Re: [Mpi-22] Higher-level languages proposal
Hi, Thanks. The 2.1.1, which was presented last time, in my opinion does not seem to solve the right problem. Instead of defining a way for unambiguous addressing of the threads in MPI, which would eliminate the MPI_Probe/Recv ambiguity and many other issues, it attempts to add yet another concept (this time, a message id) in the current situation where any thread can do what they please. Best regards. Alexander -----Original Message----- From: mpi-22-bounces_at_[hidden] [mailto:mpi-22-bounces_at_[hidden]] On Behalf Of Jeff Squyres Sent: Monday, October 13, 2008 4:24 PM To: MPI 2.2 Subject: [Mpi-22] Higher-level languages proposal Doug Gregor did 98% of the work on this proposal, but it will likely be Torsten or I presenting this proposal next week in Chicago (5-7pm Monday). The short version of the attached text is that we propose the following: - add some extensions to MPI to allow higher-level languages to build their own MPI bindings - if all that works out nicely, deprecate and eventually remove the official MPI C++ bindings Don't let the proposal name fool you -- the features that we're proposing are inspired by letting higher-level language build their own bindings, but some of the issues (e.g., new MPI_BLOB datatype) are fairly wide-reaching. We haven't yet put a "2.2" or "3.0" label on this proposal (which is why I have not entered it in the MPI-2.2 ticket system); I can see valid arguments for both sides. More feedback is required from the Forum first. -- Jeff Squyres Cisco Systems --------------------------------------------------------------------- Intel GmbH Dornacher Strasse 1 85622 Feldkirchen/Muenchen Germany Sitz der Gesellschaft: Feldkirchen bei Muenchen Geschaeftsfuehrer: Douglas Lusk, Peter Gleissner, Hannes Schwaderer Registergericht: Muenchen HRB 47456 Ust.-IdNr. VAT Registration No.: DE129385895 Citibank Frankfurt (BLZ 502 109 00) 600119052 This e-mail and any attachments may contain confidential material for the sole use of the intended recipient(s). Any review or distribution by others is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
participants (1)
unknown@example.com
