Re: [JLSE-Intel-NDA] libifport error
Another tip you shouldn't need to set INTEL_LICENSE_FILE anymore. The compilers (and other Intel tools) look for a license file in the install which redirects them to the server. Ben
On Sep 23, 2016, at 11:45 AM, François Tessier <[email protected]> wrote:
Ok, good to know. It seems to resolve the issue. With this configuration, I'm able to compile and run a simple MPI "Hello world" example on a KNL node using the Intel compiler.
--------------------- export INTEL_LICENSE_FILE=28518@ftsn2 source /soft/compilers/intel/compilers_and_libraries/linux/bin/compilervars.sh intel64 source /soft/compilers/intel/vtune_amplifier_xe/amplxe-vars.sh source /soft/compilers/intel/advisor/advixe-vars.sh source /soft/compilers/intel/inspector/inspxe-vars.sh source /soft/compilers/intel/compilers_and_libraries/linux/mpi/bin64/mpivars.sh ---------------------
François
On 09/23/2016 11:37 AM, Allen, Benjamin S. wrote:
The compilers, etc in /soft/compilers/intel are the GA release of 2017 now. They're newer than 2017 beta which is installed in /soft/compilers/intel_beta. You should be using the newer version. If someone works with the beta version and not the GA that also should be filed as a bug.
Ben
On Sep 23, 2016, at 10:55 AM, François Tessier <[email protected]> wrote:
It works with mpiicc instead of mpicc. I updated all the paths to use intel_beta. However, even if the compilation succeeds, a call to mpirun gives the same error related to "for_ifcore_version". Is there a specific wrapper to use instead of mpirun to run the application on KNL?
Maybe all of this should be added to http://jlse.anl.gov/installed-software/
François
On 09/22/2016 10:42 PM, Hammond, Jeff R wrote:
Why do you mix /soft/compilers/intel_beta
and /soft/compilers/intel
Jeff
On 9/22/16, 1:42 PM, "[email protected] on behalf of François Tessier" <[email protected] on behalf of [email protected]> wrote:
Hi All,
I'm trying to compile a MPI application with the Intel Compiler for KNL. However, I have issues like that:
----------------------- --> mpicc -g -O3 -xMIC-AVX512 hello.c -o hello /soft/compilers/intel_beta/compilers_and_libraries_2017.0.042/linux/compil er/lib/intel64/libifport.so.5: undefined reference to `for_ifcore_version' -----------------------
According to some posts on Intel forums, it seems to come from a conflict between the mpivars.sh script and $PATH and $LD_LIBRARY_PATH set for mpich-intel-3.1.4. I tried several combinations of these but without any success. Here is the configuration I use:
----------------------- export INTEL_LICENSE_FILE=28518@ftsn2 source /soft/compilers/intel_beta/compilers_and_libraries/linux/bin/compilervars. sh intel64 source /soft/compilers/intel/vtune_amplifier_xe/amplxe-vars.sh source /soft/compilers/intel/advisor_xe/advixe-vars.sh source /soft/compilers/intel/inspector_xe/inspxe-vars.sh #source /soft/compilers/intel_beta/impi/2017.0.042/bin64/mpivars.sh
export PATH=/soft/libraries/mpi/mpich-intel-3.1.4/bin:$PATH export LD_LIBRARY_PATH=/soft/libraries/mpi/mpich-intel-3.1.4/lib:$LD_LIBRARY_PATH -----------------------
To confirm that MPI is set properly:
----------------------- --> mpicc --version icc (ICC) 17.0.0 20160315 Copyright (C) 1985-2016 Intel Corporation. All rights reserved. --> mpif90 --version ifort (IFORT) 17.0.0 20160315 Copyright (C) 1985-2016 Intel Corporation. All rights reserved. -----------------------
Any idea?
François
-- -- François TESSIER, Ph.D. Postdoctoral Appointee Argonne National Laboratory LCF Division - Bldg 240, 4E 19 Tel : +1 (630)-252-5068 http://www.francoistessier.info
_______________________________________________ Intel-nda mailing list [email protected] https://lists.jlse.anl.gov/mailman/listinfo/intel-nda -- -- François TESSIER, Ph.D. Postdoctoral Appointee Argonne National Laboratory LCF Division - Bldg 240, 4E 19 Tel : +1 (630)-252-5068 http://www.francoistessier.info
participants (1)
Allen, Benjamin S.
