Re: [JLSE-Intel-NDA] Using VTune remotely on the Phi
Hi Will, Does this command work?
amplxe-cl –collect advanced-hotspots openmc
Regards -michael From: Will Boyd [mailto:[email protected]] Sent: Wednesday, January 04, 2017 4:25 PM To: Hammond, Jeff R <[email protected]>; D'mello, Michael <[email protected]>; [email protected] Subject: Re: [JLSE-Intel-NDA] Using VTune remotely on the Phi I am trying to run VTune on KNL but am running into the following error: $ amplxe-cl -collect hpc-performance openmc amplxe: Error: both cgroup and no-aggregation modes only available in system-wide mode usage: perf stat [<options>] [<command>] -G, --cgroup <name> monitor event in cgroup name only -A, --no-aggr disable CPU count aggregation -a, --all-cpus system-wide collection from all CPUs This command works fine on a Haswell node, but breaks when I run it on KNL. I am able to run VTune with the "hotspots" collection argument without on KNL. Does anyone know how to resolve this issue? Thanks, Will On Tue, Dec 13, 2016 at 6:22 PM Hammond, Jeff R <[email protected]<mailto:[email protected]>> wrote: FWIW based upon my experience trying unsuccessfully to debug why NWChem won’t run in the Vtune GUI, I recommend always using Vtune CLI. It’s a bad habit to get used to fancy features like GUIs and dynamic memory allocation if you want to be a serious HPC person ;-) Jeff From: <[email protected]<mailto:[email protected]>> on behalf of Will Boyd <[email protected]<mailto:[email protected]>> Date: Tuesday, December 13, 2016 at 3:00 PM To: "D'mello, Michael" <[email protected]<mailto:[email protected]>>, "[email protected]<mailto:[email protected]>" <[email protected]<mailto:[email protected]>> Subject: Re: [JLSE-Intel-NDA] Using VTune remotely on the Phi Thank you Michael and Jeff. Downloading the results from the VTune CLI and importing them into the VTune GUI locally works great. On Tue, Dec 13, 2016 at 5:35 PM D'mello, Michael <[email protected]<mailto:[email protected]>> wrote: Hi Will, You can use the command line interface to collect the profiling information. For example:
amplxe_cl –collect hotspots ./a.out
You can then move the results (entire directory) over to the environment (Windows or Linux) in which you would like to view the results. regards -michael From: [email protected]<mailto:[email protected]> [mailto:[email protected]<mailto:[email protected]>] On Behalf Of Will Boyd Sent: Tuesday, December 13, 2016 4:30 PM To: [email protected]<mailto:[email protected]> Subject: [JLSE-Intel-NDA] Using VTune remotely on the Phi I am interested in profiling an application on the Phi using Intel VTune. I would like to use the graphical interface for VTune, but have been unable to launch VTune remotely using my local instance of VTune. Does anyone have any recommendations for how to remotely profile my application on the Phi but view the results locally with the VTune GUI on my workstation? Thanks, Will
participants (1)
D'mello, Michael
