Re: [JLSE-Intel-NDA] KNL Status
I guess warm reboot should be avoided. Last time it also hanged. On 04/13/2016 02:46 PM, Allen, Benjamin S. wrote:
Yea, it hangs on warm reboot. Power cycling it via ipmi now.
Ben
On Apr 13, 2016, at 2:44 PM, Vitali A. Morozov <[email protected]> wrote:
I was using
sudo /usr/bin/systemctl reboot
and it is booting for over 30 minutes now. Something is not right...
Vitali
On 04/13/2016 02:05 PM, Vitali A. Morozov wrote:
As no complains have been posted, rebooting to SNC-4/Flat.
Vitali
On 04/13/2016 01:17 PM, Vitali A. Morozov wrote:
Hello,
With current setup of All2All/Flat, we seem to have a stable 410 GB/s from MCDRAM and 78 GB/s from DDR.
For STREAMing from MCDRAM, Intel people suggested to try SNC-4/Flat promising 430 GB/s. Our previous trials with other combinations of NOC settings lead to unstable results.
Do we want to try it now? It will probably require hard reboot.
Vitali
On 04/13/2016 01:06 PM, Raman, Karthik wrote:
Ok I read this as 418 GB/s J
And ok, just realized you are running in All2All mode, so yes this looks good. For Quad/Flat you should see ~440 GB/s with the same run.
From: Vitali A. Morozov [mailto:[email protected]] Sent: Wednesday, April 13, 2016 11:02 AM To: Raman, Karthik <[email protected]>; Chinthamani, Sundaram <[email protected]>; Kumaran, Kalyan <[email protected]> Cc: Sodani, Avinash <[email protected]>; Fromkin, Russ <[email protected]>; Harms, Kevin <[email protected]>; Morozov, Vitali A. <[email protected]>; Allen, Benjamin S. <[email protected]> Subject: Re: [JLSE-Intel-NDA] KNL Status
Hi Karthik,
Repeating the same options you have:
mpiicc -O3 -xMIC-AVX512 -opt-report=5 -Wall -g -fopenmp -mcmodel medium -shared-intel -opt-streaming-stores always stream.c -o stream
------------------------------------------------------------- STREAM version $Revision: 5.9 $ ------------------------------------------------------------- This system uses 8 bytes per DOUBLE PRECISION word. ------------------------------------------------------------- Array size = 134217728, Offset = 0 Total memory required = 3072.0 MB. Each test is run 100 times, but only the *best* time for each is used. ------------------------------------------------------------- Number of Threads requested = 64 -------------------------------------------------------------
< skiped >
Function Rate (MB/s) Avg time Min time Max time Copy: 362331.5200 0.0060 0.0059 0.0061 Scale: 359281.9806 0.0060 0.0060 0.0062 Add: 418122.7024 0.0078 0.0077 0.0081 Triad: 418122.7024 0.0078 0.0077 0.0081 Store: 224685.6729 0.0048 0.0048 0.0049
408GB/s
Vitali
_______________________________________________ Intel-nda mailing list
[email protected] https://lists.jlse.anl.gov/mailman/listinfo/intel-nda
Intel-nda mailing list [email protected] https://lists.jlse.anl.gov/mailman/listinfo/intel-nda
participants (1)
Vitali A. Morozov
