Re: [mpich-discuss] MPICH2 -Problem
Hello, hamideh! You wrote to <[email protected]> on Sun, 24 Feb 2013 18:30:43 +0330: hj> I see file 'config.log' from the same directory where the 'configure' hj> was started. I attached its to this email. In the content of this file, hj> pthread libraries such as "pthread.h,pthread_yield" have make. but hj> there are related error... hj> Do you know that what do we do? 1) /home/inet/src/applications/sctpapp/SCTPlikeAPI/include: No such file or directory Is this directory exists? If yes, maybe the path at all is incorrect? Try exactly 'ls -la /home/inet/src/applications/sctpapp/SCTPlikeAPI/include' 2) /usr/bin/ld: cannot find -lsctplike Have you correctly installed your SCTPlikeAPI? Add its 'lib' directory to ldconfig paths (/etc/ld.so.conf.d). This directory have to contain the file (or softlink) libsctplike.so. Then run from root ldconfig -v, and try to configure again. hj> On Sun, Feb 24, 2013 at 12:22 PM, Andrey V. Malyshev hj> <[email protected]>wrote: ??>> Hello, hamideh! ??>> You wrote to <[email protected]> on Sun, 24 Feb 2013 10:12:01 +0330: ??>> hj>>> I think configure doesn't done correctly! ??>> ??>> That's right. ??>> hj>>> configure command is : hj>>> ../configure --with-device=ch3:sctp hj>>> --with-sctp=/home/inet/src/applications/sctpapp/SCTPlikeAPI hj>>> --prefix=/home/mpich2-hginit �disable-mpe hj>>> What I am doing? :( ??>> ??>> See the file 'config.log' from the same directory where the ??>> 'configure' was started, or where the 'configure' file is ??>> located. Pthread library was not found, you should understand, why, ??>> and maybe then it becomes clear how to fix. ??>> hj>>> On Sun, Feb 24, 2013 at 10:07 AM, Andrey V. Malyshev hj>>> <[email protected]>wrote: ??>> ??>>>> Hello, hamideh! ??>>>> You wrote to <[email protected]> on Sun, 24 Feb 2013 08:23:37 +0330: ??>>>> hj>>>>> checking for pthread.h... yes ??>>>> checking for pthread_yield... no ??>>>> checking for library containing pthread_key_create... no ??>>>> configure: error: unable to find pthreads library ??>>>> ??>>>> See config.log, what error occurs during this check? ??>>>> ??>>>> -- ??>>>> With best regards, Andrey V. Malyshev. ??>>>> E-mail: [email protected] ??>>>> _______________________________________________ ??>>>> discuss mailing list [email protected] ??>>>> To manage subscription options or unsubscribe: ??>>>> https://lists.mpich.org/mailman/listinfo/discuss ??>>>> hj>>> -- hj>>> *Best Regards* hj>>> * ??>> hj>>> Hamideh Jabalameli* ??>> hj>>> M.Sc Candidate, hj>>> School of Electrical and Computer Engineering, hj>>> College of Engineering, hj>>> Electronici Shahid Beheshti Tehran University hj>>> [email protected] hj>>> [email protected] ??>> ??>> -- ??>> With best regards, Andrey V. Malyshev. ??>> E-mail: [email protected] ??>> ??>> _______________________________________________ ??>> discuss mailing list [email protected] ??>> To manage subscription options or unsubscribe: ??>> https://lists.mpich.org/mailman/listinfo/discuss ??>> hj> -- hj> *Best Regards* hj> * hj> Hamideh Jabalameli* hj> M.Sc Candidate, hj> School of Electrical and Computer Engineering, hj> College of Engineering, hj> Electronici Shahid Beheshti Tehran University hj> [email protected] hj> [email protected] -- With best regards, Andrey V. Malyshev. E-mail: [email protected]
participants (1)
Andrey V. Malyshev
