Re: [JLSE-Intel-NDA] Location of Vtune?
To setup the Vtune environment the simplest way is to use the command : source /soft/compilers/intel/vtune_amplifier_xe_2016.4.0.470476/amplxe-vars.sh I believe you should be able to just add it to your Cobalt script before the amplxe-cl command. -Scott On 8/24/16 9:26 AM, Tom LeCompte wrote:
Hi everyone-
I have an application I would like to profile. The Wiki says "Option 1" is to use Vtune and gives instructions
execute the following command via Cobalt submission script
$ amplxe-cl -c memory-access ...
This givea a command not found for amplxe-cl. Is there something I need to set up?
Cheers,
Tom
_______________________________________________ Intel-nda mailing list [email protected] https://lists.jlse.anl.gov/mailman/listinfo/intel-nda
participants (1)
Scott Parker
