Re: [Mpi-21] AUTHORS+REVIEWERS - Draft Apr. 12, 2008
Hi Rolf, Adam, I understand from your mail Rolf, that Adam lost his write token and that only you can apply the changes/comments to the chapter (in my case the collectives chapter). Thus, I'll send my review results to the list instead the chapter author directly. My general comment: very well done Adam :). I have some smaller editing remarks and also found some small errors and clarification possibilities (see below).
---------------------------------------------------------------------------------- 1234567890123456789012345678901234567890123456789012345678901234567890123456789012 All references are based on MPI-2.1 Draft Apr. 12, 2008 ww.a __ pnnn.ll text (with nnn=page number and ll=line number text continued ... ww.b __ pnnn.ll text ... and so on (total line length <= 82 characters.) ---------------------------------------------------------------------------------- Ok, here my remarks, many of them (especially EDIT or CLAR) can probably be ignored, but I thought I'd bring it up:
general: the line numbers are completely out of sync ... it's hard to classify a line that is between two line numbers. 5.a EDIT p129.19-41 "all group members" vs. "all members of a group" should use the same phrasing (parallel structure) 5.b NICE p129.41 Reference to 5.11 not 5.11.1 5.c EDIT p129.45 remove "," (comma) 5.d EDIT p129.43 replace "the same" with "a" 5.e EDIT p129.45 "the same group" in line 43 conflicts with "group or groups" 5.f CLAR p131.1 add "with exceptions stated in the following" to first sentence 5.g EDIT p131.4 no linebreak (Chapter~\ref{...}) 5.h ERR p131.31 replace "will" with "might" 5.i ERR p132. "special communicator must be created" this is wrong, later (in the bcast section) it is stated differently ... I would just remove this part of the advice or say "might be created" (see Bcast advice) 5.j CLAR p131.37 add "depending on the operation performed after last sentence (right now it sounds like ths user is free to choose which argument to replace) 5.k EDIT p133.32 "a" -> "an"? 5.l EDIT p136.22 start sentence with "If the communicator is an intracommunicator" as for all the other operations, remove "for intracommunicators" in line 23 5.m EDIT p136.24 replace "," by "and" 5.n EDIT p136.26-31 this paragraph is redundant (it's all already stated earlier, do we want this redundancy in the standard?) 5.o EDIT p136.32 move sentence to end of the previous paragraph (line 25) 5.p EDIT p136.37 "data is braodcasted" (not braodcast) 5.q CLAR p136.38-39 the text talks about send and receive buffer argument, but bcast only has a single buffer argument ... 5.r CLAR p136.38 "must be consistent with the ..." what does the word consistent mean in this context? This seems undefined. I think it means that the signature (size, count) is the same. We should say this explicitely. The same term "consistent" is used in all following operations (I'm not going to add it again) 5.s EDIT p138.3 write "all processes" instead of "process i" (i is never defined) 5.t ERR p139.47 data is not necessarily placed in rank order. The order is freely definably by the user in the displs[] array. Or does the standard enforce the displs[] array to preserve order? We might want to run this through the forum (or just ignore it?)? 5.u CLAR p136.42 add "The examples in this section are using intracommunicators." as in p140.27 5.v EDIT p147.48 the last paragraph is redundant (has been stated before for all collectives) 5.w EDIT p157.35 why a separate subsection for Alltoallw but not for Alltoallv? I'd remove this subsection 5.x EDIT p157.36 the first two sentences should go to rationale (we don't need to rationalize the operation in the description) 5.y EDIT p161.13 replace "Reduce" by "Reduction" or "Operations for MPI_Reduce" 5.z EDIT p162.13 state that the example is in Fortran (it's said for all the C examples before) 5.aa EDIT p163.10-12 I think we don't need to backref to MPI-1 here if we consider MPI-2.1 a complete standard. 5.ab CLAR p163.20 replace "bit" by "numeric" or "integer" 5.ac EDIT p167.41 doubled sentence "The order of ..." 5.ad CLAR p169.2 add: (without supporting the "in place" option) 5.ae ERR p169.16-20 the example will deadlock if root == groupsize-1. Has been there for a while :). Use Irecv/Wait instead. 5.af EDIT p171.48 state that example is in Fortran 5.ag ERR p174.12-20 this rationale should be erased completely because it explains (for MPI-1), why only the inclusive is supported ;-) 5.ah ERR p175.20 erase the last sentence in rationale, we don't need this anymore (is MPI-1) 5.ai EDIT p177.48 move orphaned Example header to next page (might change after edits though -> check chapter for orphans) 5.aj EDIT p179.24 the font suddenly changes? (sans-serif) 5.ak CLAR p179.27 maybe we should add: "and to ensure appropriate matching (for deterministic behavior) Best, Torsten -- bash$ :(){ :|:&};: --------------------- http://www.unixer.de/ ----- Indiana University | http://www.indiana.edu Open Systems Lab | http://osl.iu.edu/ 150 S. Woodlawn Ave. | Bloomington, IN, 474045-7104 | USA Lindley Hall Room 135 | +01 (812) 855-3608
participants (1)
unknown@example.com
