Re: [mpi-21] MPI 2.1 Abstract text
Rolf: Re:
This is the currently proposed Abstract for MPI 2.1:
A couple minor editing suggestions: ---------------------------------------------------------------------- This document describes the MPI standard version 2.1 in one combined document. This document combines the content from the previous standards MPI: A Message-Passing Interface Standard, June 12, 1995 (MPI-1.1) and MPI-2: Extensions to the Message-Passing Interface, July, 1997 (MPI-1.2 and MPI-2.0) and errata documents from the MPI Forum. The standard MPI-1.1 includes point-to-point message passing, collective communications, group and communicator concepts, process topologies, environmental management, and a profiling interface. Language bindings for C and Fortran are defined. The MPI-1.2 chapter of the MPI-2 document contains clarifications and corrections to the MPI-1.1 standard and defines MPI-1.2. Together with corrections, these MPI-1 documents were combined to MPI 1.3 (<data>, 2008) which was used as input for this document. The second input is the MPI-2 part of the MPI-2 document, which describes additions to the MPI-1 standard and defines the MPI standard version 2.0. These include miscellaneous topics, process creation and management, one-sided communications, extended collective operations, external interfaces, I/O, and additional language bindings (C++). Additional clarifications and errata corrections to MPI-2.0 are also included. ---------------------------------------------------------------------- I changed "book" to "document" for consistency, and added a "The " and a comma needed for grammatical correctness. Bronis
It is based on the abstract of MPI 2.0. MPI 1.1 hadn't any abstract.
This abstact should tell the main features of MPI. It should not give a full history. This is done by the versions page. Hints from the MPI Forum meeting Jan. 2008 are also included, i.e., the major sources are referenced, but also the steps between, i.e., the clarifications and MPI 1.3.
-------------------------------------------------------- Discussion should be done through the new mailing list mpi-21_at_cs.uiuc.edu.
I have sent out this mail with CC through the old general list mpi-21_at_[hidden]
Best regards Rolf
Dr. Rolf Rabenseifner . . . . . . . . . .. email rabenseifner_at_[hidden] High Performance Computing Center (HLRS) . phone ++49(0)711/685-65530 University of Stuttgart . . . . . . . . .. fax ++49(0)711 / 685-65832 Head of Dpmt Parallel Computing . . . www.hlrs.de/people/rabenseifner Nobelstr. 19, D-70550 Stuttgart, Germany . (Office: Allmandring 30) _______________________________________________ mpi-21 mailing list mpi-21_at_[hidden] http://lists.cs.uiuc.edu/mailman/listinfo/mpi-21
participants (1)
unknown@example.com
