elegant or not -- so adding ordering on it is no big deal. But like I said, I don't have strong feelings either way. On Mar 30, 2009, at 10:09 AM, Richard Treumann wrote:
I understand that the immediate motive is associated with the use of attribute delete callbacks that occur when MPI_COMM_SELF is freed at MPI_FINALIZE.
That does not alter the fact that when MPI-2 imposed an implicit free of MPI_COMM_SELF in MPI_FINALIZE to allow the use of attribute delete functions for cleanup it involved a narrow extension of a general MPI facility related to attributes and certain object types. To allow attribute delete functions for all other communicators (etc) to occur in arbitrary order while demanding that attribute delete for MPI_COMM_SELF have a standards defined order is an inelegant hack (in my opinion). Freeing MPI_COMM_SELF within MPI_FINALIZE was a relatively elegant hack because it did not introduce inconsistency.
Add to that the probability that an MPI implementor is likely to use the same algorithms for all attribute management rather than write special case code for MPI_COMM_SELF leads me to argue that if a defined order for attribute delete callbacks is adopted it should be adopted broadly to maintain a consistent flavor across the standard.
If an existing MPI implementation is currently deleting in some other order and an application happens to work on that MPI only because of that order, that application is at least non-portable and probably should be considered buggy. If (or when) the implementation adopts the fifo order for attribute deletes on "user_comm" it would be clear that the implementation change had not "broken the user".
A general mandate that attribute deletion callbacks on all object types must occur in fifo order for an implementation to be MPI 2.2 compliant should not break any "correct" MPI application and should not be noticeably harder for implementors.
It will require tracking down all places in the standard that currently say the order is arbitrary so it is harder to get all ducks in a row for the ticket.
Dick Treumann - MPI Team IBM Systems & Technology Group Dept X2ZA / MS P963 -- 2455 South Road -- Poughkeepsie, NY 12601 Tele (845) 433-7846 Fax (845) 433-8363
mpi-22-bounces_at_[hidden] wrote on 03/28/2009 11:57:19 PM:
[image removed]
Re: [Mpi-22] Ticket #71: Add routine for registering callback when finalize occurs
Quincey Koziol
to:
mpi-22
03/30/2009 09:28 AM
Sent by:
Please respond to "MPI 2.2"
Date: Thu, 26 Mar 2009 13:24:26 -0400 From: Richard Treumann <treumann_at_[hidden]> Subject: Re: [Mpi-22] Ticket #71: Add routine for registering callback when finalize occurs To: "MPI 2.2" <mpi-22_at_[hidden]> Message-ID: <OFE2F8673A.D3771BE2- ON85257585.005F95BC-85257585.005F9F47_at_[hidden]> Content-Type: text/plain; charset="us-ascii"
Why would this be specific to MPI_COMM_SELF? If this is the right thing to do, shouldn't it apply to attribute delete functions on all disposed objects?
The ticket is oriented to what happens at MPI_Finalize, really, and not so much about MPI_COMM_SELF per se. The attribute callback on MPI_COMM_SELF was just the accepted way in the standard to "have something happen" when MPI_Finalize was called.
Quincey
mpi-22-bounces_at_[hidden] wrote on 03/26/2009 12:50:40 PM:
[image removed]
Quincey Koziol
to:
mpi-22
03/26/2009 12:54 PM:
Sent by:
Hi all, Could another two people review this ticket for specifying the order that attribute delete callbacks should be made:
https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/71
Thanks, Quincey
[attachment "smime.p7s" deleted by Richard Treumann/Poughkeepsie/ IBM] _______________________________________________ mpi-22 mailing list mpi-22_at_[hidden] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-22
participants (1)
unknown@example.com
