Re: [mpi-21] MPI_GET_PROCESSOR_NAME Fortran and C
This is a discussion-point for MPI 2.1, Ballot 4. This is a follow up to: MPI_GET_PROCESSOR_NAME and Fortran in http://www.cs.uiuc.edu/homes/wgropp/projects/parallel/MPI/mpi-errata/index.h... with mail discussion in http://www.cs.uiuc.edu/homes/wgropp/projects/parallel/MPI/mpi-errata/discuss... _________________________________________________________________ MPI_GET_PROCESSOR_NAME and Fortran and in C and all MPI_xxxx_GET_NAME routines ------------------------------------------- Summary: Returning strings is defined in MPI_GET_PROCESSOR_NAME and MPI_xxxx_GET_NAME quite different. Not all implementations are doing the same with zero-filling. And what they do is at least with MPI_GET_PROCESSOR_NAME different to what the current standard requires. A propose to adapt the standard to the common reasonable implementations. The very short proposal for clarification can be found at the end of this text, see C. Proposal. A. MPI_GET_PROCESSOR_NAME ------------------------- MPI_GET_PROCESSOR_NAME defines the returned string with several sentences: (1) OUT name A unique specifier for the actual (as opposed to virtual) node. (2) OUT resultlen Length (in printable characters) of the result returned in name (3) The argument name must represent storage that is at least MPI_MAX_PROCESSOR_NAME characters long. (4) MPI_GET_PROCESSOR_NAME may write up to this many characters into name. (5) The number of characters actually written is returned in the output argument, resultlen. (6) The user must provide at least MPI_MAX_PROCESSOR_NAME space to write the processor name processor names can be this long. (7) The user should examine the ouput argument, resultlen, to determine the actual length of the name. I tested 5 implementations with C and Fortran. I called MPI_GET_PROCESSOR_NAME with a string (i.e. character array) with size MPI_MAX_PROCESSOR_NAME+2. C-Interface: ------------ All tested C implementations returned the processor-name in name[0..resultlen-1] and a the non-printable character \0 in name[resultlen]. All other elements of name were unchanged. (1,2,3,4, 6,7) are fulfilled; (5) are __NOT__ fulfilled, because resultlen+1 characters are written in name. My opinion: The returned name and resultlen is what the user expects, but the standard needs a clarification. Fortran-Interface: ------------------ All tested Fortran implementations return in processor-name in name(1:resultlen) and the rest of the total string is filled with spaces. (1, 3, 6,7) are fulfilled; (2,4,5) are __NOT__ fulfilled, because MPI_MAX_PROCESSOR_NAME+2 characters are written in name. My opinion: The returned name and resultlen is what the user expects, but the standard needs a clarification. B. MPI_COMM_GET_NAME (and other MPI_xxxx_GET_NAME) -------------------------------------------------- The string output is defined with different wording: (1) OUT comm_name the name previously stored on the communicator, or an empty string if no such name exists (string) (2) OUT resultlen length of returned name (integer) (3) name should be allocated so that it can hold a resulting string of length MPI_MAX_OBJECT_NAME characters. (4) If the user has not associated a name with a communicator, or an error occurs, MPI_COMM_GET_NAME will return an empty string (all spaces in Fortran, "" in C and C++). and in the definition of MPI_COMM_SET_NAME: (5) The length of the name which can be stored is limited to the value of MPI_MAX_OBJECT_NAME in Fortran and MPI_MAX_OBJECT_NAME-1 in C and C++ to allow for the null terminator. (6) Attempts to put names longer than this will result in truncation of the name. (7) MPI_MAX_OBJECT_NAME must have a value of at least 64. I called MPI_COMM_GET_NAME with a string (i.e. character array) with size MPI_MAX_OBJECT_NAME+2. C-Interface: ------------ All tested C implementations returned the communicator-name in comm_name[0..resultlen-1] and a the non-printable character \0 in comm_name[resultlen]. One implementation filled up the rest until name[MPI_MAX_OBJECT_NAME-1] with \0. In all other implementations, all other elements of comm_name were unchanged. (1-7) are fulfilled although the retuned zero-filling in comm_name depends on the implementations; My opinion: A clarification can make the API unambiguous. Fortran-Interface: ------------------ All tested Fortran implementations return in processor-name in name(1:resultlen) and the rest of the total string is filled with spaces. (1-7) are fulfilled; Although it is nowhere specified that the string must be filled up with spaces, and not only until position MPI_MAX_OBJECT_NAME but also further spaces until the end of comm_name. My opinion: The returned name and resultlen is what the user expects, but the standard needs a clarification. C. Proposal: ------------ Add the following sentences to the current interface definitions: ------------------ In C, a \0 is additionally stored at name[resultlen]. resultlen cannot be larger then MPI_MAX_PROCESSOR_NAME-1 (or MPI_MAX_OBJECT_NAME-1). In Fortran, name(resultlen+1:) is filled with spaces. resultlen cannot be larger then MPI_MAX_PROCESSOR_NAME (or MPI_MAX_OBJECT_NAME). ------------------ Typo correction: ---------------- MPI-1.1 Sect. 7.1, page 193, beginning of line 29 reads examine the ouput argument But should read (additional t in output) examine the output argument Okay? _________________________________________________________________ Best regards Rolf PS: Attached my tests and short protocols Dr. Rolf Rabenseifner . . . . . . . . . .. email rabenseifner_at_[hidden] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . (Office: Allmandring 30) *
participants (1)
unknown@example.com
