Re: [Mpi-22] MPI::Grequest::Start proposal
FWIW, I checked this out with Doug Gregor (my C++-goto-guy) and he basically said "yep, that's right." On Sep 4, 2008, at 9:02 AM, Erez Haba wrote:
I think that this is okay; when we discussed it, I thought it was a different fix. The proposal is just fine.
-----Original Message----- From: mpi-22-bounces_at_[hidden] [mailto:mpi-22-bounces_at_[hidden] ] On Behalf Of Jeff Squyres Sent: Thursday, September 04, 2008 7:26 AM To: MPI 2.2 Subject: [Mpi-22] MPI::Grequest::Start proposal
Regarding https://svn.mpi-forum.org/trac/mpi-forum-web/wiki/mpi22/GrequestStartFnPtrAr... :
I have confirmed in Open MPI that if you change this:
static Grequest Start(Query_function, Free_function, Cancel_function, void *);
to
static Grequest Start(Query_function *, Free_function *, Cancel_function *, void *);
Recompile and reinstall, both the implementation and same C++ user code compiles without warning/error.
Erez raised the point that this would change the type of any implementation and user-declared variables that hold the function pointer. It does not; such a variable type must always be (Free_function*); it's only the type that is passed through a function argument that can be either (Free_function) or (Free_function*). Someone smarter than me in C++ can explain why. :-)
Specifically, the following compiles and runs without warning/error:
----- #include <stdio.h> typedef int Free_function(void *);
int my_function(void*) { printf("In my_function\n"); return 0; }
void foo1(Free_function ptr) { Free_function *save = ptr; save(0); } void foo2(Free_function* ptr) { Free_function *save = ptr; save(0); } int main (int argc, char*argv[]) { foo1(my_function); foo2(my_function); return 0; } -----
I tried 4 different C++ compilers (gnu, intel, pgi, pathscale):
----- [23:19] svbu-mpi:~/tmp % g++ foo.cc -o foo && ./foo In my_function In my_function [23:21] svbu-mpi:~/tmp % icpc foo.cc -o foo && ./foo In my_function In my_function [23:21] svbu-mpi:~/tmp % pgCC foo.cc -o foo && ./foo In my_function In my_function [23:22] svbu-mpi:~/tmp % pathCC foo.cc -o foo && ./foo In my_function In my_function [23:22] svbu-mpi:~/tmp % ------
So I think the proposal stands as it is written.
-- Jeff Squyres Cisco Systems
_______________________________________________ mpi-22 mailing list mpi-22_at_[hidden] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-22
participants (1)
unknown@example.com
