Ballot 4 - Re: MPI Process Topologies - discussion?
This is a proposal for MPI 2.1, Ballot 4. This is a follow up to: Questions about Graph_create, Cart_crate, and Cart_coords in http://www.cs.uiuc.edu/homes/wgropp/projects/parallel/MPI/mpi-errata/index.h... with mail discussion in http://www.cs.uiuc.edu/homes/wgropp/projects/parallel/MPI/mpi-errata/discuss... Based on the questions for clarification, I propose: Proposal for MPI 2.1, Ballot 4: ------------------------------- MPI-1.1, Sect. 6.5.3, page 181, line 1-3 read: If the size, nnodes, of the graph is smaller than the size of the group of comm, then some processes are returned MPI_COMM_NULL, in analogy to MPI_CART_CREATE and MPI_COMM_SPLIT. but should read If the size, nnodes, of the graph is smaller than the size of the group of comm, then some processes are returned MPI_COMM_NULL, in analogy to MPI_CART_CREATE and MPI_COMM_SPLIT. If the graph is empty, i.e., nnodes == 0, then MPI_COMM_NULL is returned in all processes. ------ Rationale for this clarification: As in MPI_COMM_CREATE, empty groups are allowed, but empty groups are described here in a different way, and should be mentioned explicitly therefore. ------------------------------- After MPI-1.1, Sect. 6.5.3, page 181, line 35, the following paragraph should be added: It is allowed that at a process, a neighbor process is defined multiple in the list of neighbors (i.e., multiple edges). It is also allowed that a process is neighbor to itself (i.e., a self loop in the graph). It is allowed, that the adjacency matrix is not symmetric. Advice to users. Whether using of multiple edges or a non-symmetric adjacency matrix may have possible performance implications is not defined by this standard. The definition of a node-neighbor edge does not imply a direction of the communication. (End of advice to users.) ------ Rationale for this clarification: The Example 6.3, MPI-1.1, page 15, line 29 - page 186, line 13, clearly shows multiple edges between nodes and self loops: the two (multiple) self-loops of node 0 and of node 7. It is nowhere forbidden, that the graph has edges only in one direction. ------------------------------- After MPI-1.1, Sect. 6.4, page 178, end of the sentence on lines 6-7, the following sentence should be added: All input arguments must have identical values on all processes of the group of comm_old. ------ Rationale for this clarification: This statement is missing. ------------------------------- I have split this discussion track into this track on graph topologies and an additional track (will come) on 0-dim MPI_CART_CREATE and MPI_CART_SUB. Discussion should be done through the new mailing list mpi-21_at_cs.uiuc.edu. I have sent out this mail with CC through the old general list mpi-21_at_[hidden] Best regards Rolf Dr. Rolf Rabenseifner . . . . . . . . . .. email rabenseifner_at_[hidden] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . (Office: Allmandring 30)
participants (1)
unknown@example.com
