Re: [Mpi-22] please review - add const keyword to the C bindings
Alexander: Re:
Pursuant to the discussion of #45 (send buffer access) that this #46 depends upon, I would suggest to suspend the review until we clear situation around #45.
While it is within your rights to suggest that we "suspend the review" of these items, I object to your timing. The issues have already had a first vote. You can raise concerns about them but I see no reason that we should cease to make progress on the wording when the vast majority (I don't recall if the vote was unanimous but it was not close) have agreed to them. Perhaps more importantly, your objections have been discussed from the first that Erez brought up the issues. Frankly, I have not seen anything in your objections that changes the extensive discussion on these issues. While it may be that you have changed your position (and Intel's?) on them, I strongly doubt that others will be convinced. In my opinion, Erez should definitely proceed with the reviews. If you want to object to the solutions, you will have an opportunity when the issues come up for their second vote the week after next. Bronis
Best regards.
Alexander
________________________________ From: mpi-22-bounces_at_[hidden] [mailto:mpi-22-bounces_at_[hidden]] On Behalf Of Erez Haba Sent: Friday, December 05, 2008 11:04 PM To: MPI 2.2 Subject: [Mpi-22] please review - add const keyword to the C bindings
This proposal has passed 1st voting and needs reviewers. We need 3 volunteers to sign-off on this proposal. The proposal is short so don't be intimidated. :) plus I need the chapter authors to sign-off on the changes to the API (that the text is correct).
Chapter Authors (it's less than a handful lines for each chapter)
Chapter 3: Point-to-Point Communication Chapter 4: Datatypes Chapter 5: Collective Communication Chapter 6: Groups, Contexts, Communicators, and Caching Chapter 7: Process Topologies Chapter 8: MPI Environmental Management Chapter 9: The Info Object Chapter 10: Process Creation and Management Chapter 11: One-Sided Communication Chapter 13: I/O Chapter 15: Deprecated Functions Chapter 16: Language Bindings
Please add a comment to the ticket saying that you reviewed the proposal, or please send me your comments.
Add const Keyword to the C bindings: https://svn.mpi-forum.org/trac/mpi-forum-web/ticket/46
Thanks, .Erez
--------------------------------------------------------------------- Intel GmbH Dornacher Strasse 1 85622 Feldkirchen/Muenchen Germany Sitz der Gesellschaft: Feldkirchen bei Muenchen Geschaeftsfuehrer: Douglas Lusk, Peter Gleissner, Hannes Schwaderer Registergericht: Muenchen HRB 47456 Ust.-IdNr. VAT Registration No.: DE129385895 Citibank Frankfurt (BLZ 502 109 00) 600119052
This e-mail and any attachments may contain confidential material for the sole use of the intended recipient(s). Any review or distribution by others is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
participants (1)
unknown@example.com
