Re: [mpich-devel] ifort: error #10236: File not found: 'src/binding/fortran/use_mpi_f08/mpi_f08_types.f90'
That's what I suspected. I have access to Intel 2016, but need our sysadmins to update the license server to activate it. In the meantime, I can try to fake an env that can build F08 and find the underlying problem. It looks like you were doing a vpath build...does an in-tree build succeed? Ken On 09/09/2015 05:43 PM, Jeff Hammond wrote:
You are right. GCC 5.2 contains no references to F08, presumably because configure determined that F08 was not supported. I assume ifort 16 tested positive for F08.
I think you can download Intel 16 but if you have any trouble, let me know offline and I'll help figure it out.
Jeff
On Wed, Sep 9, 2015 at 3:40 PM, Kenneth Raffenetti <[email protected] <mailto:[email protected]>> wrote:
Did the GCC 5.2 build actually build the F08 module? I suspect it might have been disabled at configure time. That is, is there an mpi_f08.mod file in the installed include dir?
On 09/09/2015 12:58 PM, Jeff Hammond wrote:
I cannot configure MPICH due to any F08-related issue. I ran autogen.sh twice just to be darn sure I wasn't making that mistake again.
This is with the latest MPICH git master. I am using Intel Fortran 16 on Mac Yosemite. The GCC 5.2 build was fine so this might be related to ifort, but it's not obvious why.
Jeff
This is how I attempted to configure:
jrhammon-mac01:build jrhammon$ head config.log This file contains any messages produced by compilers while running configure, to aid debugging if configure makes a mistake.
It was created by MPICH configure 3.2rc1, which was generated by GNU Autoconf 2.69. Invocation command line was
$ ../configure CC=icc CXX=icpc FC=ifort F77=ifort --enable-cxx --enable-fortran --enable-threads=runtime --enable-g=dbg --with-pm=hydra --prefix=/opt/mpich/dev/intel/default --enable-wrapper-rpath --enable-static --enable-shared
Here is the error:
Configuration completed. MOD src/binding/fortran/use_mpi_f08/mpi_c_interface_types.stamp MOD src/binding/fortran/use_mpi_f08/mpi_f08_types.stamp ifort: error #10236: File not found: 'src/binding/fortran/use_mpi_f08/mpi_f08_types.f90' ifort: command line error: no files specified; for help type "ifort -help" make: *** [src/binding/fortran/use_mpi_f08/mpi_f08_types.stamp] Error 1
-- Jeff Hammond [email protected] <mailto:[email protected]> <mailto:[email protected] <mailto:[email protected]>> http://jeffhammond.github.io/
_______________________________________________ To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/devel
-- Jeff Hammond [email protected] <mailto:[email protected]> http://jeffhammond.github.io/
participants (1)
Kenneth Raffenetti
