Re: [Mpi-21] TODO - AUTHORS of MPI-2.1 - Workplan
Bronis, If the data-type section get moved into the chapter 3 it make sense to merge the leftover of the chapter 11 with chapter 7, as long as we choose a right name. "MPI Environmental Management" is not the right chapter for "Generalized Requests". But of course these are just details. I'll get in touch with you asap to see how we can coordinate. Thanks, george. On Apr 3, 2008, at 12:58 PM, Bronis R. de Supinski wrote:
Rolf:
Re:
my general statements do not answer you initial question:
My opinion is that leaving obvious problems unfixed based on an expected future version is a bad idea. However, I don't want to argue over this since I think the best approach is just to remove them now and then we don't have to worry about them. Others have more concerns over the time that they can devote to this (not that I have an abundance) and might want to delay in any event in order to get it right (at least mostly).
If you decide to move parts from Chap.11 to Chap.7, then you both mus discuss this. You both are responsible for these chapters. And you should first convince your reviewers: - Chap. 7: Rich, Jesper, Steve, Kannan, David, Bill - Chap.11: Bill and Rainer My recommendation: Express clearly which parts should be moved exactly to wich line (all based on page/line numbers as **printed** in Draft Apr. 1, 2008).
I have discussed moving the datatype decoding stuff with Rich and Bill. I will move those sections as I suggested, with an initial pass for the current review. This works well for Rich since he does not have time to do this for another couple of weeks. I hope to get that done today.
For the remainder, I will look over the two chapters (7 & 11) and propose an initial merge strategy. George can react to that; I don't know how long it will take me to get that done...
Bronis
_______________________________________________ mpi-21 mailing list mpi-21_at_[hidden] http://lists.mpi-forum.org/mailman/listinfo.cgi/mpi-21
participants (1)
unknown@example.com
