Re: [Mpi-21] AUTHORS: new consistent version and write-token to you
Hi Adam, this is really a good merge that you have done. Good ideas and very carefully implemented. The reviewers can see (nearly) all of your modifications in red. I expect that your reviewersand the Forum will enjoy your modifications. I have restored two minor mods you have done: (Line numbers refer to the new file you'll get with svn update) coll.tex, line 412 - I restored the "intracommunicator" because the categories describe the behavior only on intracommunicators, not on all, e.g., ALLGATHER has one result on intra and two on inter and the wording is "the result". coll.tex, line 491 - restored the word "also". These routines are valid for intra and inter. Writing "apply to inter" may be interpreted that they are only valid for inter. Writing "also apply to inter" should solve this problem. I also colored this sentence red. I hop, this isokay with you. Best regards Rolf On Fri, 11 Apr 2008 15:22:10 -0700 Adam Moody <moody20_at_[hidden]> wrote:
Hi Rolf, I have checked in my changes for the Collectives chapter. It's ready to be reviewed by the collective chapter reviewers. -Adam
Rolf Rabenseifner wrote:
write-token again to the chapter authors << - but only until Saturday 8:00 European GMT <<
Hi all authors and reviewers,
Please read this mail carfully, if you want to make any further modification of the text.
You must now call svn update to get the newest release!! We have a again a consistent version. Nearly all of
http://www.hlrs.de/mpi/mpi21/doc/MPI-2.1draft-2008-02-23-review.txt
is now implemented in the tex-source. Only a few items are still open, see statistics at the beginning.
You can view the current version (it is svn revision 92) at
http://www.hlrs.de/mpi/mpi21/doc/mpi-report.pdf
It is only today and Friday remaining for finishing MPI-2.1. I give back the write-token to the authors.
On Saturday morning European time, I take the write-token automatically on Saturday morning to build final pdf for the reviews.
As I can see, many chapter authors made fine cleaning to the text. All larger changes should be defered to MPI-2.2! Especially the merge of MPI Environment (inquiry.tex), Misc (misc-2.tex) and External Interfaces (ei-2.tex) to one chapter "MPI Environment and Miscellany" (with 45 pages) may be defered also to MPI-2.2.
Up to now, I was able to check most changes and they look fine.
Best regards Rolf
Dr. Rolf Rabenseifner . . . . . . . . . .. email rabenseifner_at_[hidden] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . (Office: Allmandring 30) _______________________________________________ mpi-21 mailing list mpi-21_at_[hidden] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-21
participants (1)
unknown@example.com
