Re: [JLSE-Intel-NDA] no nodefile
OK on the interactive jobs. But the job that switched memory mode was a script and it had no node file apparently. A subsequent job that did not switch modes worked ok. I'm trying again with a mode switch. (Perhaps because the job had "exceeded" its time the node file was removed?) Steve Steven C. Pieper, Senior Physicist Emeritus: [email protected] Argonne National Laboratory, Physics Division, Bldg. 203, Argonne, IL 60439 Phone: 630-252-4232 Fax -6008 Secretary, Debra Beres, -4100 http://www.phy.anl.gov/theory/staff/scp.html On 08/09/16 11:41, Allen, Benjamin S. wrote:
Environment vars aren't passed or setup for you in an interactive job unfortunately. You can find the node file in /var/tmp/cobalt.<job_id> however.
This is on the list of bugs to fix, but unknown timeframe.
Ben
On Aug 9, 2016, at 11:33 AM, Steven C. Pieper <[email protected]> wrote:
I submitted a job that changed the memory mode. After the reboot the job script started but my mpirun command failed with:
[[email protected]] HYDU_parse_hostfile (../../utils/args/args.c:535): unable to open host file: /var/tmp/cobalt.152 [[email protected]] mfile_fn (../../ui/mpich/utils.c:450): error parsing hostfile [[email protected]] match_arg (../../utils/args/args.c:243): match handler returned error [[email protected]] HYDU_parse_array (../../utils/args/args.c:269): argument matching returned error [[email protected]] parse_args (../../ui/mpich/utils.c:4498): error parsing input array [[email protected]] HYD_uii_mpx_get_parameters (../../ui/mpich/utils.c:4819): unable to parse user arguments [[email protected]] HYDU_parse_hostfile (../../utils/args/args.c:535): unable to open host file: /var/tmp/cobalt.152 [[email protected]] mfile_fn (../../ui/mpich/utils.c:450): error parsing hostfile [[email protected]] match_arg (../../utils/args/args.c:243): match handler returned error [[email protected]] HYDU_parse_array (../../utils/args/args.c:269): argument matching returned error [[email protected]] parse_args (../../ui/mpich/utils.c:4498): error parsing input array [[email protected]] HYD_uii_mpx_get_parameters (../../ui/mpich/utils.c:4819): unable to parse user arguments
Then I tried to start an interactive job (without specifying any memory mode) and I got the same nodes (knl04,05) and there is no node file:
[jlselogin1 he4] qsub -n 2 -q knl_7210 -t 60 -I Wait for job 154 to start... Opening interactive session to knl04 Last login: Tue Aug 9 16:24:36 2016 from jlselogin1.ftm.alcf.anl.gov DISPLAY = 10.17.6.108:10.0 connected to knl04 ssh connection, ssh display would be:, 10.17.6.11:0.0
[knl04 ~] echo $COBALT_NODEFILE
[knl04 ~]
Steve
-- Steven C. Pieper, Senior Physicist Emeritus: [email protected]
http://www.phy.anl.gov/theory/staff/scp.html _______________________________________________ Intel-nda mailing list [email protected] https://lists.jlse.anl.gov/mailman/listinfo/intel-nda
participants (1)
Steven C. Pieper
