Re: [mpi-21] Ballot 4 - RE: clarification text for MPI_Reduce_scatter
The only change needed here is that the following sentence on ln 19, pg 163, MPI 2.0 should be deleted: "Note that the area occupied by the input data may be either longer or shorter than the data filled by the output data." The sentence makes no sense because the input data can never be shorter than the output data. The output, determined by recvcounts[i], is a subset of the input. Rajeev
-----Original Message----- From: Rolf Rabenseifner [mailto:rabenseifner_at_[hidden]] Sent: Tuesday, January 29, 2008 4:44 AM To: mpi-21_at_[hidden] Cc: Rajeev Thakur Subject: Ballot 4 - RE: clarification text for MPI_Reduce_scatter
This is a follow-up for MPI 2.1, Ballot 4.
I'm asking especially Rajeev Thakur, the participant of the email-discussion in 2002, to review this proposal.
I would finish the following track without any proposed clarification, because the text is already clear when the MPI-1.1 part of MPI_Reduce_scatter is put in front of the MPI-2.0 part, i.e., in the upcoming combined document MPI-2.1.
This is a follow up to: MPI_IN_PLACE for MPI_Reduce_scatter in http://www.cs.uiuc.edu/homes/wgropp/projects/parallel/MPI/mpi- errata/index.html with mail discussion in
http://www.cs.uiuc.edu/homes/wgropp/projects/parallel/MPI/mpi- errata/discuss/redscat/ ___________________________________
The currently text in http://www.cs.uiuc.edu/homes/wgropp/projects/parallel/MPI/mpi- errata/index.html should not be accepted, because it is a significant modification of the MPI-2.0 standard and would break user code:
Proposed text to replace lines 16-20, pg 163 The "in place" option for intracommunicators is specified by passing MPI_IN_PLACE in the sendbuf argument. In this case, on each process, the input data is taken from recvbuf. Process i gets the ith segment of the result, and it is stored at the location corresponding to segment i in recvbuf. ___________________________________
Best regards Rolf
Dr. Rolf Rabenseifner . . . . . . . . . .. email rabenseifner_at_[hidden] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . (Office: Allmandring 30)
participants (1)
unknown@example.com
