Re: [mpi-21] Ballot 4 - Re: Request for interpretation
Do we mean "implementation defined" instead of "undefined"?
On Thu, 31 Jan 2008 14:16:20 -0500 Richard Treumann <treumann_at_[hidden]> wrote:
Jim
The sense I get from the phrase "the behavior is undefined" is that defining the behavior is beyond the scope of the standard.
The MPI standard does have some predefined keys and requires an implementation that supports any predefined key to support it as described by the standard. That can lead to one place in the standard saying "the behavior is undefined" and another saying "here is the definition of the behavior".
Maybe I am reading more than others into the phrase "the behavior is undefined" but it does have this strong implication in my mind.
How is this ?
An implementation must support info objects as caches for arbitrary key, value) pairs, regardless of whether it recognizes the key. Each function that takes hints in the form of an MPI_Info must be prepared to ignore any key it does not recognize. This description of info objects does not attempt to define how a particular function should react if it recognizes a key but not the associated value.
note: I also changed MPI function to simply function because with this free form approach to the info object, it seems to me a third party library that is intended to work as part of an MPI program may want to use MPI_Info objects too. If someone authors a parallel math library and wants the initialization routine to look like: init_pmath( MPI_Info info) why not? They should understand that init_pmath must ignore keys it does not recognize even if i is not an MPI_ routine.
Dick
Dick Treumann - MPI Team/TCEM IBM Systems & Technology Group Dept 0lva / MS P963 -- 2455 South Road -- Poughkeepsie, NY 12601 Tele (845) 433-7846 Fax (845) 433-8363
mpi-21-bounces_at_[hidden] wrote on 01/31/2008 09:39:52 AM:
As you are saying, there are two different classes of errors here.
1) Keys which are not understood and need to be ignored by functions which donât grok them (âJIMS_SECRET_TAGâ,â99â) 2) Keys which are understood by a function, but with a value which is not (âbuffer_sizeâ, âHelloâ)
I think allowing the second type to have undefined behavior is the right thing to do, since itâs the most general. If your implementation wants to define the behavior of some out-of- range values, thatâs fine and doesnât make you non-conforming, it just means you defined the previously undefined behavior for some set of values.
Having that undefined-ness explicit here (in one central place) seems to make sense (if only because it may be omitted in one of the other places where it should appear).
My addition does not alter the existing change which guarantees case 1, itâs only concerned with case 2. -- Jim
James Cownie <james.h.cownie_at_[hidden]> SSG/DPD/PAT Tel: +44 117 9071438
From: mpi-21-bounces_at_[hidden] [mailto:mpi-21-bounces_at_[hidden]] On Behalf Of Richard Treumann Sent: 31 January 2008 14:20 To: Mailing list for discussion of MPI 2.1 Subject: Re: [mpi-21] Ballot 4 - Re: Request for interpretation
Jim -
I was taking the view that the description of what to do for a recognized key but dubious value belongs to the function that recognizes the specific key. For example if MPI_File_open accepts a "buffer_size" hint with range "32K" to "16M" we may want to define the behavior of hints that are out of range.
Once we say an info can have arbitrary keys we need to state that every info consumer must be prepared to ignore keys it does not recognize because we have made unrecognizable keys legitimate.
Dick Dick Treumann - MPI Team/TCEM IBM Systems & Technology Group Dept 0lva / MS P963 -- 2455 South Road -- Poughkeepsie, NY 12601 Tele (845) 433-7846 Fax (845) 433-8363
mpi-21-bounces_at_[hidden] wrote on 01/31/2008 08:43:04 AM:
However, you have apparently lost the liberty to have undefined behavior which was there in the previous version.
