Re: [mpich-discuss] libintlc.so.5 not found while configuring
Seungbum, I've checked your configure flags in our testbed. I find no problems even without the LDFLAGS parameter. Have you tried to compile any other code with your icc setup? I bet there's something wrong with your icc setup. Have you executed the iccvars.sh script? (BTW, we use icc 13.1.3). Antonio On Thursday, September 05, 2013 06:34:08 PM Seungbum Koo wrote: Thank you for your advice. But nothing has changed even if I add that line at the stage of configure. So this is what I wrote in the command line. sudo /opt/mpich/mpich-3.0.4-source/configure --prefix=/opt/mpich/ CC=/opt/intel/composer_xe_2013_sp1.0.080/bin/intel64/icc CXX=/opt/intel/composer_xe_2013_sp1.0.080/bin/intel64/icpc F77=/opt/intel/composer_xe_2013_sp1.0.080/bin/intel64/ifort FC=/opt/intel/composer_xe_2013_sp1.0.080/bin/intel64/ifort LDFLAGS="- L/opt/intel/composer_xe_2013_sp1.0.080/compiler/lib/intel64" --enable- fast=all,O3 --enable-g=dbg,mem,log --enable-shared --with-pm=hydra 2>&1 | sudo tee log_configure.txt What 'configure' says: =============================================== ======= ld: warning: libintlc.so.5, needed by /opt/intel/composer_xe_2013_sp1.0.080/compiler/lib/intel64/libifport.so.5, not found (try using -rpath or -rpath- link)============================================ ========== What 'make' says: Not a single line difference as before. Does it make sense? "libifport.so.5" needs "libintlc.so.5" but they are in the same directory. And those 'not found' files at the 'make' stage as well. They are all in '/opt/intel/composer_xe_2013_sp1.0.080/compiler/lib/intel64/'. Any idea? Seungbum
participants (1)
Antonio J. Peña
