While reviewing Rolf's April document, I came up with a list of MPI 2.2 issues that I thought I'd bring up: Sections: - Miscellaneous - IO (long itemization) - Language bindings --------------------------------------- Based on 1 April 2008 document Miscellaneous ============= - We need to update the Fortran renferences throughout the document (F90 -> F?03?). IO chapter ========== fh parameter should be IN (not INOUT) - p381.5 - p381.44 - p384.31 - p387.6 - p394.6 - p394.31 - p395.31 - p396.22 - p397.27 - p398.2 - p398.25 - p399.2 - p400.2 - p400.22 - p402.18 - p402.40 - p403.15 - p403:36 - p404.33 - p405.8 - p405.38 - p409.2 - p409.22 - p409.38 - p410.9 - p410.25 - p410.43 - p411.10 - p411.28 - p412.2 - p412.20 - p423.39 - p424.37 C++ bindings functions should be const - p381.14 - p382.4 - p384.39 - p387.24 - p393.19,21 - p393.44,46 - p394.23,25 - p394.48 - p395.2 - p395.25 - p395.48 - p396.36,38 - p397.42,45 - p398.17,19 - p398.39,42 - p399.17 - p400.17 - p400.32 - p401.11 - p401.35 - p402.32,35 - p403.7,9 - p403.29 - p404.3 - p404.48 - p405.2 - p405.23,25 - p405.48 - p408.22 - p408.37,38 - p409.18 - p409.32,33 - p410.4 - p410.19,20 - p410.38 - p411.4,5 - p411.23 - p411.38,39 - p412.15 - p412.30,31 - p424.1 - p424.44 Language bindings chapter ========================= - p441.31-33: Replace entire paragraph with: "Constants Constants are singleton objects and are declared const. The only exception is MPI::BOTTOM, which cannot be const because it can be passed as a receive buffer argument, which is not const."
Need to fix various C++ binding methods to be const (e.g., Set_name, Set_errhandler, etc.) Same arguments I've raised for a while: all MPI predefined C++ handles should be const except BOTTOM. Short argument: - have to be able to use MPI::COMM_WORLD for initialization before MPI::Init, so they *are* const because they're initialized before main() - the "const" refers to the C++ handle, not the back-end MPI object - the handle does not change (just like MPI_SEND where "comm" argument is IN and the method is const)
-- Jeff Squyres Cisco Systems
participants (1)
unknown@example.com