Maybe you should keep that, something like An implementation must support info objects as caches for arbitrary (key, value) pairs, regardless of whether it recognizes the keys. Each MPI function which takes hints in the form of an MPI_Info must be prepared to ignore any key it does not recognize. However if a function recognizes a key but not the associated value, then the behavior is undefined. (Modifications in italics) -- Jim
From: mpi-21-bounces_at_[hidden] [mailto:mpi-21-bounces_at_[hidden]] On Behalf Of Richard Treumann Sent: 31 January 2008 13:29 To: Mailing list for discussion of MPI 2.1 Subject: Re: [mpi-21] Ballot 4 - Re: Request for interpretation
Your wording works for me Rolf. -- Thanks
mpi-21-bounces_at_[hidden] wrote on 01/31/2008 05:25:46 AM:
I try to summarize all 3 replies in one proposal:
___________________________________
Proposal: MPI 2.0, Sect. 4.10 Info Objects, page 43, line 38-40 read: If a function does not recognize a key, it will ignore it, unless otherwise specified. If an implementation recognizes a key but does not recognize the format of the corresponding value, the result is undefined. but should read: An implementation must support info objects as caches for arbitrary (key, value) pairs, regardless of whether it recognizes the pairs. Each MPI function which takes hints in the form of an MPI_Info must be prepared to ignore any key it does not recognize.
Add after MPI 2.0, Sect. 4.10 Info Objects, page 44, line 22 a new paragraph: Advice to implementors. Although in MPI functions that take hints in form of an MPI_Info (e.g., in process creation and management, one-sided communication, or parallel file I/O), an implementation must be prepared to ignore keys that it does not recognize, for the purpose of MPI_INFO_GET_NKEYS, MPI_INFO_GET_NTHKEY, MPI_INFO_GET_VALUELEN, and MPI_INFO_GET, the implementation must retain all (key,value) pairs so that layered functionality can also use the Info object. (End of advice to implementors.) _____________________________ Rationale for this clarification:
The MPI-2.0 text allowed that also MPI_INFO_DELETE, MPI_INFO_SET, MPI_INFO_GET, and MPI_INFO_DUP could ignore (key,value) pairs that are not recognized in routines in other chapters that take hints with info arguments. The proposed clarification is necessary when we assume, that layered implementation of parts of the MPI-2 standard should be possible and may use the MPI_Info objects for their needs. This was a goal of the MPI-2 Forum and the MPI-2.0 specification. ___________________________________
Bronis, for me, your wording "an MPI implementation may restrict" was in conflict with the rest of the advice. I hope the formulation above is also okay. It is based on the new wording from you and Dick in first part of the proposal.
Best regards Rolf
Dr. Rolf Rabenseifner . . . . . . . . . .. email rabenseifner_at_[hidden] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . (Office: Allmandring
Not quite; For example the standard offers: { cb_buffer_size} (integer) {SAME}: This hint specifies the total buffer space that can be used for collective buffering on each target node, usually a multiple of cb_block_size. The standard says a program is "erroneous" if the value is not the same at all callers. That is not exactly the same as the standard defining behavior for MPI_FILE_OPEN with a valid key and garbage value but pretty close. If MPI 3 adds new defined keys for new specific functions it may or may not want to go into defining behavior for some kinds of bad input. Dick Dick Treumann - MPI Team/TCEM IBM Systems & Technology Group Dept 0lva / MS P963 -- 2455 South Road -- Poughkeepsie, NY 12601 Tele (845) 433-7846 Fax (845) 433-8363 mpi-21-bounces_at_[hidden] wrote on 01/31/2008 03:55:15 PM: 30)
_______________________________________________ mpi-21 mailing list mpi-21_at_[hidden] http://lists.cs.uiuc.edu/mailman/listinfo/mpi-21
Intel Corporation (UK) Limited Registered No. 1134945 (England) Registered Office: Pipers Way, Swindon SN3 1RJ VAT No: 860 2173 47
This e-mail and any attachments may contain confidential material for the sole use of the intended recipient(s). Any review or distribution by others is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies. _______________________________________________ mpi-21 mailing list mpi-21_at_[hidden] http://lists.cs.uiuc.edu/mailman/listinfo/mpi-21
Dr. Rolf Rabenseifner . . . . . . . . . .. email rabenseifner_at_[hidden] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . (Office: Allmandring 30) _______________________________________________ mpi-21 mailing list mpi-21_at_[hidden] http://lists.cs.uiuc.edu/mailman/listinfo/mpi-21
participants (1)
unknown@example.com
