Re: [Mpi-21] TODO - AUTHORS of MPI-2.1 - Workplan
I hate to throw up another red flag, but as I was paging through the doc, I was wondering if Chapter 13 (C++/F90) should go away, and have all that content merged elsewhere in the doc: - most would go to Terms and Conventions - some would go to Point-to-Point Communication (e.g., the stuff about Comm::Clone() and friends) - ...etc. I can make a specific proposal about this, but would want some feedback that people generally thought it was a good idea first. On Apr 2, 2008, at 5:14 PM, Bronis R. de Supinski wrote:
Rolf:
I have not gone through Chapter 11 thoroughly yet but I have already noticed some major changes that I would suggest.
First Section 11.6: "Decoding a Datatype" seems out of place in the merged document. It would make sense to me to have all of the datatype functions together. If we don't make datatypes a separate chapter, then this section (11.6) should be moved into chapter 3, near section 3.12: "Derived Datatypes". Ideally, it would be merged into that section since it is clearly part of that functionality.
Second, Section 11.5: "Error Classes, Error Codes, and Error Handlers" is strongly related to Section 7.3: "Error Handling", and Section 7.4: "Error Codes and Classes". Clearly, these sections should be merged. In fact, this overlap makes me ask why have we not merged Chapters 7 and 11? What is the difference between "Environmental Management" and "External Interfaces"?
I think this question needs to be resolved before I go further on working on Chapter 11. Perhaps George and I should coordinate merging these chapters after I coordinate moving the datatype decoding functionality into chapter 3 with Rich...
Bronis
On Wed, 2 Apr 2008, Bronis R. de Supinski wrote:
Rolf:
I have finished editing chapter 14: Profiling. I have attached the modified prof.tex since I do not yet have write access. More importantly, either there is a problem with the 2.1 macros or I am doing something wrong (I think it is the first but I am not LaTex fluent enough to be certain). Specifically, the first letter of the word following the end markers does not appear in the generated PDF. I would appreciate it if you could look into which it is.
Another observation is that the macro does not work around empty sections. In particular, I tried to mark the section that I moved with the macros, with the original text commented out. I tried to do the same for some MPI-1.0 text that was contradictory to or redundant with the text that I moved. Having those empty macro regions caused the compile to fail. It might be nice to have some way to flag the deleted text, with the convention, at least for now, of just commenting it out and not to delete it entirely from the file.
Let me know if I am doing things right here and then I will move on to fixing chapter 11: External Interfaces. Thanks,
Bronis
On Wed, 2 Apr 2008, Rolf Rabenseifner wrote:
Dear Bill, Tony, Rich, Adam, Dick, Jesper, George, David, Bronis, Rajeev, Jeff, and Alexander,
you are responsible for one ore more chapters of MPI-2.1 until the meeting.
It is a tough schedule: -----------------------
* Tues, April 1, my ROUND ONE is finished and the write token is logically passed to all chapter authors: - You have read access to the source (via SVN) and the pdf. - You have write access to your local SVN copy. - You will get write access to the SVN in a few days. * Fri., April 11, chapter authors have finished ROUND TWO. - This is a hard deadline (because I've to go on travel) * Sat., April 12, I will produce mpi-report.pdf as basis for review (I cannot do later, because April 14-17, I'm on travel) * Mon.-Thu., April 14-17, strong review by the reviewer group * Fri., April 18, reviews - if necessary must be included - by the chapter authors * Sat., April 19, I will produce final mpi-report.pdf which is basis for - final reviews through the reviewer group - official reading at the April 28-30, 2008 meeting. (I cannot do later because I'm on travel April 20-26)
The goals of your work as chapter author: -----------------------------------------
- Remove references to MPI-1 and MPI-2. - Substitute by MPI. - Necessary modifications to achieve this goal.
With this, we should have a single MPI-2.1 standard that does not "know" the MPI-1 or MPI-2 history of individual functions.
** This should be mainly a task in the area of chapter- introductions. ** Please, never change the wording of function definitions.
Exceptions: - There are routines that are deprecated and that are already referenced in a consistent way. My recommendation: Current wording: There are *new* function, and existing are now deprecated. Proposal: There are functions, and there exist also deprecated functions with (nearly) same functionality but deprecated due to some lack in the bindings (or functionality) - There is history information in the frontmatter. - there is a change-log annex with limited memory (only previous version)
Technical editing rule: -----------------------
You must identify all of your changes:
a) new/modified wording - you are highlighting your new/modified wording with:
\mpiiidotiMergeNEWforSINGLEbegin% MPI-2.1 round-two - begin of modification .... your modified / new wording .... \mpiiidotiMergeNEWforSINGLEendI% MPI-2.1 round-two - end of modification
b) Moved paragraphs, sentences, ... - you are highlighting the first word of the moved text with:
\mpiiidotiMergeNEWforSINGLEbegin% MPI-2.1 round-two - begin of text-move First-word \mpiiidotiMergeNEWforSINGLEendI% MPI-2.1 round-two - ongoing text- move ... rest of the moved text.... % MPI-2.1 round-two - end of text-move
Caution: These macros work only in black parts of the text.
In blue parts you must substitute \mpiiidotiMergeNEWforSINGLEendI% by \mpiiidotiMergeNEWforSINGLEendII%
The highlighting is done with red color. (There are only a few other sentences from me magenta. Therefore red should be the best to highlight the round-two modifications.)
Rsponsibilities: ----------------
* Frontmatter mpi-report.tex Bill Gropp * Acknowledgements credits.tex Rich Graham(text) + Rolf(emails-auth.) * 1. Introduction intro.tex Bill Gropp - 2. Terms terms-2.tex Tony Skjellum * 3. Point-to-point pt2pt.tex Rich Graham * 4. Collectives coll.tex Adam Moody * 5. Groups, etc. context.tex Dick Treumann - 6. Toplogies topol.tex Jesper Traeff * 7. Environment inquiry.tex George Bosilca - 8. Miscellany misc-2.tex Jesper Traeff - 9. Process Crea... dynamic-2.tex David Solt - 10. One-sided Comm one-sided-2.tex Jepser Traeff - 11. External Int. ei-2.tex Bronis de Supinski - 12. IO io-2.tex Rajeev Thakur - 13. Lang.Binding binding-2.tex Jeff Squyres - 14. Profiling prof.tex Bronis de Supinski - 15. Deprecated deprecated.tex Rolf Rabenseifner - Annex A Lang.Bind. appLang*.tex, MAKE-APPLANG Alexander Supalov - Annex B Change-log changes.tex Rolf Rabenseifner - Bibliography refs.bib Bill Gropp - Index MAKE-FUNC-INDEX Rolf Rabenseifner
Legende: - Chapter is mainly taken from MPI-1.1 or MPI-2.0, only small work expected * There was a significant merge, or new text, or ..., more work expected
I wish you a good start and good luck with your chapter.
Best regards Rolf
Dr. Rolf Rabenseifner . . . . . . . . . .. email rabenseifner_at_[hidden] High Performance Computing Center (HLRS) . phone + +49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/ rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . (Office: Allmandring 30)
-- Jeff Squyres Cisco Systems
participants (1)
unknown@example.com
