Re: [mpi-22] [mpi-21] Ballot 4 - MPI_THREAD_FUNNELED - was Re: Attending, topics, etc
Jim and Rich: Then I suggest that fixing this broken semantic decision is something that we should consider for MPI 2.2. It should not break any existing programs and might even make some existing ones standards conforming. Although I can imagine ways for the MPI implementation to detect that the one thread is not the main thread it is not at all clear to me how it would matter to the implementation. Bronis On Thu, 31 Jan 2008, Cownie, James H wrote:
Because that's how it's always been. We're not adding a restriction with the change, merely clarifying the existing restriction.
-- Jim
James Cownie <james.h.cownie_at_[hidden]> SSG/DPD/PAT Tel: +44 117 9071438
From: mpi-21-bounces_at_[hidden] [mailto:mpi-21-bounces_at_[hidden]] On Behalf Of Richard Graham Sent: 31 January 2008 15:51 To: Mailing list for discussion of MPI 2.1 Subject: Re: [mpi-21] Ballot 4 - MPI_THREAD_FUNNELED - was Re: Attending, topics, etc
Why restrict this to a standard specified thread (main thread), why not word it as a singe thread, and let the app decide what thread this is, based on what ever criteria it wants to use to select this thread ?
Rich
On 1/31/08 10:27 AM, "Richard Treumann" <treumann_at_[hidden]> wrote:
How about:: MPI_THREAD_FUNNELED The process may be multi-threaded, but the application must insure that only the main thread makes MPI calls.
Dick Treumann - MPI Team/TCEM IBM Systems & Technology Group Dept 0lva / MS P963 -- 2455 South Road -- Poughkeepsie, NY 12601 Tele (845) 433-7846 Fax (845) 433-8363
mpi-21-bounces_at_[hidden] wrote on 01/31/2008 09:44:08 AM:
A simpler change which would seem to achieve the desired clarification would be :-
MPI_THREAD_FUNNELED The process may be multi-threaded, but only the main thread is allowed to make MPI calls.
(and you could add If other threads make MPI calls the behavior is undefined. if you want to be verbose about it).
-- Jim
-----Original Message----- From: mpi-21-bounces_at_[hidden] [mailto:mpi-21-bounces_at_[hidden]] <mailto:mpi-21-bounces_at_[hidden]%5d> On Behalf Of Rolf Rabenseifner Sent: 31 January 2008 14:31 To: mpi-21_at_[hidden] Subject: [mpi-21] Ballot 4 - MPI_THREAD_FUNNELED - was Re: Attending, topics, etc
This is a proposal for MPI 2.1, Ballot 4.
I'm asking especially Greg Lindahl, the participants of the email-discussion in 2007, to review this proposal.
This is a follow up to: Which thread is the funneled thread? in http://www.cs.uiuc.edu/homes/wgropp/projects/parallel/MPI/mpi- errata/index.html with mail discussion in http://www.cs.uiuc.edu/homes/wgropp/projects/parallel/MPI/mpi- errata/discuss/funneled/ ___________________________________
Proposal: MPI-2.0 Sect. 8.7.3, MPI_Init_thread, page 196, lines 25-26 read:
MPI_THREAD_FUNNELED The process may be multi-threaded, but only the main thread will make MPI calls (all MPI calls are "funneled" to the main thread).
but should read:
MPI_THREAD_FUNNELED The process may be multi-threaded, but only the main thread will make MPI calls (all MPI calls are "funneled" to the main thread, e.g., by using the OpenMP directive "master" in the application program). ___________________________________ Rationale for this clarification from the email from Greg Lindahl: The existing document doesn't make it clear that the MPI user has to funnel the calls to the main thread; it's not the job of the MPI library. I have seen multiple MPI users confused by this issue, and when I first read this section, I was confused by it, too. ___________________________________
Best regards Rolf
Dr. Rolf Rabenseifner . . . . . . . . . .. email rabenseifner_at_[hidden] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . (Office: Allmandring 30) _______________________________________________ mpi-21 mailing list mpi-21_at_[hidden] http://lists.cs.uiuc.edu/mailman/listinfo/mpi-21
Intel Corporation (UK) Limited Registered No. 1134945 (England) Registered Office: Pipers Way, Swindon SN3 1RJ VAT No: 860 2173 47
This e-mail and any attachments may contain confidential material for the sole use of the intended recipient(s). Any review or distribution by others is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
--------------------------------------------------------------------- Intel Corporation (UK) Limited Registered No. 1134945 (England) Registered Office: Pipers Way, Swindon SN3 1RJ VAT No: 860 2173 47
participants (1)
unknown@example.com
