Re: [Mpi-22] MPI-2.1 ambiguity?
Any behavior other than branch A violates the principle of least surprise. Bill On Jul 18, 2008, at 1:36 PM, Jeff Squyres wrote:
On Jul 18, 2008, at 2:21 PM, William Gropp wrote:
It might be a whole lot simpler to specifically define which predefined handles need to be available in each language. The spectrum ranges from "all languages' predefined handles must be available in every language" to "only that language A's predefined handles must be available in language A". Suggestions?
I'm in favor of explicitly specifying the values and names (because of the need to use alternate names when their might be a conflict, as in the MPI::F_COMPLEX case), and that these have the exact same value as if the handle transfer function was used.
Do we really need to mandate that they have the same value, or just exhibit the same behavior? Specifically does it matter if this code hits branch A or B?
MPI_Fint ftype; ftype = MPI_Type_c2f(MPI_INT); if (MPI_INT == MPI_Type_f2c(ftype)) { //branch A } else { //branch B }
Or is it simpler to say that the return from an operation like the above must behave exactly like the original, regardless of value?
-- Jeff Squyres Cisco Systems
_______________________________________________ mpi-22 mailing list mpi-22_at_[hidden] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-22
William Gropp Paul and Cynthia Saylor Professor of Computer Science University of Illinois Urbana-Champaign *
participants (1)
unknown@example.com
