Re: [Mpi-21] TODO - AUTHORS of MPI-2.1 - Workplan
Alexander, this isn't a problem: Annex A.1 is about constants: These must not change, because in this round-two, it is absolutly forbidden to change the standard content. Annex A.2-4 is done automatically, with one exception: If a whole chapter is removed or added, we must remove/add a line in MAKE-APPLANG (in lines 6-18). If a chapter title is changed, we have to modify such a line. That is all and easy, because Denis and his predecessor had made a good job. Best regards Rolf On Thu, 3 Apr 2008 20:23:46 +0100 "Supalov, Alexander" <alexander.supalov_at_[hidden]> wrote:
Hi guys,
As soon as we start moving chapters, the binding annex may change as well. I need your updates soon to make sense of the annex.
Best regards.
Alexander
-----Original Message----- From: mpi-21-bounces_at_[hidden] [mailto:mpi-21-bounces_at_[hidden]] On Behalf Of George Bosilca Sent: Thursday, April 03, 2008 9:20 PM To: MPI 2.1 Mailing List Subject: Re: [Mpi-21] TODO - AUTHORS of MPI-2.1 - Workplan
Bronis,
If the data-type section get moved into the chapter 3 it make sense to merge the leftover of the chapter 11 with chapter 7, as long as we choose a right name. "MPI Environmental Management" is not the right chapter for "Generalized Requests". But of course these are just details.
I'll get in touch with you asap to see how we can coordinate.
Thanks, george.
On Apr 3, 2008, at 12:58 PM, Bronis R. de Supinski wrote:
Rolf:
Re:
my general statements do not answer you initial question:
My opinion is that leaving obvious problems unfixed based on an expected future version is a bad idea. However, I don't want to argue over this since I think the best approach is just to remove them now and then we don't have to worry about them. Others have more concerns over the time that they can devote to this (not that I have an abundance) and might want to delay in any event in order to get it right (at least mostly).
If you decide to move parts from Chap.11 to Chap.7, then you both mus discuss this. You both are responsible for these chapters. And you should first convince your reviewers: - Chap. 7: Rich, Jesper, Steve, Kannan, David, Bill - Chap.11: Bill and Rainer My recommendation: Express clearly which parts should be moved exactly to wich line (all based on page/line numbers as **printed** in Draft Apr. 1, 2008).
I have discussed moving the datatype decoding stuff with Rich and Bill. I will move those sections as I suggested, with an initial pass for the current review. This works well for Rich since he does not have time to do this for another couple of weeks. I hope to get that done today.
For the remainder, I will look over the two chapters (7 & 11) and propose an initial merge strategy. George can react to that; I don't know how long it will take me to get that done...
Bronis
_______________________________________________ mpi-21 mailing list mpi-21_at_[hidden] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-21
--------------------------------------------------------------------- Intel GmbH Dornacher Strasse 1 85622 Feldkirchen/Muenchen Germany Sitz der Gesellschaft: Feldkirchen bei Muenchen Geschaeftsfuehrer: Douglas Lusk, Peter Gleissner, Hannes Schwaderer Registergericht: Muenchen HRB 47456 Ust.-IdNr. VAT Registration No.: DE129385895 Citibank Frankfurt (BLZ 502 109 00) 600119052
This e-mail and any attachments may contain confidential material for the sole use of the intended recipient(s). Any review or distribution by others is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
Dr. Rolf Rabenseifner . . . . . . . . . .. email rabenseifner_at_[hidden] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . (Office: Allmandring 30)
participants (1)
unknown@example.com
