I have committed the changes to the language bindings chapter (r75). ------------- I had two questions about Rolf's list for chapter 13: JMS WHY IS THIS AN MPI-2.2 ISSUE? 32.r 22 p463.17-18: Delete first sentence; delete "In MPI-2," JMS WHY IS THIS A QUESTION MARK? 32.v ? p470.46: Change sentence from: "It is important to note that all C++ objects and their corresponding C handles..." to "It is important to note that all C++ objects with corresponding C handles..." I.e., this sentence is referring only to C++ handles that actually have corresponding C handles (e.g., not MPI::ERRORS_THROW_EXCEPTIONS). ------------- One answer to a question in Rolf's list: JMS THE NAMES THAT ARE THERE ARE GOOD 32.j' ? Which names should be visible in the Index for Dup and Clone? ------------- And here's the items that I completed: JMS DONE 32.a R2 p437.18: Delete first sentence of paragraph Editor's comment: Please check the "this interface" in the next sentence. This is a backward reference to the first sentence. JMS DONE 32.b R2 p437.22: Delete "original" Editor's comment: Please check "original ... was based". Removing "original" may need further corrections. JMS DONE 32.c R2 p437.24-29: Delete first and last sentences of paragraph Editor's comment: See also Review item 28.q JMS DONE 32.d R2 p437.29: New last sentence, "See Annex A.4.19 for a function cross reference." JMS DONE 32.e R2 p438.11: Delete "for MPI-1" JMS DONE 32.f R2 p438.14-37: Join the two namespaces together and delete the "Additionally, the following classes defined for MPI-2:" text. Re-sort the class names as appropriate. JMS DONE 32.g R2 p439.2: Delete last sentence ("To maintain ... in [23].") JMS DONE 32.k R2 p445.36-38: Remove this entire paragraph ("Compilers that do not support..."). This feature has been a part of C++ since C+ +98, and exists in all modern C++ compilers. JMS DONE 32.p *NO* p459.11-15: Delete paragraph Editor's comment: The first MPI-1 should be substituted by MPI, the second MPI-1 should be removed. The paragraph is still valid. JMS CHANGED MPI-1 to MPI 32.q *NO* p462.43-45: Delete paragraph Editor's comment: The paragraph is still valid. -- Jeff Squyres Cisco Systems
participants (1)
unknown@example.com
