Re: [Kbase-core] Globus online
if I bring up globus-connect, I don't see any kbase-* endpoints in the endpoint list - am I reading this wrong? Or are they dolson#kbase-chicago dolson#kbase-knoxville? --bob On Apr 24, 2013, at 3:10 PM, Dan Olson wrote:
We do have the dtn's defined in GO. kbase-chicago, and kbase-knoxville are defined.
In order to use shock directly we need to figure out the optimal way to display the shock data as a filesystem abstraction. I think this should be a priority for the shock developers.
GCMU isn't required to use globus connect. You can fire up globus connect and transfer data to the kbase DTNs today. However, you have to use your developer credentials to auth.
We are trying to get GCMU installed on some KBase endpoints to support richer user-user sharing of data. The globus connect to standard gridftp interface just puts the data down on the filesystem with no good way to link it to accounts outside of unix perms on the DTN.
----- Original Message -----
From: "Robert Olson" <[email protected]> To: [email protected] Sent: Wednesday, April 24, 2013 2:55:13 PM Subject: [Kbase-core] Globus online
Do we have any KBase Globus Online endpoints defined? It seems it would make sense to have ADM storage visible via both Globus Online and Shock. Since Shock doesn't supply any real upload support (the client application doesn't seem to do much from my read of it) it would make sense to utilize GO to provide high performance upload.
With Globus Connect (a client-side application that appears to integrate nicely with the Mac at least), we could enable high performance up/downloads between user systems and KBase.
This seems related - globus connect multiuser https://www.globusonline.org/gcmu/ and would be required on the KB transfer node (it requires firewall be opened).
The context of this is enabling real-life large file upload for KB users without forcing them to handle the huge details required since the Shock folks don't care to make things easy for the end user. _______________________________________________ Kbase-core mailing list [email protected] https://lists.kbase.us/mailman/listinfo/kbase-core
participants (1)
Robert Olson
