Re: [Mpi-21] AUTHORS+REVIEWERS - Draft Apr. 12, 2008
Hi Torsten, I've marked most of your edits with DON2, which means I've made the change as you recommended. However, there are a number for which I'm not clear on what you meant. These are marked with "vv", which points to the question following. Would you please clarify these items? As a reference, let's use the following document for page and line numbers: http://www.hlrs.de/organization/par/services/models/mpi/mpi21/doc/mpi-report... -Adam Torsten Hoefler wrote:
Hi Rolf, Adam, I understand from your mail Rolf, that Adam lost his write token and that only you can apply the changes/comments to the chapter (in my case the collectives chapter). Thus, I'll send my review results to the list instead the chapter author directly. My general comment: very well done Adam :).
I have some smaller editing remarks and also found some small errors and clarification possibilities (see below).
---------------------------------------------------------------------------------- 1234567890123456789012345678901234567890123456789012345678901234567890123456789012 All references are based on MPI-2.1 Draft Apr. 12, 2008 ww.a __ pnnn.ll text (with nnn=page number and ll=line number text continued ... ww.b __ pnnn.ll text ... and so on (total line length <= 82 characters.) ----------------------------------------------------------------------------------
Ok, here my remarks, many of them (especially EDIT or CLAR) can probably be ignored, but I thought I'd bring it up:
general: the line numbers are completely out of sync ... it's hard to classify a line that is between two line numbers.
5.a DON2 EDIT p129.19-41 "all group members" vs. "all members of a group" should use the same phrasing (parallel structure)
5.b DON2 NICE p129.41 Reference to 5.11 not 5.11.1 5.c DON2 EDIT p129.45 remove "," (comma) 5.d DON2 EDIT p129.43 replace "the same" with "a" 5.e DON2 EDIT p129.45 "the same group" in line 43 conflicts with "group or groups"
There is not really a clear way to state this. As Rejeev also suggested, the definition of "matching" is not well understood here. Perhaps the best option is to remove this statement altogether, since it is defined in more detail in the "Specifics" sections for intra- and inter-communicators. I'll remove the statement, but the idea of "matching" parameters in collective calls should be discussed in the Forum. Thus, the following lines: "A collective operation is executed by having all processes in the same group call the communication routine, with matching arguments. One of the key arguments is a communicator ..." are now written more simply as: "One of the key arguments in a call to a collective routine is a communicator ..."
5.f vv CLAR p131.1 add "with exceptions stated in the following" to first sentence
Do you mean exceptions to the matching of datatypes in sender and receiver? Are there exceptions to this?
5.g DON2 EDIT p131.4 no linebreak (Chapter~\ref{...}) 5.h *NO* ERR p131.31 replace "will" with "might"
I'd leave this in, since it was the original wording for this version of the standard. I think there is still an escape here already in the "(or a similar mechanism)" phrase.
5.i vv ERR p132. "special communicator must be created" this is wrong, later (in the bcast section) it is stated differently ... I would just remove this part of the advice or say "might be created" (see Bcast advice)
Could you specify the particular advice via page and line numbers? It's not clear to me what you are referring to here.
5.j vv CLAR p131.37 add "depending on the operation performed after last sentence (right now it sounds like ths user is free to choose which argument to replace)
Do you mean p132.27 instead? The recommendation doesn't seem to line up with the document I have.
5.k *NO* EDIT p133.32 "a" -> "an"?
I think "a" is actually appropriate here.
5.l DON2 EDIT p136.22 start sentence with "If the communicator is an intracommunicator" as for all the other operations, remove "for intracommunicators" in line 23 5.m DON2 EDIT p136.24 replace "," by "and" 5.n ?? EDIT p136.26-31 this paragraph is redundant (it's all already stated earlier, do we want this redundancy in the standard?)
I agree that it is redundant, but this emphasis in a particular case may be useful to get the point across. I'd leave it up to the Forum to vote on this.
5.o *NO* EDIT p136.32 move sentence to end of the previous paragraph (line 25)
Although, this text may read more smoothly with this edit, it breaks symmetry on where the "in place" statements are placed in other descriptions.
5.p *NO* EDIT p136.37 "data is braodcasted" (not braodcast)
Left as "broadcast" per discussion between Bronis and Torsten which concluded that "broadcast" is recommended.
5.q DON2 CLAR p136.38-39 the text talks about send and receive buffer argument, but bcast only has a single buffer argument ...
5.r ?? CLAR p136.38 "must be consistent with the ..." what does the word consistent mean in this context? This seems undefined. I think it means that the signature (size, count) is the same. We should say this explicitely. The same term "consistent" is used in all following operations (I'm not going to add it again)
I agree that "consistent" is not defined, however, I'm not sure what it means either. I think this change should be left to the Forum.
5.s DON2 EDIT p138.3 write "all processes" instead of "process i" (i is never defined)
I changed this to: "The type signature of sendcount, sendtype on each process must be equal ..."
5.t *NO* ERR p139.47 data is not necessarily placed in rank order. The order is freely definably by the user in the displs[] array. Or does the standard enforce the displs[] array to preserve order? We might want to run this through the forum (or just ignore it?)?
I think the "that is, ..." portion of this statement clarifies the meaning.
5.u DON2 CLAR p136.42 add "The examples in this section are using intracommunicators." as in p140.27 5.v ?? EDIT p147.48 the last paragraph is redundant (has been stated before for all collectives)
Again, I'll leave this redundancy question to the Forum.
5.w DON2 EDIT p157.35 why a separate subsection for Alltoallw but not for Alltoallv? I'd remove this subsection 5.x DON2 EDIT p157.36 the first two sentences should go to rationale (we don't need to rationalize the operation in the description)
I missed this piece in the original rewrite, and so this section still required significant editting. I've made it look and feel more like the AlltoallV definition.
5.y DON2 EDIT p161.13 replace "Reduce" by "Reduction" or "Operations for MPI_Reduce" 5.z vv EDIT p162.13 state that the example is in Fortran (it's said for all the C examples before)
I don't see examples in this chapter that say they are in C either, or at least, there are many that don't.
5.aa DON2 EDIT p163.10-12 I think we don't need to backref to MPI-1 here if we consider MPI-2.1 a complete standard.
Ok, I've been convinced to remove this.
5.ab DON2 CLAR p163.20 replace "bit" by "numeric" or "integer" 5.ac *NO* EDIT p167.41 doubled sentence "The order of ..."
The sentence is not technically duplicated. I'll leave this text as is now, although, I agree that this paragraph could be rewritten to state its point more clearly.
5.ad DON2 CLAR p169.2 add: (without supporting the "in place" option) 5.ae DON2 ERR p169.16-20 the example will deadlock if root == groupsize-1. Has been there for a while :). Use Irecv/Wait instead. 5.af vv EDIT p171.48 state that example is in Fortran
Again, not sure if this needs to be done?
5.ag DON2 ERR p174.12-20 this rationale should be erased completely because it explains (for MPI-1), why only the inclusive is supported ;-) 5.ah DON2 ERR p175.20 erase the last sentence in rationale, we don't need this anymore (is MPI-1) 5.ai ?? EDIT p177.48 move orphaned Example header to next page (might change after edits though -> check chapter for orphans) 5.aj ?? EDIT p179.24 the font suddenly changes? (sans-serif)
Haven't checked these two in the recent document. I suppose some of the checks will need to wait until the final copy is available for reading.
5.ak ?? CLAR p179.27 maybe we should add: "and to ensure appropriate matching (for deterministic behavior)
I'll leave this one to the Forum.
Best, Torsten
participants (1)
unknown@example.com
