Re: [mpi-21] Ballot 4 - 0-dim MPI_CART_CREATE and MPI_CART_SUB
On Thu, 24 Jan 2008 21:26:09 +0800 "William Yu" <wyu_at_[hidden]> wrote:
Understood. Nice work. Thanks!
Thank you. And here is the proposal to correct all the unclear specifications on Cartesian topologies. This is a proposal for MPI 2.1, Ballot 4. ________________________________________________________________ Proposal about handling zero-dimensional Cartesian communicators that are produced with MPI_Cart_sub if all remain_dims are false. MPI-1.1 Sect.6.5.4, page 187, lines 38-42 (definition of MPI_Cart_sub) reads If a cartesian topology has been created with MPI_CART_CREATE, the function MPI_CART_SUB can be used to partition the communicator group into subgroups that form lower-dimensional cartesian subgrids, and to build for each subgroup a communicator with the associated subgrid cartesian topology. (This function is closely related to MPI_COMM_SPLIT.) but should read If a cartesian topology has been created with MPI_CART_CREATE, the function MPI_CART_SUB can be used to partition the communicator group into subgroups that form lower-dimensional cartesian subgrids, and to build for each subgroup a communicator with the associated subgrid cartesian topology. If all entries in remain_dims are false or comm is already associated with a zero-dimensional Cartesian topology then newcomm is associated with a zero-dimensional Cartesian topology. (This function is closely related to MPI_COMM_SPLIT.) Rationale for this clarification (not to be included into the MPI standard): Several MPI implementations have implemented the MPI-1 standard which requires a "lower-dimensional cartesian" subgrid and that newcomm is "associated" with the "subgrid Cartesian topology". Other MPI implementations did not or only partially. Therefore, a clarification may help that all MPI implementations implment the same interface. ________________________ MPI-1.1 Sect.6.5.4, page 183, lines 29-30 (definition of MPI_Cartdim_get and MPI_Cart_get) reads: The functions MPI_CARTDIM_GET and MPI_CART_GET return the cartesian topology information that was associated with a communicator by MPI_CART_CREATE. but should read The functions MPI_CARTDIM_GET and MPI_CART_GET return the cartesian topology information that was associated with a communicator by MPI_CART_CREATE. If comm is associated with a zero-dimensional Cartesian topology, MPI_Cartdim_get returns ndims=0 and MPI_Cart_get will keep all output arguments unchanged. Rationale for this clarification (not to be included into the MPI standard): Zero-dimensional topologies have zero coords, i.e., do not have coords and therefore also no dims, or periods. ________________________ MPI-1.1 Sect.6.5.4, page 184, lines 17-23 (definition of MPI_Cart_rank) reads For a process group with cartesian structure, the function MPI_CART_RANK translates the logical process coordinates to process ranks as they are used by the point-to-point routines. For dimension i with periods(i) = true, if the coordinate, coords(i), is out of range, that is, coords(i) < 0 or coords(i) >= dims(i), it is shifted back to the interval 0 <= coords(i) < dims(i) automatically. Out-of-range coordinates are erroneous for non-periodic dimensions. but should read For a process group with cartesian structure, the function MPI_CART_RANK translates the logical process coordinates to process ranks as they are used by the point-to-point routines. For dimension i with periods(i) = true, if the coordinate, coords(i), is out of range, that is, coords(i) < 0 or coords(i) >= dims(i), it is shifted back to the interval 0 <= coords(i) < dims(i) automatically. Out-of-range coordinates are erroneous for non-periodic dimensions. If comm is associated with a zero-dimensional Cartesian topology, coord is not significant and 0 is returned in rank. Rationale for this clarification (not to be included into the MPI standard): Zero-dimensional topologies have zero coords, i.e., do not have coords. The communicator has only one process and therefore only the rank 0 is valid. ________________________ MPI-1.1 Sect.6.5.4, page 184, lines 38-39 (definition of MPI_Cart_coords) reads The inverse mapping, rank-to-coordinates translation is provided by MPI CART COORDS. but should read The inverse mapping, rank-to-coordinates translation is provided by MPI CART COORDS. If comm is associated with a zero-dimensional Cartesian topology, coords will be unchanged. Rationale for this clarification (not to be included into the MPI standard): Zero-dimensional topologies have zero coords, i.e., do not have coords. ________________________ Alternative 1: -------------- MPI-1.1 Sect.6.5.5, page 186, after line 47 (end of definition of MPI_Cart_shift), the following paragraph is added: It is erroneous to call MPI_CART_SHIFT with comm that is associated with a zero-dimensional Cartesian topology. Rationale for this clarification (not to be included into the MPI standard): It is impossible to define a correct input for direction because there does not exist any directions in a zero-dimensional topology. (This is currently implemented by several MPI implementations.) Alternative 2: -------------- MPI-1.1 Sect.6.5.5, page 186, after line 47 (end of definition of MPI_Cart_shift), the following paragraph is added: If comm is associated with a zero-dimensional Cartesian topology, then the input arguments direction and disp are ignored and always MPI_PROC_NULL is returned in rank_source and rank_dest. Rationale for this clarification (not to be included into the MPI standard): It is impossible to define a correct input for direction because there does not exist any directions in a zero-dimensional topology. For convenience, the routine returns MPI_PROC_NULL. _______________________ MPI-1.1 Sect.6.5.1, page 179, lines 29-30 (end of definition of MPI_Cart_create) reads The call is erroneous if it specifies a grid that is larger than the group size. but should read The call is erroneous if it specifies a grid that is larger than the group size or ndims is zero or negative. Rationale for this clarification (not to be included into the MPI standard): Although it is allowed to produce zero-dimensional subgrids with MPI_CART_SUB, it makes no sense to establish a zero-dimensional grid a priori with MPI_CART_CREATE. _______________________ MPI-1.1 Sect.6.5.4, page 184, lines 30 (definition of MPI_Cart_coords) reads IN maxdims length of vector coord in the calling program (integer) but should read (missing s at coords) IN maxdims length of vector coords in the calling program (integer) Rationale for this clarification (not to be included into the MPI standard): Typo. _______________________ Best regards Rolf Rabenseifner PS: All background informations with reports from 5 different MPI implementations and their differences have been in my previous mail on Wed, 23 Jan 2008 18:42:43. Dr. Rolf Rabenseifner . . . . . . . . . .. email rabenseifner_at_[hidden] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . (Office: Allmandring 30)
participants (1)
unknown@example.com
