Re: [Mpi-22] Another MPI-2.2 attribute ambiguity?
Imagine a Fortran communicator keyval copy function callback like this (typed off the top of my head; pardon typos): SUBROUTINE COPY_FUNCTION1(OLDCOMM, KEYVAL, EXTRA_STATE, AVALIN, AVALOUT, FLAG, IERR) ... INTEGER EXTRA_STATE INTEGER IERR EXTRA_STATE = EXTRA_STATE + 1 WRITE *, "Extra state is: ", EXTRA_STATE IERR = MPI_SUCCESS END Now suppose MPI_COMM_CREATE_KEYVAL is invoked like this: INTEGER EV = 7 CALL MPI_COMM_KEYVAL_CREATE(COPY_FUNCTION1, ..., EV, IERR) I think we all agree that the output the first time that COPY_FUNCTION1 is invoked should be 7. But what is the output the second time it is invoked -- 7 or 8? That is the question. I think Iain has conclusively show that in this case: INTEGER EV = 7 CALL MPI_COMM_KEYVAL_CREATE(COPY_FUNCTION1, ..., EV + 3, IERR) EV = 42 the output from the first call to COPY_FUNCTION1 still needs to be 10. The point is that the MPI implementation needs to *copy* the INTEGER value into internal storage and use *that* storage when calling COPY_FUNCTION1. If for no other reason than the value may be the result of an expression, and that storage disappears after the call to MPI_COMM_KEYVAL_CREATE completes (as in the above example). I'm not sure what you're referring to with the array stuff -- the Fortran prototype for the callback function says that the extra value can only be a single INTEGER...? On May 21, 2009, at 4:41 PM, William Gropp wrote:
I'm not sure what "change the value" means in #1. I think that you mean "if we interpret extra_data as a pointer to a Fortran data item, the MPI implementation will pass this pointer (by value) to the callback. If the callback stores through this pointer, then (naturally) the afore mentioned data item will be changed. If that's what #1 means, then yes, that's the right answer. Note that the extra_data could be a pointer to an array of arbitrary size, and the call back could update any part of the array. Saving a copy of what extra_data points at (is that what #2 is doing?) is going to be tricky, since you don't know the size of the thing to copy (without a lot of help from the compiler in Fortran).
Bill
On May 19, 2009, at 7:55 PM, Jeff Squyres wrote:
So then you're in favor of #1 from my original post, right?
http://lists.mpi-forum.org/mpi-22/2009/05/0407.php
On May 19, 2009, at 4:39 PM, William Gropp wrote:
Silly me, I missed that.
In Fortran (particularly thinking in terms of Fortran 77, since that was the original design), the Fortran callback should be able to do things like increment the "extra data" - i.e., if the extra data is a counter, the Fortran callback should be able to increment it. Since Fortran 77 has no pointers (and pointers in Fortran 90 aren't the same as addresses), having an address is worthless in a Fortran 77 program. So if the MPI implementation stores the address of the extra data and passes that to the call back (by value, so Fortran sees the address of the extra data), users should get what they expect in Fortran.
Bill
On May 19, 2009, at 12:22 PM, Iain Bason wrote:
On May 19, 2009, at 1:16 PM, William Gropp wrote:
MPICH2 passes the value of the extra_state that was saved in the internal storage to the callback routine, which is case 2 (the
copy
is implicit as the value is passed to the routine and C semantics ensures that the value isn't changed).
But this is the Fortran interface, not the C interface.
Iain
William Gropp Deputy Director for Research Institute for Advanced Computing Applications and Technologies Paul and Cynthia Saylor Professor of Computer Science University of Illinois Urbana-Champaign
_______________________________________________ mpi-22 mailing list mpi-22_at_[hidden] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-22
-- Jeff Squyres Cisco Systems
participants (1)
unknown@example.com
