Re: [Mpi-21] TODO - AUTHORS of MPI-2.1 - Workplan
About Chap. 13, especially C++. I'm proposing (referencec to MPI-2.1 Draft Apr.1, 2008): - The MPI-2 Forum decided to put only small overview stuff into Chap. 2 Terms. (I want to recall, that in MPI-2 the Terms are rewritten for whole MPI, i.e., still valid in MPI-2.1) - The MPI-2 Forum decided to put all deeper information into extra sections of an additionally last chapter on Bindings. - The MPI-2 Forum already decided that normal C++ bindings should be after the Fortran bindings. - Terms, page 18, lines 36-39 clearly expresses, that all constants are given only in MPI_ notation and that C++ names (with MPI::) are given in Annex A. I.e., MPI_COMM_WORLD, MPI_FLOAT, MPI_PROC_NULL, ... should not to be translated everywhere in the chapters. Same for Table 3.2 on page 27. - There are important things were C++ clearly differs from C, e.g. the handling of the Status. I have already added the Status handling, see page 31 lines 23-32. (By the way, this information was missing in Chap. 13.1 and only available in the Annex A.) - I'm not aware, whether there are more such stuff, that is explained for C and Fortran and should be also explained for C++. Do you see an additional stuff like status? - I do not expect that it would be a good idee to move all the ugly Fortran problems (17 pages) to the beginning of thee book into Chap. 2 Terms. I would recommend same rule for C++ (12 pages). Chap.2 terms has only 16 pages - with 2 pages dedicated to Fortran, 1/2 page to C, and 3 pages to C++. Best regards Rolf On Thu, 3 Apr 2008 15:13:10 -0400 Jeff Squyres <jsquyres_at_[hidden]> wrote:
On Apr 3, 2008, at 12:09 PM, Rolf Rabenseifner wrote: ...
For me, the answer may have implications on how separate or integrated additional bindings should be integrated into the language independent text of the MPI standard.
I don't quite understand. All officially-supported language bindings should be listed consistently in the standard. In MPI-2.1, for example, that means alongside the language neutral bindings in the text and in Annex A.
------------- On Thu, 3 Apr 2008 15:27:08 -0400 Jeff Squyres <jsquyres_at_[hidden]> wrote:
What about the C++/Fortran language bindings text? Should the majority of chapter 13 be merged into Terms and Conventions (and elsewhere)?
It's not really a "problem", per se -- but it is a little awkward. There are sections in chapter 13 that could definitely fit in existing text elsewhere. Some of it is redundant, too.
On Apr 3, 2008, at 3:19 PM, George Bosilca wrote:
Bronis,
If the data-type section get moved into the chapter 3 it make sense to merge the leftover of the chapter 11 with chapter 7, as long as we choose a right name. "MPI Environmental Management" is not the right chapter for "Generalized Requests". But of course these are just details.
I'll get in touch with you asap to see how we can coordinate.
Thanks, george.
On Apr 3, 2008, at 12:58 PM, Bronis R. de Supinski wrote:
Rolf:
Re:
my general statements do not answer you initial question:
My opinion is that leaving obvious problems unfixed based on an expected future version is a bad idea. However, I don't want to argue over this since I think the best approach is just to remove them now and then we don't have to worry about them. Others have more concerns over the time that they can devote to this (not that I have an abundance) and might want to delay in any event in order to get it right (at least mostly).
If you decide to move parts from Chap.11 to Chap.7, then you both mus discuss this. You both are responsible for these chapters. And you should first convince your reviewers: - Chap. 7: Rich, Jesper, Steve, Kannan, David, Bill - Chap.11: Bill and Rainer My recommendation: Express clearly which parts should be moved exactly to wich line (all based on page/line numbers as **printed** in Draft Apr. 1, 2008).
I have discussed moving the datatype decoding stuff with Rich and Bill. I will move those sections as I suggested, with an initial pass for the current review. This works well for Rich since he does not have time to do this for another couple of weeks. I hope to get that done today.
For the remainder, I will look over the two chapters (7 & 11) and propose an initial merge strategy. George can react to that; I don't know how long it will take me to get that done...
Bronis
_______________________________________________ mpi-21 mailing list mpi-21_at_[hidden] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-21
-- Jeff Squyres Cisco Systems
Dr. Rolf Rabenseifner . . . . . . . . . .. email rabenseifner_at_[hidden] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . (Office: Allmandring 30)
participants (1)
unknown@example.com
