Re: [mpich-discuss] [petsc-dev] Is mpich/master:a8a2b30fd21 tested with Petsc?
Hi Eric, It will be great if you could give us a simple MPI program (not with PETSc) to reproduce this issue. If this is a problem happens only when PETSc is involved, the PETSc team can give you more suggestions. Thanks, Min On 2018/03/27 15:38, Eric Chamberland wrote:
since more than 2 weeks that the master branch of mpich is still and it can be reproduced with a simple "make test" after a fresh installation of PETSc...
Is anyone testing it?
Is it supposed to be working?
Just tell me if I should "follow" another mpich branch please.
Eric
On 14/03/18 03:35 AM, Eric Chamberland wrote:
fwiw, the actual mpich/master branch doesn't passes the PETSc "make test" after a fresh installation... It hangs just afer the 1 MPI process test, meaning it is locked into the 2 process test:
make PETSC_DIR=/pmi/cmpbib/compilation_BIB_dernier_mpich/COMPILE_AUTO/mpich-3.x-debug/petsc-3.8.3-debug PETSC_ARCH=arch-linux2-c-debug test Running test examples to verify correct installation Using PETSC_DIR=/pmi/cmpbib/compilation_BIB_dernier_mpich/COMPILE_AUTO/mpich-3.x-debug/petsc-3.8.3-debug and PETSC_ARCH=arch-linux2-c-debug C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1 MPI process
^Cmakefile:151: recipe for target 'test' failed make: [test] Interrupt (ignored)
thanks,
Eric
On 13/03/18 08:07 AM, Eric Chamberland wrote:
each night we are testing mpich/master with our petsc-based code. I don't know if PETSc team is doing the same thing with mpich/master? (Maybe it is a good idea?)
Everything was fine (except the issue https://github.com/pmodels/mpich/issues/2892) up to commit 7b8d64debd, but since commit mpich:a8a2b30fd21), I have a segfault on a any parallel nightly test.
For example, a 2 process test ends at almost different execution points:
rank 0:
#003: /lib64/libpthread.so.0(+0xf870) [0x7f25bf908870] #004: /pmi/cmpbib/compilation_BIB_dernier_mpich/COMPILE_AUTO/BIB/bin/BIBMEFGD.opt() [0x64a788] #005: /lib64/libc.so.6(+0x35140) [0x7f25bca18140] #006: /lib64/libc.so.6(__poll+0x2d) [0x7f25bcabfbfd] #007: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x1e4cc9) [0x7f25bd90ccc9] #008: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x1ea55c) [0x7f25bd91255c] #009: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0xba657) [0x7f25bd7e2657] #010: /opt/mpich-3.x_debug/lib/libmpi.so.0(PMPI_Waitall+0xe3) [0x7f25bd7e3343] #011: /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(PetscGatherMessageLengths+0x654) [0x7f25c4bb3193] #012: /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecScatterCreate_PtoS+0x859) [0x7f25c4e82d7f] #013: /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecScatterCreate+0x5684) [0x7f25c4e4d055] #014: /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecCreateGhostWithArray+0x688) [0x7f25c4e01a39] #015: /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecCreateGhost+0x179) [0x7f25c4e020f6]
rank 1:
#002: /pmi/cmpbib/compilation_BIB_dernier_mpich/COMPILE_AUTO/GIREF/lib/libgiref_opt_Util.so(traitementSignal+0x2bd0) [0x7f62df8e7310] #003: /lib64/libc.so.6(+0x35140) [0x7f62d3bc9140] #004: /lib64/libc.so.6(__poll+0x2d) [0x7f62d3c70bfd] #005: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x1e4cc9) [0x7f62d4abdcc9] #006: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x1ea55c) [0x7f62d4ac355c] #007: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x12c9c5) [0x7f62d4a059c5] #008: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x12e102) [0x7f62d4a07102] #009: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0xf17a1) [0x7f62d49ca7a1] #010: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x3facf) [0x7f62d4918acf] #011: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x3fc3d) [0x7f62d4918c3d] #012: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0xf18d8) [0x7f62d49ca8d8] #013: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x3fb88) [0x7f62d4918b88] #014: /opt/mpich-3.x_debug/lib/libmpi.so.0(+0x3fc3d) [0x7f62d4918c3d] #015: /opt/mpich-3.x_debug/lib/libmpi.so.0(MPI_Barrier+0x27b) [0x7f62d4918edb] #016: /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(PetscCommGetNewTag+0x3ff) [0x7f62dbceb055] #017: /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(PetscObjectGetNewTag+0x15d) [0x7f62dbceaadb] #018: /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecScatterCreateCommon_PtoS+0x1ee) [0x7f62dc03625c] #019: /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecScatterCreate_PtoS+0x29c4) [0x7f62dc035eea] #020: /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecScatterCreate+0x5684) [0x7f62dbffe055] #021: /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecCreateGhostWithArray+0x688) [0x7f62dbfb2a39] #022: /opt/petsc-3.8.3_debug_mpich-3.x_debug/lib/libpetsc.so.3.8(VecCreateGhost+0x179) [0x7f62dbfb30f6]
Have some other users (PETSc users?) reported problem?
Eric
ps: usual informations:
mpich logs: http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_conf...
http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_mpic...
http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_c.tx...
http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_m.tx...
http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_mi.t...
http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_open...
http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_mpl_...
http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_pm_h...
http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_mpie...
Petsc logs: http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_conf...
http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_make...
http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_defa...
http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_RDic...
http://www.giref.ulaval.ca/~cmpgiref/dernier_mpich/2018.03.12.05h39m54s_CMak...
_______________________________________________ discuss mailing list [email protected] To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/discuss
participants (1)
Min Si
