Re: [mpi-21] MPI_GET_PROCESSOR_NAME Fortran and C
Agreed - the migration and checkpoint/restart issues are already clear in MPI 1.1 Dick Treumann - MPI Team/TCEM IBM Systems & Technology Group Dept 0lva / MS P963 -- 2455 South Road -- Poughkeepsie, NY 12601 Tele (845) 433-7846 Fax (845) 433-8363 mpi-21-bounces_at_[hidden] wrote on 01/28/2008 03:24:32 AM:
Dick,
your right and it is already decided: MPI 1.1 Sect. 7.1 page 193, lines 13-14: "This routine returns the name of the processor on which it was called at the moment of the call." And lines 22-25: "Rationale. This function allows MPI implementations that do process migration to return the current processor. Note that nothing in MPI requires or defines process migration; this definition of MPI GET PROCESSOR NAME simply allows such an implementation. (End of rationale.)"
I.e., current location, i.e., it may change in case of check point/restart and all the other reasons you mentioned.
I would say, that the sentences above are clear enough.
Okay?
Best regards Rolf
On Fri, 25 Jan 2008 15:32:07 -0500 Richard Treumann <treumann_at_[hidden]> wrote:
We also should decide whether every call to MPI_GET_PROCESSOR_NAME across the life of the task must return the same name. On very large machines running very large jobs, migration of some tasks off of failing nodes and on to robust nodes will become more interesting. Checkpoint/restart raises the same issue. A restarted job will probably not have the same task to node mapping.
We can either require the name to remain constant and allow that it might be a "virtual" name or require that it return an "actual" name but allow it to change.
Dick
mpi-21-bounces_at_[hidden] wrote on 01/25/2008 12:00:42 PM:
This is a discussion-point for MPI 2.1, Ballot 4.
This is a follow up to: MPI_GET_PROCESSOR_NAME and Fortran in http://www.cs.uiuc.edu/homes/wgropp/projects/parallel/MPI/mpi- errata/index.html with mail discussion in http://www.cs.uiuc.edu/homes/wgropp/projects/parallel/MPI/mpi- errata/discuss/procname/
_________________________________________________________________
MPI_GET_PROCESSOR_NAME and Fortran and in C and all MPI_xxxx_GET_NAME routines -------------------------------------------
Summary: Returning strings is defined in MPI_GET_PROCESSOR_NAME and MPI_xxxx_GET_NAME quite different. Not all implementations are doing the same with zero-filling. And what they do is at least with MPI_GET_PROCESSOR_NAME different to what the current standard requires. A propose to adapt the standard to the common reasonable implementations. The very short proposal for clarification can be found at the end of this text, see C. Proposal.
A. MPI_GET_PROCESSOR_NAME ... B. MPI_COMM_GET_NAME (and other MPI_xxxx_GET_NAME) ... C. Proposal: ------------
Add the following sentences to the current interface definitions: ------------------ In C, a \0 is additionally stored at name[resultlen]. resultlen cannot be larger then MPI_MAX_PROCESSOR_NAME-1 (or MPI_MAX_OBJECT_NAME-1). In Fortran, name(resultlen+1:) is filled with spaces. resultlen cannot be larger then MPI_MAX_PROCESSOR_NAME (or MPI_MAX_OBJECT_NAME). ------------------
Typo correction: ---------------- MPI-1.1 Sect. 7.1, page 193, beginning of line 29 reads examine the ouput argument But should read (additional t in output) examine the output argument
Okay? _________________________________________________________________
Best regards Rolf
PS: Attached my tests and short protocols
Dr. Rolf Rabenseifner . . . . . . . . . .. email rabenseifner_at_[hidden] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . (Office: Allmandring 30) [attachment "mpi_get_xxx_name.tar.gz" deleted by Richard Treumann/Poughkeepsie/IBM]
mpi-21 mailing list mpi-21_at_[hidden] http://lists.cs.uiuc.edu/mailman/listinfo/mpi-21
Dr. Rolf Rabenseifner . . . . . . . . . .. email rabenseifner_at_[hidden] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . (Office: Allmandring 30) _______________________________________________ mpi-21 mailing list mpi-21_at_[hidden] http://lists.cs.uiuc.edu/mailman/listinfo/mpi-21
participants (1)
unknown@example.com
