Re: [Mpi-21] AUTHORS: new consistent version and write-token to you
Hi Rajeev, Thanks for all of your feedback. I've made every change but two, which I think we should delay to a decision for the Forum (or at least wait to get more votes from reviewers). Rolf, Can you add the following items to some ballot to be considered by the Forum? * pg 134, ln 32-33: What does matching arguments mean? Does it mean same arguments? That's not true for the root argument of rooted collectives on the group containing the root. Maybe just delete the sentence. * pg 163, Sec 5.9.3: Delete the sentence "This is an extension to MPI-1.2, ..." since we are all one now. I've incorporated the rest of the edits Rajeev suggested and committed the new chapter. -Adam Rajeev Thakur wrote:
Adam, You have done a wonderful job of fixing the merged collectives chapter, which was a nontrivial task (and hence I didn't volunteer for it :-)). I only have some minor comments listed below.
Rajeev
* pg 133, ln 27-28: change to the plural -- "patterns of" and "do not fit"
Done.
Yes, I agree, but it's not clear to me how to clarify this point either. There's probably a clean way to explain the intent here, but I don't want to make that decision. I'll leave this in to get more input from the Forum.
* pg 136, ln 22-23: move "for intracommunicators" to the beginning of the sentence
Done.
* pg 140, ln 28: change "are using" to "use"
Done.
* pg 149, ln 45: change "are using" to "use"
Done.
* pg 154, ln 33: change "are using" to "use"
Done.
* pg 162, ln 10: change "are using" to "use"
Done.
* pg 163, Sec 5.9.3: Delete the sentence "This is an extension to MPI-1.2, ..." since we are all one now. Merge the next paragraph on heterogeneous into this one, and fix spelling of "charater" to character.
I fixed the "charater" mis-spelling and merged the paragraphs. I left the statement about MPI-1.2 for now, although I moved it so that, after merging the other paragraph, the resulting paragraph reads a little more smoothly. This statement seems to highlight an important, but subtle change. I want to get feedback from the Forum on this item.
* pg 165, ln 10: change "are using" to "use"
Done.
* pg 167, ln 38-39: Question - Do we want to also list MPI_Accumulate with a forward reference to it?
* pg 170, ln 3: change "is using" to "uses"
Done.
* pg 171, ln 38: should be "In such a case" or better "In this case"
Done.
* pg 171, ln 43: change "is using" to "uses" and "an intracommunicators" to the singular
Done.
* pg 174, ln 11: change "illegal" to "invalid"
Done.
* pg 174, ln 12-20: Delete the entire rationale. It was included in MPI-1 to justify not having an exclusive scan. Doesn't apply any more. You deleted only the last sentence, which was explicit, but the whole rationale should go.
Done.
* pg 175, ln 13-20: By the same token, delete the entire rationale here. It was used to justify adding an exclusive scan to MPI-2. Even the "no in-place version" is covered above in lin 5. Maybe you can change that line 5 to include the justification as follows: "No in-place version is supported because it is not clear what this means for the process with rank zero". Note that it should be "process with rank zero" rather than "process for rank zero" as in the current text.
I kept the rationale, because I think it provides some useful information here, but I changed it to the following: The exclusive scan is more general than the inclusive scan. Any inclusive scan operation can be achieved by using the exclusive scan and then locally combining the local contribution. Note that for non-invertable operations such as MPI_MAX, the exclusive scan cannot be computed with the inclusive scan. No in-place version is specified for MPI_EXSCAN because it is not clear what this means for the process with rank zero.
* pg 175, ln 25: change "is using" to "uses"
Done.
Rest looks great!
-----Original Message----- From: mpi-21-bounces_at_[hidden] [mailto:mpi-21-bounces_at_[hidden]] On Behalf Of Rolf Rabenseifner Sent: Saturday, April 12, 2008 10:15 AM To: MPI 2.1 Mailing List Subject: Re: [Mpi-21] AUTHORS: new consistent version and write-token to you
Hi Adam,
this is really a good merge that you have done. Good ideas and very carefully implemented.
The reviewers can see (nearly) all of your modifications in red. I expect that your reviewersand the Forum will enjoy your modifications.
I have restored two minor mods you have done: (Line numbers refer to the new file you'll get with svn update)
coll.tex, line 412 - I restored the "intracommunicator" because the categories describe the behavior only on intracommunicators, not on all, e.g., ALLGATHER has one result on intra and two on inter and the wording is "the result".
coll.tex, line 491 - restored the word "also". These routines are valid for intra and inter. Writing "apply to inter" may be interpreted that they are only valid for inter. Writing "also apply to inter" should solve this problem. I also colored this sentence red.
I hop, this isokay with you.
Best regards Rolf
On Fri, 11 Apr 2008 15:22:10 -0700 Adam Moody <moody20_at_[hidden]> wrote:
Hi Rolf, I have checked in my changes for the Collectives chapter.
It's ready to
be reviewed by the collective chapter reviewers. -Adam
Rolf Rabenseifner wrote:
write-token again to the chapter authors << - but only until Saturday 8:00 European GMT <<
Hi all authors and reviewers,
Please read this mail carfully, if you want to make any further modification of the text.
You must now call svn update to get the newest release!! We have a again a consistent version. Nearly all of
http://www.hlrs.de/mpi/mpi21/doc/MPI-2.1draft-2008-02-23-review.txt
is now implemented in the tex-source. Only a few items are still open, see statistics at the beginning.
You can view the current version (it is svn revision 92) at
http://www.hlrs.de/mpi/mpi21/doc/mpi-report.pdf
It is only today and Friday remaining for finishing MPI-2.1. I give back the write-token to the authors.
On Saturday morning European time, I take the write-token automatically on Saturday morning to build final pdf for the reviews.
As I can see, many chapter authors made fine cleaning to the text. All larger changes should be defered to MPI-2.2! Especially the merge of MPI Environment (inquiry.tex),
Misc (misc-2.tex)
and External Interfaces (ei-2.tex) to one chapter "MPI Environment and Miscellany" (with 45 pages) may be defered also to MPI-2.2.
Up to now, I was able to check most changes and they look fine.
Best regards Rolf
Dr. Rolf Rabenseifner . . . . . . . . . .. email
rabenseifner_at_[hidden]
High Performance Computing Center (HLRS) . phone
++49(0)711/685-65530
University of Stuttgart . . . . . . . . .. fax ++49(0)711
/ 685-65832
Head of Dpmt Parallel Computing . . .
www.hlrs.de/people/rabenseifner
Nobelstr. 19, D-70550 Stuttgart, Germany . (Office: Allmandring 30) _______________________________________________ mpi-21 mailing list mpi-21_at_[hidden] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-21
Dr. Rolf Rabenseifner . . . . . . . . . .. email rabenseifner_at_[hidden] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . (Office: Allmandring 30) _______________________________________________ mpi-21 mailing list mpi-21_at_[hidden] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-21
participants (1)
unknown@example.com
