Re: [mpich-discuss] Problem installing MPICH
Hello Balaji and all, I am trying to install MPICH-3.1 on our supercomputer with linux system. I have got the same error as Sahar Amir as follow. It sounds like that Sahar had worked with the option "--disable-maintainer-mode", but it still can not work for me. Anyone can give me some suggestions? I would like to appreciate to you very much. Regards. *Xueming Zhu 朱学明* Key Laboratory of Research on Marine Hazards Forecasting (*LoMF*), SOA National Marine Environmental Forecasting Center (*NMEFC*) No.8 Dahuisi Road, Haidian District, Beijing, 100081 People's Republic of China Tel: +86-10-82481923 在 2014/8/5 23:17, Sahar Amir 写道:
Good morning,
I am trying to install MPICH on my mac. however when I try to apply the instruction make 2>&1 | tee m.log
It gives: CDPATH="${ZSH_VERSION+.}:" && cd . && /bin/sh /Data_1/mpich-3.1.2/confdb/missing aclocal-1.14 -I confdb /Data_1/mpich-3.1.2/confdb/missing: line 81: aclocal-1.14: command not found WARNING: 'aclocal-1.14' is missing on your system. You should only need it if you modified 'acinclude.m4' or 'configure.ac <http://configure.ac>' or m4 files included by 'configure.ac <http://configure.ac>'. The 'aclocal' program is part of the GNU Automake package: <http://www.gnu.org/software/automake> It also requires GNU Autoconf, GNU m4 and Perl in order to run: <http://www.gnu.org/software/autoconf> <http://www.gnu.org/software/m4/> <http://www.perl.org/> make: *** [aclocal.m4] Error 127
Regards, Sahar
------------------------------------------------------------------------ This message and its contents, including attachments are intended solely for the original recipient. If you are not the intended recipient or have received this message in error, please notify me immediately and delete this message from your computer system. Any unauthorized use or distribution is prohibited. Please consider the environment before printing this email.
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
朱学明
