Re: [Mpi-22] Borderline ticket #107: Types of predefined constants in Appendix A
On Aug 3, 2009, at 12:36 PM, Erez Haba wrote:
This might be nitpicking but wouldn't that force implementation to typecast their definition of error codes? For example,
#define MPI_ERR_BUFFER 0
Is not a correct definition with the proposed change, because it is not typed.
I think that the "Constants with the type const int may also be implemented as literal integer constants substituted by the preprocessor" bit on lines 23-24 helps implementors realize that they don't need to insert a cast here. Also, the type of the integer constant 0 is typed as the first integer type in {int, long int, long long int} that can express the value, which is required to be int in this particular case.
Thus, it needs to change to
#define MPI_ERR_BUFFER (int)0 // you don't really need to define it as (const int)0
as a result the following statement
short x = MPI_ERR_BUFFER;
which compiled correctly before, would break with this change.
To the best of my knowledge this is still perfectly legitimate C. Section 6.5.16.1 of my copy of the C99 standard seems to corroborate this: -------8<-------- Semantics 2 In simple assignment (=), the value of the right operand is converted to the type of the assignment expression and replaces the value stored in the object designated by the left operand. -------8<-------- GCC doesn't give a warning for this assignment, even when you add a bunch of warning flags. It does warn if the value is something too large for the short type (like 0xdeadbeef), although of course only for direct assignments like this when the compiler still knows the origin of the value. Does the Microsoft compiler behave differently?
Second comment.
Adding the 'const' modifier to all types is very confusing imho. I understand that it meant to make it clear that the values are constants and should not change, but still is very confusing.
For example,
C Type: void * const MPI_BOTTOM
This means that the value of MPI_BOTTOM is constant and not the memory it points to. however at first look you might think that it's the later. (if it was, it would break any application that uses it because the API's do not take a pointer to const void)
I'm not sure that there's a lot we can do if people can't properly read cv-qualified C types. This is a standards document, not a tutorial. I don't think that this is intentionally misleading or difficult to read.
In any case implementers should define MPI_BOTTOM as
#define MPI_BOTTOM (void*)0
Rather than
#define MPI_BOTTOM (void* const)0
As the value is constant and you don't need to add the const modifier.
The reason you don't really need the const here is that casts create rvalues. So it has the same effect as a cast to the unqualified type. This, combined with the constant initializer rule in MPI-2.1 section 2.5.4, is one reason that choosing "const int" as the type for these constants is debatable.
Note that the 'constness' of these values is already stated in the title of the section '19.1.1 Defined Constants'
I don't agree. The semantic constness of these constants is implied by the title, but not the specific language implementation constness. In the standard we could say "X, Y, and Z are constants (their values never change) with the exact type `int'". Depending on the exact uses with the rest of the API this would be perfectly valid, although we might lose some error checking assistance from C compilers. The title together with MPI-2.1 section 2.5.4 indicates that most of these are compile-time constants that may be used for initialization, so you could say that the constness doesn't matter since these may never be stored in link-time constant variables. However using "const" as a way of indicating that these constants are "non- lvalue" (and in particular, "non-(modifiable lvalue)") is fine by me. -Dave
participants (1)
unknown@example.com
