Re: [Ecp-aurora-sdk-discuss] omp/2020.04.30.001 Fortran issue
Thanks Thomas. Using ifort instead worked for me. Best, Mike ________________________________ From: Applencourt, Thomas <[email protected]> Sent: Tuesday, May 19, 2020 10:50:15 AM To: [email protected]; Wall, Michael E; Parks, John Subject: [EXTERNAL] Re: omp/2020.04.30.001 Fortran issue Hi Mike, Thanks a lot for the bugs report! We will work with Intel to fix this issue as soon as possible. I assume you used ifx (the new fortran compiler). As a workaround, ifx is ABI compatible with ifort. That means you can compile this file with ifort, and the rest of the code with `ifx`. I know it's a little tedious, to help you can write a little wrapper who tries to do that for you. Something like: ifx $@ if [ $? != 0 ]; then ifort $@ fi Hope this help, Regards, Thomas Thomas Applencourt Leadership Computing Facility Argonne National Laboratory Building 240 Office - 1.D.18 9700 S Cass Av., Lemont Il, 60439 (630) 252-0036 ________________________________ From: Ecp-aurora-sdk-discuss <[email protected]> on behalf of Wall, Michael E via Ecp-aurora-sdk-discuss <[email protected]> Sent: Tuesday, May 19, 2020 11:32 To: [email protected] <[email protected]> Subject: [Ecp-aurora-sdk-discuss] omp/2020.04.30.001 Fortran issue Hi, I'm encountering a compiler error while building a package that includes Fortran on JLSE. I'm using ifx in the omp/2020.04.30.001 (default) module. The package is https://github.com/lanl/bml Here is the error message: /home/mewall/packages/bml/src/Fortran-interface/bml_allocate_m.F90(99): catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error. See line 99 of the source code here, with the above Note caveat: https://github.com/lanl/bml/blob/master/src/Fortran-interface/bml_allocate_m... Any advice for overcoming this issue would be appreciated. Thank you, Mike
participants (1)
Wall, Michael E
